Radio propagation beacon
Transmission characteristics
The majority of propagation beacons operate in continuous wave (CW or A1A) and transmit their identification (callsign and location). Some of them send long dashes (sometimes at varying power levels) to facilitate signal strength measurement. A small number of beacons transmit Morse code by frequency shift keying (F1A). A few beacons transmit signals in digital modulation modes, like radioteletype (F1B) and PSK31 (G1B).
160 meters beacons
60 meters beacons
Callsign | Frequency | Locator | Details |
DRA5 | 5195.0 kHz | JO44VQ | DARC |
LX0HF | 5205.3 kHz | ||
OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
GB3RAL | 5290.0 kHz | IO91IN | RSGB |
GB3WES | 5290.0 kHz | IO84QN | RSGB |
GB3ORK | 5290.0 kHz | IO89JA | RSGB |
OV1BCN | 5290.0 kHz | JO55SI | Op OZ1FJB [2] |
SZ1SV | 5398.5 kHz | Op SV1IW & SV1JG |
30 meters beacons
DK0WCY | 10144.0 kHz | JO44VQ | DARC |
IK3NWX | 10137.3 kHz | JN55VF | nr Monselice, PD 15m asl |
10 meters beacons
R1 |
R2[3] |
R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
IARU R1 | IARU R2 | IARU R3 | |
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
SHF and microwave beacons
9 cm | 3,400.800-3,400.995 | 3,456.300-3,456.400 | Unknown |
5 cm | 5,760.800-5,760.995 | 5,760.300-5,760.400 | Unknown |
3 cm | 10,368.800-10,368.995 | 10,368.300-10,368.400 | Unknown |
1.2 cm | Beacons are rare |
Optical and infrared beacons
Type | Frequencies | Countries | FCC Part 15 rules |
LowFER | 160-190 kHz | USA, Canada | § 15.217 |
MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
BeFER | 6776 kHz | Canada | - |
HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
WSPR Network
This is an a large scale amateur radio propagation beacon project which uses the WSPR (Weak Signal Propagation Reporter) transmission scheme available with the WSJT software suite, created by Joe Taylor, K1JT. The loosely-coordinated beacon transmitters and receivers, collectively known as the WSPRnet, report the real-time propagation characteristics of a number of frequency bands and geographical locations via the Internet. The WSPRnet website provides detailed propagation report databases and real-time graphical maps of propagation paths. WSPR Networks operates on the following amateur radio frequencies (USB dial settings in kHz) 136.0, 502.4, 1836.6, 3592.6, 5287.2, 7038.6, 101387.0, 14095.6, 18104.6, 21094.6, 24924.6, 28124.6, 50293.0, 70028.6 and 144489.0 kHz.
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
Beacon lists
- Aurora Beacon DK0WCY
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Radio_propagation_beacon | WP |
