Radio propagation beacon
Transmission characteristics
160 meters beacons
10 meters beacons
R1 |
R2[3] |
R3 |
6 meters beacons
VHF/UHF beacons
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, Template:Coor Maidenhead) and at Darwin, Australia (callsign VL8IPS, Template:Coor Maidenhead). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.[6] Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. [7]
DARC beacon project
The Deutscher Amateur-Radio-Club sponsors two beacons which transmit from Scheggerott, near Kiel (Template:Coor Maidenhead). [8] These beacons are DRA5 on 5195 kHz and DK0WCY on 10144 kHz. In addition to identification and location, every 10 minutes these beacons transmit solar and geomagnetic bulletins. Transmissions are in Morse code for aural reception, RTTY and PSK31. [9] DK0WCY operates also a limited service beacon on 3579 kHz at 0720-0900 and 1600-1900 local time.
RSGB 5 MHz beacon project
The Radio Society of Great Britain operates three radio propagation beacons on 5290 kHz, which transmit in sequence, for one minute each, every 15 minutes. The project includes GB3RAL near Didcot (Template:Coor Maidenhead), GB3WES in Cumbria (Template:Coor Maidenhead) and GB3ORK in the Orkney Islands (Template:Coor Maidenhead). GB3RAL, which is located at the Rutherford-Appleton Laboratory, also transmits continuously on 28215 kHz and on a number of low VHF frequencies (40050, 50053, 60053 and 70053 kHz).[10]
Notes and references
- HF 0-20 MHz beacons
