MURS
Multi Use Radio Service
Were you looking for militia tactical radio channel plans? (MURS is an important part).
MURS Frequencies / Channels:
| MURS Channel 2 | MURS-2 | 151.880 MHz | 11.25 kHz | Recommended simplex repeater/crossband repeater channel (156.7 Hz CTCSS tone) and SAFETY channel - TX 210.7 Hz CTCSS 210.7 PL |
| MURS Channel 3 | MURS-3 | 151.940 MHz | 11.25 kHz | Recommended prepper/emergency management/disaster response calling/working channel - TX 88.5 Hz CTCSS or 141.3 Hz CTCSS 141.3 PL |
- Are the "color dot" frequencies license free or part of MURS? Yes and no. Only the Blue Dot (154.57 MHz) and Green Dot (154.6 MHz) channels are license free and part of MURS. The other color dot frequencies, star frequencies, etc. require FCC Part 90 Business Radio licenses to operate on. You must have a license to use 151.625 MHz, 151.955 MHz, 467.925 MHz, 467.850 MHz, 467.7625 MHz, 464.500 MHz and 464.550 MHz, for example.
- Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be good to go. Make sure to use narrowband mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market.
- Are MURS channels part of the CB radio service? Legally and technically, yes. MURS is included under Part 95 of the FCC rules, as an unlicensed Personal Radio Service. Like CB, and FRS, MURS is designed as a short range voice and data radio service for personal, family, business and any other use by members of the public. MURS is not designed for public safety purposes.
- Can you transmit voice modes other than regular FM on MURS? Yes, you can transmit analog voice in FM mode, AM mode or digital voice in any DV mode that meets the bandwidth requirements for the MURS frequencies. This includes DMR, DPMR, TRBO, C4FM, MotoTRBO, IDAS, NEXEDGE, NXDN, D-STAR, Project 25/P25/APCO-25 digital voice, etc. Mixed voice and data, including TDMA DMR 2-slot DMR as well as TDMA and FDMA P25 are also permitted.
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Retevis RT-27V MURS VHF
Despite their age, the Motorola CP110M series, Motorola RMM2050 and RDM2070D are still very popular jobsite radios. The RMM and RDM radios should not be confused with the Motorola RDV. RMV, RMU or RDU series radios (which require licenses to use).
- 151.820 MHz (Output) 154.600 MHz (Input) - San Francisco area "MURS 82-60" or "MURSR" - MURS channel 1 output, MURS channel 5 repeater input +2.780 MHz offset (program RX 151.8200 MHz, TX 154.6000 MHz) - unknown CTCSS or PL tone
- 151.880 MHz MURS Channel 2 151.88 MHz 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 Hz CTCSS. The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
- 151.940 MHz MURS Channel 3 151.94 MHz 103.5 Hz CTCSS/PL - Oregon (additional information unconfirmed)
- 151.940 MHz MURS Channel 3 151.94 MHz 156.7 Hz CTCSS/PL - Sacramento, CA area
