Radio propagation beacon
A radio propagation beacon is a radio beacon, which is used for investigating the propagation of radio signals. Currently most radio propagation beacons use amateur radio frequencies. They can be found on HF, VHF, UHF, and microwave frequencies. Microwave beacons are also used as signal sources to test and calibrate antennas and receivers.[1] [2]
Transmission characteristics
Most beacons consist of a simple digital keyer, based on discrete digital electronics or a microcontroller, and a low power transmitter or tranceiver. Antennas usually are types with low directivity.
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| R1 | R2 | R3 | |
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
SHF and microwave beacons
| R1 | R2 | R3 | |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Aurora Beacon DK0WCY
