Wi-Fi
900 MHz (802.11ah)
It is important to note that the 902-928 MHz band is allocated to numerous other services, including 33cm amateur radio band, cordless telephone systems, vehicle transponder systems, train and railroad telemetry systems and unlicensed frequency hopping spread spectrum (FHSS) business radio systems.
Region | Subband (MHz) | Bandwidths (MHz) |
Australia | 915–920 MHz | 1, 2, 4 |
920–928 MHz | 1, 2, 4, 8 | |
China | 755–779 MHz | 1 |
779–787 MHz | 1, 2, 4, 8 | |
Europe | 863–868 MHz | 1, 2 |
Japan | 916.5–927.5 MHz | 1 |
Korea | 917.5–923.5 MHz | 1, 2, 4 |
New Zealand | 915–924 MHz | 1, 2, 4, 8 |
924–928 MHz | 1, 2, 4 | |
Singapore | 866–869 MHz | 1, 2 |
920–925 MHz | 1, 2, 4 | |
Taiwan | 839–848.5 MHz | 1, 2, 4 |
United States | 902–904 MHz | 1, 2 |
904–920 MHz | 1, 2, 4, 8, 16 | |
2.4 GHz (802.11b/g/n/ax)
The 2.4 GHz band is extremely congested in many areas with numerous devices using this frequency band, including high power ISM devices, cordless telephones, Bluetooth, analog and digital wireless video link systems (video senders), baby monitors, wireless intercoms, wireless microphone systems, short-range data and audio/video link systems of various power output levels and bandwidths...along with dozens of other uses.
Channel | F0 (MHz) | Frequency Range (MHz) | |
1 | 2412 | 2401–2423 | |
2 | 2417 | 2406–2428 | |
3 | 2422 | 2411–2433 | |
4 | 2427 | 2416–2438 | |
5 | 2432 | 2421–2443 | |
6 | 2437 | 2426–2448 | |
7 | 2442 | 2431–2453 | |
8 | 2447 | 2436–2458 | |
9 | 2452 | 2441–2463 | |
10 | 2457 | 2446–2468 | |
11 | 2462 | 2451–2473 | |
12 | 2467 | 2456–2478 | |
13 | 2472 | 2461–2483 | |
14 | 2484 | 2473–2495 |
To guarantee no interference in any circumstances the Wi‑Fi protocol requires 16.25 to 22 MHz of channel separation. The remaining 2 MHz gap is used as a guard band to allow sufficient attenuation along the edge of the band. This guardband is mainly used to accommodate older routers with modem chipsets prone to full channel occupancy, as most modern Wi‑Fi modems are not prone to excessive channel occupancy. In 22 MHz channel width situations, there is 3 MHz free/unused spectrum between NON-overlapping channels, this is not called "guard band" but channel spacing.
3.65 GHz (802.11y)
Designation | Center (MHz) | Span | ||
5 MHz | 10 MHz | 20 MHz | ||
131 | 3657.5 | 3655–3660 | ||
3660 | 3655–3665 | |||
132 | 3662.5 | 3660–3665 | ||
3665 | 3655–3675 | |||
133 | 3667.5 | 3665–3670 | ||
3670 | 3665–3675 | |||
134 | 3672.5 | 3670–3675 | ||
135 | 3677.5 | 3675–3680 | ||
3680 | 3675–3685 | |||
136 | 3682.5 | 3680–3685 | ||
3685 | 3675–3695 | |||
137 | 3687.5 | 3685–3690 | ||
3690 | 3685–3695 | |||
138 | 3692.5 | 3690–3695 |
Text | Meaning |
Template:Yes | MAY be used without restrictions. |
Template:No | SHOULD NOT be used. |
Template:Yes | MUST be used indoor only. |
Template:Yes | MUST be used with DFS regardless indoor or outdoor. |
Template:Yes | MUST comply with SRD requirements regardless indoor or outdoor. |
Template:Yes | MUST be used with DFS and indoor only. |
Template:Yes | MUST be used with TPC and indoor only. |
Template:Yes | MUST be used with DFS and TPC. |
Template:Yes | MUST be used with DFS, TPC and comply with SRD requirements. |
Template:Yes | MUST be used with DFS, TPC and indoor only. |
Template:Nonfree | MUST be used only after registration. |
Template:Unknown | Information not available or defined. |
Notes: Template:Citation |
Germany requires DFS and TPC capabilities on 5.250–5.350 GHz and 5.470–5.725 GHz as well; in addition, the frequency range 5.150–5.350 GHz is allowed only for indoor use, leaving only 5.470–5.725 GHz for outdoor and indoor use.
Austria
The same restrictions as in Germany apply, only 5.470–5.725 GHz is allowed to be used outdoor and indoor.
Brazil
In Brazil, the TPC use in 5.150–5.725 GHz band is optional. DFS is required only in the 5.470–5.725 GHz band.
Singapore
Singapore regulatory – IMDA requires DFS and TPC capabilities on 5.250–5.350 GHz above 100 mW effective radiated powerand below or equal to 200 mW EIRP, requires DFS capability on 5.250–5.350 GHz below or equal to 100 mW EIRP, and requires DFS and TPC capabilities on 5.470–5.725 below or equal to 1000 mW EIRP (1 watt) Operating 5.725–5.850 GHz above 1000 mW (1 watt) and below or equal to 4000 mW (4 watts) EIRP shall be approved on exceptional basis.
South Korea
Indonesia
5.9 GHz (802.11p)
6 GHz (802.11ax)
On 23 April 2020, the FCC voted to allocate 1.2 GHz of unlicensed spectrum in the 6 GHz band (5.925–7.125 GHz) for Wi-Fi use. This represents a significant increase in available spectrum bandwidth for broadband wireless applications. It also provides for the possibility of moving larger networks off of the heavily congested 2.4 GHz and 5 GHz bands.
Band | 20 MHz | 40 MHz | 80 MHz | 160 MHz |
U-NII-5 | 24 | 12 | 6 | 3 |
U-NII-6 | 5 | 2.5 | 1.25 | 0.5 |
U-NII-7 | 17.5 | 8.75 | 4.25 | 2.25 |
U-NII-8 | 12.5 | 5.75 | 2.5 | 1.25 |
TOTAL | 59 | 29 | 14 | 7 |
Standard power
U-NII-6 | Not allowed | |||
U-NII-7 | 17 | 8 | 3 | 1 |
U-NII-8 | Not Allowed | |||
TOTAL | 41 | 20 | 9 | 4 |
Very-low-power devices
Client devices
Europe
The European Commission is expected to rule on 6 GHz in early 2021. It is currently expected that EU regulations will permit operation only in the band from 5925 to 6425 MHz 5.925 GHz to 6.425 GHz (corresponding to the US U-NII-5 band) by low-power indoor and very-low-power devices.
5925–6425 MHz | 24 | 12 | 6 | 3 |
60 GHz (802.11ad/ay)
