VHF LADD
VHF LADD (Logging Administration Dispatch), LD (Loading Channels) RR ([[Resource Road]] or Road Resource) channels, standardized for trucking, logging and use in remote areas for truck-to-truck, truck-to-base and emergency services communications with trucks, loading channels, etc. These frequencies are known by several names, including the Ice Road Channels, Ice Road Truckers Frequencies, Loading Channels, LD channels LAD channels, LADD channels, Resource Road channels, Logging common channels, Natural Resource Road Channels Resource Road VHF, VHF trucking channels, Canadian trucking channels and several other combinations of these. In remote areas of Canada, specific sections of roads are assigned specific channels.
Note that use of 27 MHz CB radio equipment (called the General Radio Service in Canada - not to be confused with the General Mobile Radio Service or GMRS) is still a de facto requirement for trucking and use of CB equipment is strongly recommended.
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth or 16K0F3E emission) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth - also known as 11K3F3E emission, 11K2F3E emission or 11K0F3E emission). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
| Channel | Frequency | Remarks/Usage |
| LADD 1 | 154.100 MHz | LADD channel 1 - trucking and logging companies, natural resource agencies |
| LADD 2 | 158.940 MHz | LADD channel 2 - trucking and logging companies, natural resource agencies |
| LADD 3 | 154.325 MHz | LADD channel 3 - trucking and logging companies, natural resource agencies |
| LADD 4 | 173.370 MHz | LADD channel 4 - trucking and logging companies, natural resource agencies |
| LD-1 | 151.700 MHz | Loading Channel 1 |
| LD-2 | 151.745 MHz | Loading Channel 2 |
| LD-3 | 151.790 MHz | Loading Channel 3 |
| LD-4 | 151.805 MHz | Loading Channel 4 |
| LD-5 | 151.850 MHz | Loading Channel 5 |
| LD-6 | 150.485 MHz | Loading Channel 6 |
| LD-7 | 153.215 MHz | Loading Channel 7 |
| LD-8 | 154.665 MHz | Loading Channel 8 |
| LD-9 | 152.330 MHz | Loading Channel 9 |
| LD-10 | 153.635 MHz | Loading Channel 10 |
| LD-11 | 157.590 MHz | Loading Channel 11 |
| LD-12 | 159.750 MHz | Loading Channel 12 |
| LD-13 | 164.010 MHz | Loading Channel 13 |
| LD-14 | 165.960 MHz | Loading Channel 14 |
| RR-01 | 150.080 MHz | Resource Road channel 1 |
| RR-02 | 150.110 MHz | Resource Road channel 2 |
| RR-03 | 150.140 MHz | Resource Road channel 3 |
| RR-04 | 150.185 MHz | Resource Road channel 4 |
| RR-05 | 150.200 MHz | Resource Road channel 5 |
| RR-06 | 150.245 MHz | Resource Road channel 6 |
| RR-07 | 150.260 MHz | Resource Road channel 7 |
| RR-08 | 150.320 MHz | Resource Road channel 8 |
| RR-09 | 150.365 MHz | Resource Road channel 9 |
| RR-10 | 150.410 MHz | Resource Road channel 10 |
| RR-11 | 150.440 MHz | Resource Road channel 11 |
| RR-12 | 150.500 MHz | Resource Road channel 12 |
| RR-13 | 150.530 MHz | Resource Road channel 13 |
| RR-14 | 150.545 MHz | Resource Road channel 14 |
| RR-15 | 150.560 MHz | Resource Road channel 15 |
| RR-16 | 150.590 MHz | Resource Road channel 16 |
| RR-17 | 150.680 MHz | Resource Road channel 17 |
| RR-18 | 150.710 MHz | Resource Road channel 18 |
| RR-19 | 150.770 MHz | Resource Road channel 19 |
| RR-20 | 150.830 MHz | Resource Road channel 20 |
| RR-21 | 151.010 MHz | Resource Road channel 21 |
| RR-22 | 151.130 MHz | Resource Road channel 22 |
| RR-23 | 151.190 MHz | Resource Road channel 23 |
| RR-24 | 151.220 MHz | Resource Road channel 24 |
| RR-25 | 151.310 MHz | Resource Road channel 25 |
| RR-26 | 151.340 MHz | Resource Road channel 26 |
| RR-27 | 151.370 MHz | Resource Road channel 27 |
| RR-28 | 151.430 MHz | Resource Road channel 28 |
| RR-29 | 151.460 MHz | Resource Road channel 29 |
| RR-30 | 151.490 MHz | Resource Road channel 30 |
| RR-31 | 151.520 MHz | Resource Road channel 31 |
| RR-32 | 151.580 MHz | Resource Road channel 32 |
| RR-33 | 151.610 MHz | Resource Road channel 33 |
| RR-34 | 151.640 MHz | Resource Road channel 34 |
| RR-35 | 151.670 MHz | Resource Road channel 35 |
Channel Use Location Information Official Resource Road Channel Allocations
See this official list of Natural Resource Roads LADD LD RR Resource Road VHF Radio Channel Frequency Channel Location Use Maps - kilometer signs with call-in channels are listed on the roads where use of these frequencies are required (link below).
