Militia Radio Frequencies
Revision as of 18:55, 21 April 2022 by R4002 (Talk | contribs)
UHF (FRS) is preferred for short-range tactical nets, while VHF (MURS) and CB frequencies are preferred for command nets and vehicle to vehicle communications. Amateur frequencies should never be used by unlicensed personnel or radio operators. See also: Survivalist and Militia Patriot CB AM SSB Frequencies 26-28 MHz 27 MHz 11m band frequency plan.
  • Channel 9 - 467.5875 MHz - FRS 9 - Tac, Calling/Mutual Aid
  • Channel 13 - 467.6875 MHz - FRS 13 - Tac
  • Channel 19 - 462.6500 MHz - FRS 19 - Tac, Calling/Mutual Aid
  • Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
  • Channel 34 - 154.5700 MHz - MURS 4 - Command Blue or Tac/Ops (alternate to MURS 1 and MURS 3)
  • Channel 35 - 154.6000 MHz - MURS 5 - Command Green or Tac/Ops (alternate to MURS 1 and MURS 3)
  • MURS 1 - 151.8200 MHz - 88.5 Hz CALL
  • MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
  • MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
  • MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
  • MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
Simplified MURS / FRS tactical programming - Radio settings: WN: NARR ROGER: OFF ANI: OFF RP-STE: OFF STE: OFF TOT: 30 T-CTCS: 88.5Hz R-CTCS: OFF T-DCS: OFF R-DCS: OFF
  • Channel - FUTURE SECTION FOR SIMPLIFIED PLAN
  • Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 - display channel name: MURS 3 CALL - high power setting
  • Channel 123 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 1 HP - high power setting
  • Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 2 HP - high power setting
  • Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3 HP - high power setting
  • Channel 126 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4 HP - high power setting
  • Channel 127 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5 HP - high power setting
Militia Radio Programming Plan Militia Patriot Handheld Tactical Intra Squad Radio Frequencies Channels UHF Only 16-Channel Intra-Squad Radio Channel Chart Inter-Squad Radio Frequencies Channel List
RECOMMENDED MILITIA PATRIOT ISR INTRA SQUAD INTER-SQUAD INTRA SQUAD RADIO 16 CHANNEL RADIO BF888S MILITIA PROGRAMMING LIST'
Ideal for low power (under 5 watt, ideally in the 0.5 to 2 watt range) short-range communications using dedicated 16 channel UHF handhelds. These radios are very inexpensive, can easily be programmed with CHIRP and since there are only 16 channels, these channels can also be added to your standard VHF/UHF tactical radio of choice's programming plan for communications between the intra squad radio frequencies (intra-squad radio, ISR) and the standard Baofeng militia radios.
  • Channel 01 - 467.8375 MHz - 159.8 Hz CTCSS - ISR01 - 467.83750 NFM 159.8 TSQL
  • Channel 02 - 469.5125 MHz - 159.8 Hz CTCSS - ISR02 - 469.51250 NFM 159.8 TSQL
  • Channel 03 - 456.3375 MHz - 189.9 Hz CTCSS - ISR03 - 456.33750 NFM 189.9 TSQL
  • Channel 04 - 456.4375 MHz - 189.9 Hz CTCSS - ISR04 - 456.43750 NFM 189.9 TSQL
  • Channel 05 - 467.8625 MHz - 165.5 Hz CTCSS - ISR05 - 467.86250 NFM 165.5 TSQL
  • Channel 06 - 467.8875 MHz - 165.5 Hz CTCSS - ISR06 - 467.88750 NFM 165.5 TSQL
  • Channel 07 - 462.7875 MHz - 254.1 Hz CTCSS - ISR07 - 462.78750 NFM 254.1 TSQL
  • Channel 08 - 462.8875 MHz - 254.1 Hz CTCSS - ISR08 - 462.88750 NFM 254.1 TSQL
  • Channel 09 - 462.8375 MHz - 254.1 Hz CTCSS - ISR09 - 462.83750 NFM 254.1 TSQL
  • Channel 10 - 469.5625 MHz - 159.8 Hz CTCSS - ISR10 - 469.56250 NFM 159.8 TSQL
  • Channel 11 - 457.6625 MHz - 189.9 Hz CTCSS - ISR11 - 457.66250 NFM 189.9 TSQL
  • Channel 12 - 452.1875 MHz - 171.3 Hz CTCSS - ISR12 - 452.18750 NFM 171.3 TSQL
  • Channel 13 - 451.4375 MHz - 177.3 Hz CTCSS - ISR13 - 451.43750 NFM 177.3 TSQL
  • Channel 14 - 457.7125 MHz - 165.5 Hz CTCSS - ISR14 - 457.71250 NFM 165.5 TQSL
  • Channel 15 - 451.3375 MHz - 177.3 Hz CTCSS - ISR15 - 451.33750 NFM 177.3 TSQL
  • Channel 16 - 467.8000 MHz - 254.1 Hz CTCSS - ISR16 - 467.80000 NFM 251.1 TSQL
The 16 channel version above is designed for 16 channel handheld radios discussed below. Extended versions (using sets of 16 channels) are also possible.
