FM
No static at all.
Frequency Modulation
It is rarely used on HF frequencies, with some exceptions - land mobile systems operating in the 25-30 MHz region and the 27 MHz 11 meter CB operators in many countries - often in conjunction with AM and SSB, amateur radio operators using the FM in the 10 meter band, land mobile radio users operating on a small number of channelized frequencies in the 25 to 30 MHz range and some specialized maritime mobile (marine radio) systems used by fishing fleets, fishery radio networks, etc. In military contexts, "FM" is used to refer to the VHF-FM combat net radio / tactical radio systems operating in the (roughly) 30-88 MHz range, e.g. SINCGARS.
