Part 15
(a) The field strength of any emission within this band shall not exceed 10,000
microvolts/meter at 3 meters. The emission limit in this paragraph is
based on measurement instrumentation employing an average detector.
The provisions in 15.35 for limiting peak emissions apply.
RC frequencies:
- 26.995 MHz
- 27.045 MHz
- 27.095 MHz
- 27.145 MHz
- 27.195 MHz
- 27.255 MHz
- 49.850 MHz - Channel 2
- 49.870 MHz - Channel 3
- 49.890 MHz - Channel 4
- 49.875 MHZ - Channel 4
- 49.850 MHz - Channel 1A
- 49.870 MHz - Channel 2A
- 49.830 MHz - Channel 1B
- 49.890 MHz - Channel 2B
- 49.845 MHz - Channel X
- 49.875 MHz - Channel Y
Or,
- 49.830 MHz - Channel A
- 49.860 MHz - Channel B
Or,
- 49.845 MHz - Channel A
- 49.890 MHz - Channel B
Or,
- 49.840 MHz - Channel A
- 49.870 MHz - Channel B
Or,
- 49.850 MHz - Channel I
- 49.870 MHz - Channel II
Or,
- 49.825 MHz - Channel 1
Or,
- 49.870 MHz - Channel 1
Or,
- 49.840 MHz - Channel 1
- 49.860 MHz - Channel 2
Or,
- 49.8425 MHz - Channel 1 (49.842 MHz or 49.843 MHz offset)
- 49.8625 MHz - Channel 2 (49.862 MHz or 49.863 MHz offset)
Or,
- 49.885 MHz - Channel B
Or,
- 49.875 MHz - Channel B
Or,
- 49.876 MHz - Channel B (specifically designed to operate off-frequency from 49.875 MHz - 49.876 MHz per FCC ID documentation)
Or,
- 49.850 MHz - Channel X
- 49.880 MHz - Channel Y
- 49.870 MHz - Channel A (actually closer to 49.885 MHz, 49.8875 MHz, 49.888 MHz or 49.890 MHz)
- 49.810 MHz - Channel B - actual center frequency 49.8225 MHz (49.820 MHz or 49.825 MHz on 5 kHz step receivers)
- 49.870 MHz - Channel 4
- 49.880 MHz - Channel 5
- 49.890 MHz - Channel 6
- 49.835 MHz - Channel A
- 49.850 MHz - Channel B
- 49.865 MHz - Channel C
Or,
- 49.890 MHz - Channel C
- 49.835 MHz - Channel 1/A
- 49.860 MHz - Channel 2/B
- 49.885 MHz - Channel 3/C
§ 15.235 Operation within the band
49.82–49.90 MHz.
The provisions in §15.35 for limiting
(b) The field strength of any emissions appearing between the band edges
and up to 10 kHz above and below the
band edges shall be attenuated at least
26 dB below the level of the
unmodulated carrier or to the general
limits in §15.209, whichever permits the
higher emission levels. The field
strength of any emissions removed by
more than 10 kHz from the band edges
emission limits in §15.209. All signals
exceeding 20 microvolts/meter at 3 meters shall be reported in the application for certification.
(c) For a home-built intentional radiator, as defined in §15.23(a), operating
within the band 49.82–49.90 MHz, the
following standards may be employed:
(1) The RF carrier and modulation
products shall be maintained within
the band 49.82–49.90 MHz.
(2) The total input power to the device measured at the battery or the
power line terminals shall not exceed
100 milliwatts under any condition of
modulation.
(3) The antenna shall be a single element, one meter or less in length, permanently mounted on the enclosure
containing the device.
(4) Emissions outside of this band
(5) The regulations contained in
§15.23 of this part apply to intentional
radiators constructed under the provisions of this paragraph.
(d) Cordless telephones are not permitted to operate under the provisions
of this section.
- 902 MHz - 928 MHz - 500 millivolts/meter at 3 meters
- 2435 MHz - 2465 MHz - 500 millivolts/meter at 3 meters - 2.435 GHz - 2.465 GHz
- 5785 MHz - 5815 MHz - 500 millivolts/meter at 3 meters - 5.785 GHz - 5.815 GHz
- 10500 MHz - 10550 MHz - 2500 millivolts/meter at 3 meters - 10.5 GHz - 10.55 GHz
- 24075 MHz - 24175 MHz - 2500 millivolts/meter at 3 meters - 24.075 GHz - 24.175 GHz
See also: ISM, cordless phone systems (900 MHz band, 2.4 GHz band and 5.8 GHz band digital cordless phones may operate under 15.247. Wireless intercoms, full duplex headset comms systems, long-range telemetry, non Part 95 remote control, datalink, video backhaul systems for UAV systems, drones, etc.). Line of sight (air to ground) radio links on 900 MHz are capable of very long range, often 40 km or more.
- 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
- 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
- 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
- 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters or 250mV/m at 3 meters (250,000 microvolts/meter at 3 meters)
(b) [Reserved]