  • FRS Channels 1-16 (allows simple interoperability with standard FRS radios and standard militia programmed radios). Tone mode should be set to Tone (not TSQL - unless you are programming radios for a group/unit/team/squad/crew specific channel plan - see links and general information above and example programming plans below).
  • Channel 01 - 462.5625 MHz [transmit Tone 67.0 Hz] - FRS Channel 1
  • Channel 02 - 462.5875 MHz [transmit Tone 118.8 Hz] - FRS Channel 2
  • Channel 03 - 462.6125 MHz [transmit Tone 127.3 Hz] - FRS Channel 3
  • Channel 04 - 462.6375 MHz [transmit Tone 131.8 Hz] - FRS Channel 4
  • Channel 05 - 462.6625 MHz [transmit Tone 136.5 Hz] - FRS Channel 5
  • Channel 06 - 462.6875 MHz [transmit Tone 141.3 Hz] - FRS Channel 6
  • Channel 07 - 462.7125 MHz [transmit Tone 146.2 Hz] - FRS Channel 7
  • Channel 08 - 467.5625 MHz [transmit Tone 88.5 Hz] - FRS Channel 8
  • Channel 09 - 467.5875 MHz [transmit Tone 88.5 Hz] - FRS Channel 9
  • Channel 10 - 467.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 10
  • Channel 11 - 467.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 11
  • Channel 12 - 467.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 12
  • Channel 13 - 467.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 13
  • Channel 14 - 467.7125 MHz [transmit Tone 88.5 Hz] - FRS Channel 14
  • Channel 15 - 462.5500 MHz [transmit Tone 88.5 Hz] - FRS Channel 15
  • Channel 16 - 462.5750 MHz [transmit Tone 88.5 Hz] - FRS Channel 16
  • FRS Calling/Tactical Channels (16 channel programming):
  • Channel 01 - 462.5625 MHz [transmit Tone 67.0 Hz] - FRS Channel 1 - FRS Nationwide Calling
  • Channel 02 - 462.5875 MHz [transmit Tone 88.5 Hz] - FRS Channel 2 - Tactical
  • Channel 03 - 462.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 3 - Patriot/Militia Calling
  • Channel 04 - 462.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 4 - Convoy Tac/Operations
  • Channel 05 - 462.5750 MHz [transmit Tone 88.5 Hz] - FRS Channel 16 - Convoy Tactical/Operations
  • Channel 06 - 462.6750 MHz [transmit Tone 141.3 Hz] - FRS Channel 20 - GMRS Nationwide Calling
  • Channel 07 - 462.6000 MHz [transmit Tone 88.5 Hz] - FRS Channel 17 - Patriot Militia Ops Tactical
  • Channel 08 - 462.6250 MHz [transmit Tone 88.5 Hz] - FRS Channel 18 - Tactical
  • Channel 09 - 462.6500 MHz [transmit Tone 88.5 Hz] - FRS Channel 19 - Tac, Calling/Mutual Aid
  • Channel 10 - 467.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 10 - Tactical
  • Channel 11 - 467.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 11 - Tactical
  • Channel 12 - 467.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 12 - Tactical
  • Channel 13 - 467.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 13 - Tactical
  • Channel 14 - 467.7125 MHz [transmit Tone 88.5 Hz] - FRS Channel 14 - Tactical
  • Channel 15 - 462.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 5 - Tactical
  • Channel 16 - 462.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 6 - Tactical
  • Example 16-channel intra squad radio inter squad radio plan - using FRS frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans using FRS frequencies - see the full list here.
