VHF low band VHF-low
VHF high band VHF band
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
700 MHz band
800 MHz band
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 808.5125 MHz) both with 156.7 Hz CTCSS
- 853.4875 MHz - old 800 MHz itinerant channel, may be used for simplex, tactical or talkaround purposes.
UHF band
- Law Enforcement Plan
- LE A Calling - 167.0875 MHz
- LE B Calling - 414.0375 MHz
- LE 01 Tactical - 162.0875 MHz
- LE 02 Tactical - 162.2625 MHz
- LE 03 Tactical - 162.8375 MHz
- LE 04 Tactical - 163.2875 MHz
- LE 05 Tactical - 163.4250 MHz
- LE 06 Tactical - 167.2500 MHz
- LE 07 Tactical - 167.7500 MHz
- LE 08 Tactical - 168.1125 MHz
- LE 09 Tactical - 168.4625 MHz
- LE 10 Tactical - 418.9875 MHz
- LE 11 Tactical - 419.1875 MHz
- LE 12 Tactical - 419.6125 MHz
- LE 13 Tactical - 414.0625 MHz
- LE 14 Tactical - 414.3125 MHz
- LE 15 Tactical - 414.3375 MHz
- LE 16 Tactical - 409.9875 MHz
- LE 17 Tactical - 410.1875 MHz
- LE 18 Tactical - 410.6125 MHz
- Incident Response Plan
- NC 1 Calling - 164.7125 MHz
- NC 2 Calling - 419.2375 MHz
- IR 01 - 165.2500 MHz
- IR 02 - 165.9625 MHz
- IR 03 - 166.5750 MHz
- IR 04 - 167.3250 MHz
- IR 05 - 169.5375 MHz
- IR 06 - 170.0125 MHz
- IR 07 - 170.4125 MHz
- IR 08 - 170.6875 MHz
- IR 09 - 173.0375 MHz
- IR 10 - 419.4375 MHz
- IR 11 - 419.6375 MHz
- IR 12 - 419.8375 MHz
- IR 13 - 413.1875 MHz
- IR 14 - 413.2125 MHz
- IR 15 - 410.2375 MHz
- IR 16 - 410.4375 MHz
- IR 17 - 410.6375 MHz
- IR 18 - 410.8375 MHz
- 5680 kHz - USB voice - SAR operations
- 8364 kHz - USB voice - SAR operations
- 40.5000 MHz - FM Guard - FM SINCGARS military emergency use only - Fox Guard or Fox Mike Guard 40.5 MHz
- 121.5000 MHz - VHF Guard - VHF aircraft emergency use only - Victor Guard 121.5 MHz
- 243.0000 MHz - UHF Guard - UHF aircraft emergency use only - Uniform Guard 243.0 MHz
- 853.0125 MHz - 8TAC94D - SAR Command interop simplex - 156.7 Hz CTCSS
The VHF aircraft band frequencies are in AM mode. The VHF and UHF land mobile frequencies are regular NFM mode. See remarks above regarding CTCSS tones. The A/G air/ground air to ground VHF FM frequencies are assigned on a local/regional basis. These frequencies may be used for other purposes outside their assigned GACC - Geographic Area Coordination Center. In addition to region-specific air-to-ground VHF FM frequencies, specific VHF-AM aircraft - "Victor" - frequencies are assigned to bases - 123.925 MHz, 123.975 MHz and several others are used.
- 168.6250 MHz - Nationwide AIR GUARD - Must be included for emergency air-to-ground communications - 110.9 Hz CTCSS required
- 168.6500 MHz - Nationwide Flight Following - National Flight Following frequency, interagency aircraft contact - 110.9 Hz CTCSS required
- 170.9750 MHz - Command Repeater 1
- 170.4500 MHz - Command Repeater 2
- 170.4250 MHz - Command Repeater 3
- 170.0000 MHz - Command Repeater 4
- 169.7500 MHz - Command Repeater 5
- 173.8125 MHz - Command Repeater 6
- 168.7000 MHz - Command Simplex 1
- 168.1000 MHz - Command Simplex 2
- 168.0750 MHz - Command Simplex 3
- 166.6750 MHz - Command Simplex 4
- 167.1000 MHz - Command Simplex 5
- 168.4750 MHz - Command Simplex 6
- 166.6125 MHz - Air Tactics 1
- 169.1500 MHz - Air Tactics 2
- 169.2000 MHz - Air Tactics 3
- 168.4000 MHz - Air Tactics 4
- 167.9500 MHz - Air Tactics 5
- 168.0500 MHz - Tactical 1
- 168.2000 MHz - Tactical 2
- 168.6000 MHz - Tactical 3
- 166.7250 MHz - Tactical 4
- 166.7750 MHz - Tactical 5
- 168.2500 MHz - Tactical 6
- 163.7125 MHz - Intra-Crew Base and Travel Net - Nationwide Mobilization - Handheld Portable Radios Only - NFM or P25 digital
- 167.1375 MHz - Primary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
- 168.6125 MHz - Secondary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
- 173.6250 MHz - Tertiary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
- 168.3500 MHz - Government Wide Tactical/Simplex
- 163.1000 MHz - Government Wide Tactical/Simplex
- 163.7125 MHz - Government Wide Tactical Simplex
- 167.1375 MHz - Government Wide Tactical Simplex
- 168.6125 MHz - Government Wide Tactical Simplex
- 173.6250 MHz - Government Wide Tactical Simplex
- 168.3500 MHz - Government Wide Tactical Repeater (163.1000 MHz input) - Portable Repeaters
- 122.9250 MHz - Air A1 - Multicom - Natural Resources Aircraft
- 122.9000 MHz - Air A2 - Multicom
- 122.8500 MHz - Air A3 - Multicom
- 122.7500 MHz - Air A4 - Fixed Wing Aircraft Air to Air
- 123.0250 MHz - Air A5 - Helicopter Aircraft Air to Air
- 406.4000 MHz - Logistics 1 (Repeater or simplex)
- 406.5875 MHz - Logistics 2 (Repeater or simplex)
- 407.7875 MHz - Logistics 3 (Repeater or simplex)
- 410.2750 MHz - Logistics 4 (Repeater or simplex)
- 410.7750 MHz - Logistics 5 (Repeater or simplex)
- 408.6875 MHz - Logistics 6 (Repeater or simplex)
- 408.5000 MHz - Logistics 7 (Repeater or simplex)
- 411.4000 MHz - Logistics 8/ UHF Special Use 1 Simplex
- 412.2250 MHz - Logistics 9/ UHF Special Use 2 Simplex
Oil Spill Cleanup
