Radio propagation beacon
Transmission characteristics
Most beacons operate in continuous wave (CW or A1A) and transmit their identification (callsign and location). Some of them send long dashes (sometimes at varying power levels) to facilitate signal strength measurement. A small number of beacons transmit Morse code by frequency shift keying (F1A). A few beacons transmit signals in digital modulation modes, like radioteletype (F1B) and PSK31 (G1B).
Most beacons consist of a simple digital keyer, based on discrete digital electronics or a microcontroller, and a low power transmitter or tranceiver. Antennas usually are types with low directivity. There are exceptions, however, like the high power beacons with directional antennas, specifially set up for transatlantic VHF propagation experiments. Recently K6HX published a versatile keyer design based on the popular Arduino microcontroller system.
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
SHF and microwave beacons
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
Beacon lists
- Aurora Beacon DK0WCY
