Radio propagation beacon
Transmission characteristics
160 meters beacons
10 meters beacons
R1 |
R2[3] |
R3 |
40 MHz beacons
- The first radio propagation beacon on 40 MHz was OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40021 kHz. Transmitted power is 22 W to a dipole antenna. Modulation is F1A keying (frequency Shift Keying), with a shift of 250 Hz. [1]
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
Beacon projects
IARU Beacon Project
The International Beacon Project (IBP), which is coordinated by the Northern California DX Foundation and the International Amateur Radio Union, consists of 18 HF propagation beacons worldwide, which transmit in turns on 14100 kHz, 18110 kHz, 21150 kHz, 24930 kHz, and 28200 kHz. [5] The IARU/NDXF beacons transmit in turns on the five designated frequencies according to the following schedule, which repeats every 3 minutes:
Slot | DXCC entity | Call | Location | Latitude | Longitude | Grid Sq | 14100 | 18110 | 21150 | 24930 | 28200 |
01 | United Nations | 4U1UN | New York City | 40º 45' N | 73º 58' W | FN3ØAS | 00.00 | 00.10 | 00.20 | 00.30 | 00.40 |
02 | Canada | VE8AT | Eureka, Nunavut | 79º 59' N | 85º 57' W | EQ79AX | 00.10 | 00.20 | 00.30 | 00.40 | 00.50 |
03 | United States | W6WX | Mt. Umunhum | 37º 09' N | 121º 54' W | CM97bd | 00:20 | 00.30 | 00:40 | 00.50 | 01:00 |
04 | Hawaii | KH6WO | Laie | 21º 38' N | 157º 55' W | BL11ap | 00.30 | 00.40 | 00.50 | 01.00 | 01.10 |
05 | New Zealand | ZL6B | Masterton | 41º 03' S | 175º 36' E | RE78tw | 00.40 | 00.50 | 01.00 | 01.10 | 01.20 |
06 | Australia | VK6RBP | Rolystone | 32º 06' S | 116º 03' E | OF87av | 00.50 | 01.00 | 01.10 | 01.20 | 01.30 |
07 | Japan | JA2IGY | Mt. Asama | 34º 27' N | 136º 47' E | PM84jk | 01.00 | 01.10 | 01.20 | 01.30 | 01.40 |
08 | Russia | RR9O | Novosibirsk | 54º 59' N | 82º 54' E | NO14kx | 01.10 | 01.20 | 01.30 | 01.40 | 01.50 |
09 | Hong Kong | VR2B | Hong Kong | 22º 16' N | 114º 09' E | OL72bg | 01.20 | 01.30 | 01.40 | 01.50 | 02.00 |
10 | Sri Lanka | 4S7B | Colombo | 6º 6' N | 80º 13' E | NJ06cc | 01.30 | 01.40 | 01.50 | 02.00 | 02.10 |
11 | South Africa | ZS6DN | Pretoria | 25º 54' S | 28º 16' E | KG44dc | 01:40 | 01.50 | 02:00 | 02:10 | 02:20 |
12 | Kenya | 5Z4B | Kariobangi | 1º 15' S | 36º 53' E | KI88ks | 01.50 | 02.00 | 02.10 | 02.20 | 02.30 |
13 | Israel | 4X6TU | Tel Aviv | 32º 03' N | 34º 46' E | KM72jb | 02:00 | 02:10 | 02:20 | 02.30 | 02:40 |
14 | Finland | OH2B | Lohja | 60º 19' N | 24º 50' E | KP2Ø | 02:10 | 02:20 | 02:30 | 02:40 | 02:50 |
15 | Madeira | CS3B | Santo da Serra | 32º 43' N | 16º 48' W | IM12or | 02.20 | 02.30 | 02.40 | 02.50 | 00.00 |
16 | Argentina | LU4AA | Buenos Aires | 34º 37' S | 58º 21' W | GFØ5tj | 02:30 | 02:40 | 02:50 | 00.00 | 00:10 |
17 | Peru | OA4B | Lima | 12º 04' S | 76º 57' W | FH17MW | 02.40 | 02.50 | 00.00 | 00.10 | 00.20 |
18 | Venezuela | YV5B | Caracas | 10º 25' N | 66º 51' W | FK6ØNJ | 02:50 | 00.00 | 00:10 | 00:20 | 00:30 |
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Aurora Beacon DK0WCY
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Radio_propagation_beacon | WP |
