Radio propagation beacon
Revision as of 10:44, 2 September 2010 by Strange Attractor (Talk | contribs)
Transmission characteristics
160 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
40 MHz beacons
  • The first radio propagation beacon on 40 MHz was OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40021 kHz. Transmitted power is 22 W to a dipole antenna. Modulation is F1A keying (frequency Shift Keying), with a shift of 250 Hz. [1]
6 meters beacons
VHF/UHF beacons
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
Beacon projects
IARU Beacon Project
url="http://www.darc.de"
The International Beacon Project (IBP), which is coordinated by the Northern California DX Foundation and the International Amateur Radio Union, consists of 18 HF propagation beacons worldwide, which transmit in turns on 14100 kHz, 18110 kHz, 21150 kHz, 24930 kHz, and 28200 kHz. [5] The IARU/NDXF beacons transmit in turns on the five designated frequencies according to the following schedule, which repeats every 3 minutes:
Slot DXCC entity Call Location Latitude Longitude Grid Sq 14100 18110 21150 24930 28200
01 United Nations 4U1UN New York City 40º 45' N 73º 58' W FN3ØAS 00.00 00.10 00.20 00.30 00.40
02 Canada VE8AT Eureka, Nunavut 79º 59' N 85º 57' W EQ79AX 00.10 00.20 00.30 00.40 00.50
03 United States W6WX Mt. Umunhum 37º 09' N 121º 54' W CM97bd 00:20 00.30 00:40 00.50 01:00
04 Hawaii KH6WO Laie 21º 38' N 157º 55' W BL11ap 00.30 00.40 00.50 01.00 01.10
05 New Zealand ZL6B Masterton 41º 03' S 175º 36' E RE78tw 00.40 00.50 01.00 01.10 01.20
06 Australia VK6RBP Rolystone 32º 06' S 116º 03' E OF87av 00.50 01.00 01.10 01.20 01.30
07 Japan JA2IGY Mt. Asama 34º 27' N 136º 47' E PM84jk 01.00 01.10 01.20 01.30 01.40
08 Russia RR9O Novosibirsk 54º 59' N 82º 54' E NO14kx 01.10 01.20 01.30 01.40 01.50
09 Hong Kong VR2B Hong Kong 22º 16' N 114º 09' E OL72bg 01.20 01.30 01.40 01.50 02.00
10 Sri Lanka 4S7B Colombo 6º 6' N 80º 13' E NJ06cc 01.30 01.40 01.50 02.00 02.10
11 South Africa ZS6DN Pretoria 25º 54' S 28º 16' E KG44dc 01:40 01.50 02:00 02:10 02:20
12 Kenya 5Z4B Kariobangi 1º 15' S 36º 53' E KI88ks 01.50 02.00 02.10 02.20 02.30
13 Israel 4X6TU Tel Aviv 32º 03' N 34º 46' E KM72jb 02:00 02:10 02:20 02.30 02:40
14 Finland OH2B Lohja 60º 19' N 24º 50' E KP2Ø 02:10 02:20 02:30 02:40 02:50
15 Madeira CS3B Santo da Serra 32º 43' N 16º 48' W IM12or 02.20 02.30 02.40 02.50 00.00
16 Argentina LU4AA Buenos Aires 34º 37' S 58º 21' W GFØ5tj 02:30 02:40 02:50 00.00 00:10
17 Peru OA4B Lima 12º 04' S 76º 57' W FH17MW 02.40 02.50 00.00 00.10 00.20
18 Venezuela YV5B Caracas 10º 25' N 66º 51' W FK6ØNJ 02:50 00.00 00:10 00:20 00:30
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
  6. HF 0-20 MHz beacons
IK0WRB beacon keyer schematic
Wikipedia article: {{{1}}}
WP
