Radio beacon
A most basic aviation radio navigational aid is the NDB or Non-directional Beacon. These are simple low frequency and medium frequency transmitters and they are used to locate airways intersections, airports and to conduct instrument approaches, with the use of a radio direction finder located on the aircraft. The aviation NDBs, especially the ones marking airways intersections, are gradually decommissioned, as they are replaced with other navigational aids based on newer technologies. Due to relatively low purchase, maintenance and calibration cost, they are still used to mark locations of smaller aerodromes and important helicopter landing sites.
There are also marine beacons, based on the same techonlogy and installed at coastal areas, for use by ships at sea.(1) Most of them, especially in the western world, are no longer in service, while some have been converted to telemetry transmitters for differential GPS. Chains of radio navigation beacons for marine use are still active around the Russian and Ukrainian coastline.(2)
NDB technical
NDBs typically operate in the frequency range from 190 kHz to 535 kHz (although they are allocated frequencies from 190 to 1750 kHz) and transmit a carrier modulated by either 400 or 1020 Hz. NDBs can also be colocated with DME in a similar installation for the ILS as the outer marker, only in this case, they function as the inner marker. NDB owners are mostly governmental agencies and airport authorities.
Antennas have as part of their makeup a segment that consists of an inductor and a capacitor in series "tuned" to the particular frequency or frequencies assigned to that antenna. NDB's tuned segment is part of the antenna itself. What is viewed as the Vertical part of the antenna tends to be the supporting pylon for the capacitive element. At low frequencies the antenna itself is capacitive. (functions as the capacitor in the system). There is often a counterpoise (or bottom section of the capacitor) buried in the ground underneath the antenna. The inductive section is the feedline, and the vertical antenna element itself.
Monitoring NDBs
Besides their use in aircraft navigation, NDBs are also popular with DXers. Because NDBs are generally low-power (usually 25 watts), they normally cannot be heard over long distances, but favorable conditions in the ionosphere can allow NDB signals to travel much farther than normal. Because of this, radio DXers interested in picking up distant signals enjoy listening to faraway NDBs. Also, since the band allocated to NDBs is free of broadcast stations and their associated interference, and because most NDBs do little more than transmit their Morse Code callsign, they are very easy to identify, making NDB monitoring a very entertaining niche within the DXing hobby.
In North America, the NDB band is from 190 to 435 kHz and from 510 to 530 kHz. In Europe, there is a longwave broadcasting band from 150 to 280 kHz, so the European NDB band is from 280 kHz to 530 kHz with a gap between 495 and 505 kHz because 500 kHz was the international maritime distress (emergency) frequency.
The beacons that are between 510 kHz and 530 kHz can sometimes be heard on AM radios that can tune below the beginning of the AM broadcast band. (For example, the "HEH" beacon in Newark, Ohio at 524 kHz is within the bandwidth of most AM radios, and the "OS" beacon in Columbus, Ohio at 515 kHz can also be heard on some AM radios). Some beacons can also be heard on 530 kHz, although from the adjacent frequencies such as "LYQ" at 529 kHz in Manchester, Tennessee but for the most part, reception of NDBs requires a radio receiver that can receive frequencies below 530 kHz (the longwave band). Most so-called "shortwave" radios also include mediumwave and longwave, and they can usually receive all frequencies from 150 kHz to 30 MHz, which makes them ideal for listening to NDBs. Whilst this type of receiver is adequate for reception of local beacons, specialized techniques (receiver preselectors, noise limiters and filters) are required for the reception of very weak signals from remote beacons.<ref>Template:Cite web</ref>
The best time to hear NDBs that are very far away (i.e that are "DX") is the last three hours before sunrise. Reception of NDBs is also usually best during the fall and winter because during the spring and summer, there is more atmospheric noise on the LF and MF bands.
ILS marker beacons
A marker beacon is a specialized beacon used in aviation in conjunction with an instrument landing system (ILS), to give pilots a means to determine distance to the runway. Marker beacons transmit on the dedicated frequency of 75 MHz. This type of beacon is slowly phased-out and most new ILS installations have no marker beacons.
Radio propagation beacons
Single letter HF beacons
See: Letter beacon
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", etc) transmitting in morse code have been regularly reported on various HF frequencies. There is no official information available about these transmitters and they are not registered with the ITU. Some investigators suggest that some of these beacons (the so called "cluster beacons") are actually radio propagation beacons for naval use.
