Militia Radio Frequencies
Revision as of 11:57, 24 March 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Tac, Calling/Mutual Aid
  • Channel 13 - 467.6875 MHz - FRS 13 - Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
  • Channel 34 - 154.5700 MHz - MURS 4 - Command Blue
  • Channel 35 - 154.6000 MHz - MURS 5 - Command Green
  • MURS 1 - 151.8200 MHz - 88.5 Hz CALL
  • MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
  • MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
  • MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
  • MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
  • Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2
  • Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3
  • Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 - display channel name: MURS 3 CALL - high power setting
  • Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2 HP - high power setting
  • Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3 HP - high power setting
  • FRS Channels 1-16 (allows simple interoperability with standard FRS radios and standard militia programmed radios). Tone mode should be set to Tone (not TSQL - unless you are programming radios for a group/unit/team/squad/crew specific channel plan - see links and discussion above)
  • Channel 01 - 462.5625 MHz
  • Channel 02 - 462.5875 MHz
  • Channel 03 - 462.6125 MHz
  • Channel 04 - 462.6375 MHz
  • Channel 05 - 462.6625 MHz
  • Channel 06 - 462.6875 MHz
  • Channel 07 - 462.7125 MHz
  • Channel 08 - 467.5625 MHz
  • Channel 09 - 467.5875 MHz
  • Example 16-channel intra squad radio inter squad radio plan - using FRS frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group.
  • Channel 01 - 467.6625 MHz - NNN.N CTCSS
  • Example 16-channel intra squad radio inter squad radio plan - using business frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group.
  • Channel 01 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 02 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 03 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 04 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 05 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 06 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 07 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 08 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 09 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 10 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 11 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 12 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 13 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 14 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 15 - XXX.XXXX MHz - XXX.X Hz CTCSS
  • Channel 16 - XXX.XXXX MHz - XXX.X Hz CTCSS
