Radio propagation beacon
A radio propagation beacon is a radio beacon, whose purpose is the investigation of the propagation of radio signals. Most radio propagation beacons use amateur radio frequencies. They can be found on HF, VHF, UHF, and microwave frequencies. Microwave beacons are also used as signal sources to test and calibrate antennas and receivers.<ref>Template:Cite journal The article includes the following definition for beacons licensed in the Amateur Radio service: A station in the Amateur Service or Amateur Satellite Service that autonomously transmits in a fixed format, which may include repeated data or information, for the study of propagation, determination of frequency or bearing, or for other experimental purposes.</ref><ref>Template:Cite journal</ref>
Transmission characteristics
Most beacons operate in continuous wave (A1A) and transmit their identification (call sign and location). Some of them send long dashes to facilitate signal strength measurement. A small number of beacons transmit Morse code by frequency shift keying (F1A). A few beacons transmit signals in digital modulation modes, like radioteletype (F1B) and PSK31 (G1B).
160 meters beacons
The International Amateur Radio Union Region 2 (North and South America) bandplan reserves the range 1999 kHz to 2000 kHz for propagation beacons.
10 meters beacons
Most high frequency radio propagation beacons are found in the 10 meters (28 MHz) frequency band, where they are good indicators of Sporadic E ionospheric propagation. According to IARU bandplans, the following 28 MHz frequencies are allocated to radio propagation beacons:
| R1 |
| R2<ref>New IARU Region 2 bandplan introduced in January 2008</ref> |
| R3 |
6 meters beacons
In the 6 meters (50 MHz) band, beacons operate in the lower part of the band, in the range 50000 kHz to 50080 kHz. The American Radio Relay League bandplan recommends 50060 to 50080 kHz for beacons in the United States. Due to unpredictable and intermittent long distance propagation, usually achieved by a combination of ionospheric conditions, beacons are very important in providing early warning for 50 MHz openings.
VHF/UHF beacons
Beacons on 144 MHz and higher frequencies are mainly used to identify tropospheric radio propagation openings. It is not uncommon for VHF and UHF beacons to use directional antennas. Frequency allocations for beacons on VHF and UHF bands vary widely in different IARU regions and countries. The current allocation in the United Kingdom, which also reflects IARU Region 1 recommendations, is the following:<ref>Template:Cite web</ref>
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
Beacon projects
IARU Beacon Project
The International Beacon Project (IBP), which is coordinated by the Northern California DX Foundation and the International Amateur Radio Union, consists of 18 HF propagation beacons worldwide, which transmit in turns on 14100 kHz, 18110 kHz, 21150 kHz, 24930 kHz, and 28200 kHz.<ref name="ncdxf">Template:Cite web</ref>
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, Template:Coor Maidenhead) and at Darwin, Australia (callsign VL8IPS, Template:Coor Maidenhead). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.<ref name="ham_radio_nl">Template:Cite web</ref>. Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed.<ref name="itu">Template:Cite web</ref>
DARC beacon project
The Deutscher Amateur-Radio-Club sponsors two beacons which transmit from Scheggerott, near Kiel (Template:Coor Maidenhead).<ref>Template:Cite web</ref> These beacons are DRA5 on 5195 kHz and DK0WCY on 10144 kHz. In addition to identification and location, every 10 minutes these beacons transmit solar and geomagnetic bulletins. Transmissions are in Morse code for aural reception, RTTY and PSK31.<ref>Template:Cite book</ref> DK0WCY operates also a limited service beacon on 3579 kHz at 0720-0900 and 1600-1900 local time.
RSGB 5 MHz beacon project
The Radio Society of Great Britain operates three radio propagation beacons on 5290 kHz, which transmit in sequence, for one minute each, every 15 minutes. The project includes GB3RAL near Didcot (Template:Coor Maidenhead), GB3WES in Cumbria (Template:Coor Maidenhead) and GB3ORK in the Orkney Islands (Template:Coor Maidenhead). GB3RAL, which is located at the Rutherford-Appleton Laboratory, also transmits continuously on 28215 kHz and on a number of low VHF frequencies (40050, 50053, 60053 and 70053 kHz).<ref>Template:Cite journal</ref>
Notes and references
