Radio propagation beacon
Transmission characteristics
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
| SZ1SV | 5398.5 kHz | Op SV1IW & SV1JG |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
SHF and microwave beacons
Optical and infrared beacons
| Type | Frequencies | Countries | FCC Part 15 rules |
| LowFER | 160-190 kHz | USA, Canada | § 15.217 |
| MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
| BeFER | 6776 kHz | Canada | - |
| HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
| 49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
WSPR Network
This is an a large scale amateur radio propagation beacon project which uses the WSPR (Weak Signal Propagation Reporter) transmission scheme available with the WSJT software suite, created by Joe Taylor, K1JT. The loosely-coordinated beacon transmitters and receivers, collectively known as the WSPRnet, report the real-time propagation characteristics of a number of frequency bands and geographical locations via the Internet. The WSPRnet website provides detailed propagation report databases and real-time graphical maps of propagation paths. WSPR Networks operates on the following amateur radio frequencies (USB dial settings in kHz) 136.0, 502.4, 1836.6, 3592.6, 5287.2, 7038.6, 101387.0, 14095.6, 18104.6, 21094.6, 24924.6, 28124.6, 50293.0, 70028.6 and 144489.0 kHz.
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
Beacon lists
- Aurora Beacon DK0WCY
