Radio propagation beacon
Revision as of 15:59, 8 August 2010 by Strange Attractor (Talk | contribs)
Transmission characteristics
160 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
6 meters beacons
VHF/UHF beacons
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
Beacon projects
IARU Beacon Project
url="http://www.darc.de"
The International Beacon Project (IBP), which is coordinated by the Northern California DX Foundation and the International Amateur Radio Union, consists of 18 HF propagation beacons worldwide, which transmit in turns on 14100 kHz, 18110 kHz, 21150 kHz, 24930 kHz, and 28200 kHz. [5]
Slot DXCC entity Call Location Latitude Longitude Grid Sq 14100 18110 21150 24930 28200
01 United Nations 4U1UN New York City 40º 45' N 73º 58' W FN3ØAS 00.00 00.10 00.20 00.30 00.40
02 Canada VE8AT Eureka, Nunavut 79º 59' N 85º 57' W EQ79AX 00.10 00.20 00.30 00.40 00.50
03 United States W6WX Mt. Umunhum 37º 09' N 121º 54' W CM97bd 00:20 00.30 00:40 00.50 01:00
04 Hawaii KH6WO Laie 21º 38' N 157º 55' W BL11ap 00.30 00.40 00.50 01.00 01.10
05 New Zealand ZL6B Masterton 41º 03' S 175º 36' E RE78tw
06 Australia VK6RBP Rolystone 32º 06' S 116º 03' E OF87av
07 Japan JA2IGY Mt. Asama 34º 27' N 136º 47' E PM84jk
08 Russia RR9O Novosibirsk 54º 59' N 82º 54' E NO14kx
09 Hong Kong VR2B Hong Kong 22º 16' N 114º 09' E OL72bg
10 Sri Lanka 4S7B Colombo 6º 6' N 80º 13' E NJ06cc
11 South Africa ZS6DN Pretoria 25º 54' S 28º 16' E KG44dc
12 Kenya 5Z4B Kariobangi 1º 15' S 36º 53' E KI88ks
13 Israel 4X6TU Tel Aviv 32º 03' N 34º 46' E KM72jb
14 Finland OH2B Lohja 60º 19' N 24º 50' E KP2Ø
15 Madeira CS3B Santo da Serra 32º 43' N 16º 48' W IM12or
16 Argentina LU4AA Buenos Aires 34º 37' S 58º 21' W GFØ5tj
17 Peru OA4B Lima 12º 04' S 76º 57' W FH17MW 02.40 02.50 00.00 00.10 00.20
18 Venezuela YV5B Caracas 10º 25' N 66º 51' W FK6ØNJ 02:50 00.00 00:10 00:20 00:30
The IARU/NDXF beacons transmit in turns on the five designated frequencies according to the following schedule, which repeats every 3 minutes:
Call 14100 18110 21150 24930 28200
4U1UN 00.00 00.10 00.20 00.30 00.40
VE8AT 00.10 00.20 00.30 00.40 00.50
W6WX 00:20 00.30 00:40 00.50 01:00
KH6WO 00.30 00.40 00.50 01.00 01.10
ZL6B 00.40 00.50 01.00 01.10 01.20
VK6RBP 00.50 01.00 01.10 01.20 01.30
JA2IGY 01.00 01.10 01.20 01.30 01.40
RR9O 01.10 01.20 01.30 01.40 01.50
VR2HK 01.20 01.30 01.40 01.50 02.00
4S7B 01.30 01.40 01.50 02.00 02.10
ZS6DN 01:40 01.50 02:00 02:10 02:20
5Z4B 01.50 02.00 02.10 02.20 02.30
4X6TU 02:00 02:10 02:20 02.30 02:40
OH2B 02:10 02:20 02:30 02:40 02:50
CS3B 02.20 02.30 02.40 02.50 00.00
LU4AA 02:30 02:40 02:50 00.00 00:10
OA4B 02.40 02.50 00.00 00.10 00.20
YV5B 02:50 00.00 00:10 00:20 00:30
ITU sponsored beacons
DARC beacon project
The Deutscher Amateur Radio Club (DARC) sponsors two beacons which transmit from Scheggerott, near Kiel (54.68750N - 9.791670E, JO44VQ). [8] These beacons are DRA5 on 5195 kHz and DK0WCY on 10144 kHz. In addition to identification and location, every 10 minutes these beacons transmit solar and geomagnetic bulletins. Transmissions are in Morse code for aural reception, RTTY and PSK31. [9] DK0WCY operates also a limited service beacon on 3579 kHz at 0720-0900 and 1600-1900 local time.
RSGB 5 MHz beacon project
Notes and references
  6. HF 0-20 MHz beacons
Wikipedia article: {{{1}}}
WP