  • Channel 01 - 467.6625 MHz - 171.3 Hz CTCSS FRS Channel 12
  • Channel 02 - 467.5625 MHz - 165.5 Hz CTCSS FRS Channel 8
  • Channel 03 - 467.6375 MHz - 171.3 Hz CTCSS FRS Channel 11
  • Channel 04 - 462.7000 MHz - 210.7 Hz CTCSS FRS Channel 21
  • Channel 05 - 467.7125 MHz - 165.5 Hz CTCSS FRS Channel 14
  • Channel 06 - 462.6000 MHz - 210.7 Hz CTCSS FRS Channel 17
  • Channel 07 - 462.6500 MHz - 210.7 Hz CTCSS FRS Channel 19
  • Channel 08 - 467.6125 MHz - 171.3 Hz CTCSS FRS Channel 10
  • Channel 09 - 467.5875 MHz - 199.5 Hz CTCSS FRS Channel 9
  • Channel 10 - 462.5750 MHz - 210.7 Hz CTCSS FRS Channel 16
  • Channel 11 - 462.6750 MHz - 210.7 Hz CTCSS FRS Channel 20
  • Channel 12 - 462.5500 MHz - 210.7 Hz CTCSS FRS Channel 15
  • Channel 13 - 462.5875 MHz - 229.1 Hz CTCSS FRS Channel 2
  • Channel 14 - 462.6875 MHz - 229.1 Hz CTCSS FRS Channel 6
  • Channel 15 - 462.6125 MHz - 225.7 Hz CTCSS FRS Channel 3
  • Channel 16 - 462.7125 MHz - 233.6 Hz CTCSS FRS Channel 7
  • Example 16-channel intra squad radio inter squad radio plan - using business frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans - see the full list here.
The most commonly used frequencies are 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.900 MHz, 467.875 MHz, 467.850 MHz, 467.8125 MHz, 467.7625 MHz, 469.550 MHz, 469.500 MHz, 451.800 MHz, 456.800 MHz, 451.8125 MHz, 456.8125 MHz, 461.0375 MHz, 461.0625 MHz, and 461.0875 MHz. Avoid using those frequencies if at all possible and monitor the particular frequency use in your area.
Channel Assignments Frequency Requirements For Teams Squads Platoons etc.
  • Tactical Channels - common frequencies/channels for liaison between friendly forces - must be agreed upon ahead of time. Tactical channels overlap with intra squad radio channels for obvious reasons. For tactical purposes, moving off the designated calling/mutual aid channels is a good idea...and is another reason why having multiple calling/mutual aid channels is a good idea...it allows primary tactical ops to be moved to a secondary mutual aid channel - thus clearing the main calling channel for other friendly forces to use.
In urban areas, UHF (FRS) is the best choice for this, but VHF (MURS) will work as well. In less built-up areas, either will work. Multiple tactical channels should be available for teams to be able to switch to as the situation dictates.
  • Calling, Monitor and Mutual Aid Channels - common frequencies/channels for liaison between friendly forces (similar to tactical channels in many respects) - these include FRS channel 3 (462.6125 MHz), MURS channel 3 (151.940 MHz) and others. As with the tactical channels, mutual aid channels should be determined ahead of time.
  • Command Channel - Larger formations may wish to have a dedicated command channel, perhaps with a designated alternate (backup) channel. In many situations, this is not needed and actually adds more complexity and confusion.
