Radio beacon
Revision as of 16:50, 20 August 2010 by Strange Attractor (Talk | contribs)
DARC beacons DRA5 and DK0WCY
Radio navigation beacons
There are also marine beacons, based on the same techonlogy and installed at coastal areas, for use by ships at sea.(1) Most of them, especially in the western world, are no longer in service, while some have been converted to telemetry transmitters for differential GPS. Chains of radio navigation beacons for marine use are still active around the Russian and Ukrainian coastline.(2)
NDB technical
Antennas are of vertical polarization, either masts with a "top hat" or T-like wire antennas supported between two masts. NDB antennas have as part of their makeup a segment that consists of an inductor and a capacitor in series, "tuned" to the particular frequency or frequencies assigned to that antenna. NDB's tuned segment is part of the antenna itself. There is often a counterpoise (or bottom section of the capacitor) buried in the ground underneath the antenna.
Monitoring NDBs
A PFC QSL card from an NDB
Besides their use in aircraft navigation, NDBs are also popular with DXers. Because NDBs are generally low-power (usually 25 watts), they normally cannot be heard over long distances, but favorable conditions in the ionosphere can allow NDB signals to travel much farther than normal. Because of this, radio DXers interested in picking up distant signals enjoy listening to faraway NDBs. Also, since the band allocated to NDBs is free of broadcast stations and their associated interference, and because most NDBs do little more than transmit their Morse Code callsign, they are very easy to identify, making NDB monitoring a very entertaining niche within the DXing hobby.
The beacons that are between 510 kHz and 530 kHz can sometimes be heard on AM radios that can tune below the beginning of the AM broadcast band. (For example, the "HEH" beacon in Newark, OH at 524 kHz is within the bandwidth of most AM radios, and the "OS" beacon in Columbus, OH at 515 kHz can also be heard on some AM radios). Some beacons can also be heard on 530 kHz, although from the adjacent frequencies such as "LYQ" at 529 kHz in Manchester, TN but for the most part, reception of NDBs requires a radio receiver that can receive frequencies below 530 kHz (the longwave band). Many so-called "shortwave" radios can receive all frequencies from 150 kHz to 30 MHz, which makes them ideal for listening to NDBs. Whilst this type of receiver is adequate for reception of local beacons, specialized techniques (receiver preselectors, noise limiters and filters) are required for the reception of very weak signals from remote beacons.(9)
ILS marker beacons
A marker beacon is a specialized beacon used in aviation in conjunction with an instrument landing system (ILS), to give pilots a means to determine distance to the runway. Marker beacons transmit on the dedicated frequency of 75 MHz. This type of beacon is slowly phased-out and most new ILS installations have no marker beacons.
Radio propagation beacons
See Radio propagation beacon
Single letter HF beacons
See: Letter beacon
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", etc) transmitting in morse code have been regularly reported on various HF frequencies. There is no official information available about these transmitters and they are not registered with the ITU. Some investigators suggest that some of these beacons (the so called "cluster beacons") are actually radio propagation beacons for naval use.
Beacons are also used in both geostationary and inclined orbit satellites. Any satellite will emit one or more beacons (normally on a fixed frequency) whose purpose is twofold; as well as containing modulated houskeeping information (telemetry), the beacon is also used to locate the satellite (determine its azimuth and elevation) in the sky.
A beacon was left on the moon by the Apollo 17 mission, transmitting FSK telemetry on 2276.0 MHz.(3)
Driftnet buoy radio beacons
Distress radiobeacons
  • EPIRBs (Emergency Position Indicating Radio Beacons) signal maritime distress,
  • ELTs (Emergency Locator Transmitters) signal aircraft distress
  • PLBs (Personal Locator Beacons) are for personal use and are intended to indicate a person in distress who is away from normal emergency response capabilities (i.e. 911)
The basic purpose of distress radiobeacons is to get people rescued within the so-called "golden day" [1] (the first 24 hours following an accident) when the majority of survivors can still be saved.
IEEE 802.11 Wi-Fi beacons
In the field of Wi-Fi (wireless local area networks using the IEEE 802.11b and 802.11g specification), the term beacon signifies a specific data transmission from the wireless access point (AP), which carries the SSID, the channel number and security protocols such as WEP (Wired Equivalent Protection) or WPA (Wi-Fi Protected Access). This transmission does not contain the link layer address of another Wi-Fi device, therefore it can be received by any LAN client. (6)
AX.25 packet radio beacons
This mode of AX.25 operation, using a formal machine-readable beacon text specification developed by Bob Bruninga, WB4APR, became the basis of the Automatic Position Reporting System (APRS) networks.
  5. Robert Connolly: "Greyline DXing, Fishing NDBs and NOTAM software", Radio User, 5(6), pages 35–36, ISSN 1748-8117, June 2010.
Wikipedia article: {{{1}}}
WP