Beacons are also used in both geostationary and inclined orbit satellites. Any satellite will emit one or more beacons (normally on a fixed frequency) whose purpose is twofold; as well as containing modulated houskeeping information (telemetry), the beacon is also used to locate the satellite (determine its azimuth and elevation) in the sky.
A beacon was left on the moon by the Apollo 17 mission, transmitting FSK telemetry on 2276.0 MHz.(3)
Driftnet buoy radio beacons
Driftnet radio buoys are extensively used by fishing boats operating in open seas and oceans.(4) They are useful for collecting long fishing lines or fishing nets, with the assistance of a radio direction finder. According to product information released by manufacturer Kato Electronics Co, Ltd., these buoys transmit on 1600–2850 kHz with a power of 4-15 W.
Distress radiobeacons
Distress radiobeacons, also collectively known as distress beacons, emergency beacons, or simply, beacons, are those tracking transmitters that operate as part of the international Cospas-Sarsat Search and Rescue satellite system. When activated, these beacons send out a distress signal that, when detected by geostationary|non-geostationary satellites, can be located by triangulation. In the case of 406 MHz beacons which transmit digital signals, the beacons can be uniquely identified almost instantly (via GEOSAR). Furthermore, a GPS position can be encoded into the signal, thus providing both instantaneous identification & position. Distress signals from the beacons are homed by Search and Rescue (SAR) aircraft and ground search parties who can in turn come to the aid of the concerned boat, aircraft, and/or persons.
- EPIRBs (Emergency Position Indicating Radio Beacons) signal maritime distress,
- ELTs (Emergency Locator Transmitters) signal aircraft distress
- PLBs (Personal Locator Beacons) are for personal use and are intended to indicate a person in distress who is away from normal emergency response capabilities (i.e. 911)
The basic purpose of distress radiobeacons is to get people rescued within the so-called "golden day" [1] (the first 24 hours following an accident) when the majority of survivors can still be saved.
IEEE 802.11 Wi-Fi beacons
In the field of Wi-Fi (wireless local area networks using the IEEE 802.11b and 802.11g specification), the term beacon signifies a specific data transmission from the wireless access point (AP), which carries the SSID, the channel number and security protocols such as WEP (Wired Equivalent Protection) or WPA (Wi-Fi Protected Access). This transmission does not contain the link layer address of another Wi-Fi device, therefore it can be received by any LAN client. (6)
AX.25 packet radio beacons
This mode of AX.25 operation, using a formal machine-readable beacon text specification developed by Bob Bruninga, WB4APR, became the basis of the Automatic Position Reporting System (APRS) networks.
- Connolly, R.: "Navigation Beacons", Radio & Communications Monitoring Monthly, 3(4), ISSN 179-7809, p. 58, April 2008.
- Jessop, G.R., G6JP: "VHF-UHF manual" (4th ed), Radio Society of Great Britain, ISBN 0-900612-63-0, page 2.19, 1983.
- Pelagic Fishing Methods in the Pacific, Western Pacific Regional Fishery Management Council.
- Robert Connolly: "Greyline DXing, Fishing NDBs and NOTAM software", Radio User, 5(6), pages 35–36, ISSN 1748-8117, June 2010.
- IEEE: "Local and metropolitan area networks — Specific requirements — Part 11: Wireless LAN Medium Access Control (MAC) and Physical Layer (PHY) specifications: Higher-Speed Physical Layer Extension in the 2.4 GHz Band (IEEE Std 802.11b-1999)", Institute of Electrical and Electronic Engineers, p. 2, 2003.
- AX.25 Link Access Protocol for Amateur Packet Radio
- Terry L. Fox, WB4JFI: "AX.25 Amateur Packet-Radio Link-Layer Protocol, Version 2.0", The American Radio Relay League, Newington, CT, ISBN 0-87259-011-9, p. 18, 1984.
- Non-directional beacon
- Letter beacon
- Radio direction finder
- Direction finding
- High Frequency Beacons
- HiFER
- Radio propagation beacon
- Beaconworld photo gallery by Alan Gale, G4TMV
- Sheldon Remington, NI6E (ex KH6SR): "On the Art of NDB DXing", The Lowdown, 1987-1988.
