Radio propagation beacon
DK0WCY & DRA5 beacons
Transmission characteristics
Most beacons operate in continuous wave (CW or A1A) and transmit their identification (callsign and location). Some of them send long dashes (sometimes at varying power levels) to facilitate signal strength measurement. A small number of beacons transmit Morse code by frequency shift keying (F1A). A few beacons transmit signals in digital modulation modes, like radioteletype (F1B) and PSK31 (G1B).
Most beacons consist of a simple digital keyer, based on discrete digital electronics or a microcontroller, and a low power transmitter or tranceiver. Antennas usually are types with low directivity.
160 meters beacons
60 meters beacons
DRA5 5195.0 kHz JO44VQ DARC
LX0HF 5205.3 kHz
OK1IF 5258.5 kHz JO40HG Recording: [1]
GB3RAL 5290.0 kHz IO91IN RSGB
GB3WES 5290.0 kHz IO84QN RSGB
GB3ORK 5290.0 kHz IO89JA RSGB
30 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
Band Beacon Sub-band (MHz)
IARU R1 IARU R2 IARU R3
33 cm N/A Varies Locally N/A
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
SHF and microwave beacons
1.2 cm Beacons are rare
Beacon projects
IARU Beacon Project
url="http://www.darc.de"
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7)
Radio Beacon LN2A
14395 00 - 20 - 40
20945 04 - 24 - 44
5470 08 - 28 - 48
7870 12 - 32 - 52
10407 16 - 36 - 56
The contact address is:
P O Box 447 Sentrum
N-0104 Oslo
Norway
DARC beacon project
RSGB 5 MHz beacon project
U.S. Navy beacon NAF
Notes and references
  6. HF 0-20 MHz beacons
Beacon lists
IK0WRB beacon keyer schematic
WP
