Amateur radio
Revision as of 12:14, 29 September 2021 by R4002 (Talk | contribs)
hamateurszzz hamsexy dot com eham dot net et cetera hams don't like CBers. Hammies hamateurs HF frequencies listed below. Several VHF/UHF allocations worldwide. Exact band limits vary from country to country, with 2 meters generally being 144-146 MHz and 70cm generally being centered around 432 MHz or 440 MHz, the US bands of 144-148 MHz and 420-450 MHz are generally larger than allocations in other countries.
Amateur radio has secondary allocation in many bands.
Amateur Radio Bands
  • 28000 kHz - 29700 kHz - 10 meter band
  • 50-54 MHz - 6 meter band (50-51 MHz or 50-52 MHz in some countries)
  • 144-148 MHz - 2 meter band (144-146 MHz only in many countries)
  • 222-225 MHz - 1.25 meter band (220-225 MHz in some areas)
  • 420-450 MHz - 70cm band (usually much smaller in most area/countries, including all of Europe)
