Part 15
Revision as of 13:22, 3 October 2021 by R4002 (Talk | contribs)
RC frequencies:
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
  • 27.255 MHz
  • 49.850 MHz - Channel 2
  • 49.870 MHz - Channel 3
  • 49.890 MHz - Channel 4
  • 49.875 MHZ - Channel 4
  • 49.850 MHz - Channel 1A
  • 49.870 MHz - Channel 2A
  • 49.830 MHz - Channel 1B
  • 49.890 MHz - Channel 2B
  • 49.845 MHz - Channel X
  • 49.875 MHz - Channel Y
Or,
  • 49.830 MHz - Channel A
  • 49.860 MHz - Channel B
Or,
  • 49.845 MHz - Channel A
  • 49.890 MHz - Channel B
Or,
  • 49.840 MHz - Channel A
  • 49.870 MHz - Channel B
Or,
  • 49.850 MHz - Channel I
  • 49.870 MHz - Channel II
Or,
  • 49.825 MHz - Channel 1
Or,
  • 49.870 MHz - Channel 1
Or,
  • 49.840 MHz - Channel 1
  • 49.860 MHz - Channel 2
Or,
Or,
  • 49.885 MHz - Channel B
Or,
  • 49.875 MHz - Channel B
Or,
Or,
  • 49.850 MHz - Channel X
  • 49.880 MHz - Channel Y
  • 49.870 MHz - Channel 4
  • 49.880 MHz - Channel 5
  • 49.890 MHz - Channel 6
  • 49.835 MHz - Channel A
  • 49.850 MHz - Channel B
  • 49.865 MHz - Channel C
Or,
  • 49.890 MHz - Channel C
  • 49.835 MHz - Channel 1/A
  • 49.860 MHz - Channel 2/B
  • 49.885 MHz - Channel 3/C
PLACEHOLDER
Low power operations within the FM broadcast band.
PLACEHOLDER
15.242 - Operation in the bands 174-216 MHz and 470-668 MHz.
15.243 - Operation in the band 890-940 MHz.
  • 2435 MHz - 2465 MHz - 500 millivolts/meter at 3 meters
  • 5785 MHz - 5815 MHz - 500 millivolts/meter at 3 meters
  • 10500 MHz - 10550 MHz - 2500 millivolts/meter at 3 meters
  • 24075 MHz - 24175 MHz - 2500 millivolts/meter at 3 meters
(a) Operation under the provisions of this Section is limited to frequency hopping and digitally modulated intentional radiators that comply with the following provisions:
  • 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters
  • 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters
  • 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters
  • 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters
