Radio beacon
A radio beacon (Радиомаяк) is a transmitter at a known location, which transmits a continuous or periodic radio signal with limited information content (for example its identification or location), on a specified radio frequency. Occasionally the beacon function is combined with some other transmission, like telemetry data or meteorological information.
NDB technical
NDBs typically operate in the frequency range from 190 kHz to 535 kHz (although they are allocated frequencies from 190 to 1750 kHz) and transmit a carrier modulated by either 400 or 1020 Hz. NDBs can also be colocated with DME stations and ILS marker beacons. NDB owners are mostly governmental agencies and airport authorities.
Transmission power varies. Locator beacons are low power, typically 25-100 W. Beacons marking airways are medium to high power, typically 200 W to 1 kW, and sometimes higher up to 5 kW. In most cases there are two transmitters at the beacon site, the main transmitter and a backup reserve transmitter. The backup transmitter sends the beacon identification morse code letters followed by a dot (morse code "E").
Monitoring NDBs
In North America, the NDB band is from 190 to 435 kHz and from 510 to 530 kHz. In Europe, there is a longwave broadcasting band from 150 to 280 kHz, so the European NDB band is from 280 kHz to 530 kHz with a gap between 495 and 505 kHz because 500 kHz was the international maritime distress (emergency) frequency.
The beacons that are between 510 kHz and 530 kHz can sometimes be heard on AM radios that can tune below the beginning of the AM broadcast band. (For example, the "HEH" beacon in Newark, OH at 524 kHz is within the bandwidth of most AM radios, and the "OS" beacon in Columbus, OH at 515 kHz can also be heard on some AM radios). Some beacons can also be heard on 530 kHz, although from the adjacent frequencies such as "LYQ" at 529 kHz in Manchester, TN but for the most part, reception of NDBs requires a radio receiver that can receive frequencies below 530 kHz (the longwave band). Many so-called "shortwave" radios can receive all frequencies from 150 kHz to 30 MHz, which makes them ideal for listening to the stronger NDB signals. Whilst this type of receiver is adequate for reception of local beacons, specialized techniques (receiver preselectors, noise limiters and narrow IF filters) are required for the reception of very weak signals from remote beacons.(9)
ILS marker beacons
A marker beacon is a specialized beacon used in aviation in conjunction with an instrument landing system (ILS), to give pilots a means to determine distance to the runway. Marker beacons transmit upwards using beam antennas on the dedicated frequency of 75.0 MHz. ILS marker beacons are gradually phased-out and most new ILS installations have no marker beacons.
Radio propagation beacons
Single letter HF beacons
See: Letter beacon
Beacons are also used in both geostationary and inclined orbit satellites. Almost every satellite transmits one or more beacon signals, normally on fixed frequencies. The satellite beacons are used to locate the satellite (determine its azimuth and elevation) in the sky and point the receiving antenna accurately. In addtion they contain modulated houskeeping information (telemetry). Many satellites transmit two distinct beacons, the general beacon, which transmits limited information in CW or FSK and is used for locating and identifying the satellite and the engineering beacon, which transmits telemetry data in FSK or PSK. Satellite radio beacons have proved useful in studies of various ionospheric phenomena, like traveling ionospheric disturbances, isolated plasma lenses etc.(11)
An S-band radio beacon was left on the moon by the Apollo 17 mission, transmitting FSK telemetry on 2276.0 MHz.(3)
Driftnet buoy radio beacons
See: Fishnet beacon
Driftnet radio buoys are extensively used by fishing boats operating in open seas and oceans.(4) They are useful for collecting long fishing lines or fishing nets, with the assistance of a radio direction finder. According to product information released by manufacturer Kato Electronics Co, Ltd., these buoys transmit on 1600–2850 kHz with a power of 4-15 W.
Distress radiobeacons
Distress radiobeacons, also collectively known as distress beacons, emergency beacons, or simply, beacons, are those tracking transmitters that operate as part of the international Cospas-Sarsat Search and Rescue satellite system. When activated, these beacons send out a distress signal that, when detected by geostationary|non-geostationary satellites, can be located by triangulation. In the case of 406 MHz beacons which transmit digital signals, the beacons can be uniquely identified almost instantly (via GEOSAR). Furthermore, a GPS position can be encoded into the signal, thus providing both instantaneous identification & position. Distress signals from the beacons are homed by Search and Rescue (SAR) aircraft and ground search parties who can in turn come to the aid of the concerned boat, aircraft, and/or persons.
- EPIRB (Emergency Position Indicating Radio Beacons) used for maritime distress,
- ELT (Emergency Locator Transmitters) signal aircraft distress
- PLB (Personal Locator Beacons) are for personal use and are intended to indicate a person in distress who is away from normal emergency response capabilities (i.e. 911)
IEEE 802.11 Wi-Fi beacons
A Wi-Fi beacon transmission does not specify the link layer address of another Wi-Fi device, therefore it can be received and processed by any LAN client. (6)
- In infrastructure networks, beacon frames are sent by access points. Usually the beacon interval can be set though the access point configuration screen. An interval of 100 ms is recommended, as it provides good performance for most applications.
- In ad hoc networks there are no access points, so one of the peer stations assumes the responsibility for sending the beacon. After receiving a beacon frame, each station waits for the beacon interval and then, if no beacon is received, it transmits it's own beacon frame after a random time delay.
There are no special timeslot or channel reservations for beacons transmissions, so they are sent using the mandatory 802.11 CSMA/CA algorithm. If another station is sending a frame when the beacon is to be sent, then the access point must wait, therefore the actual time between beacon transmissions may be longer than the beacon interval. This is compensated by utilizing the timestamp found within the beacon frame.
Transmission of beacon frames generates a substantial amount of overhead. However, the beacon serves a variety of functions:
- Each beacon transmission identifies the presence of an access point. By default, each WiFi radio network interface (NIC) passively scans all RF channels and listens for beacons coming from access points in order to find a suitable access point.
- When a beacon is found, the radio NIC learns a great deal about that particular network. This enables a ranking of access points based on the received signal strength of the beacon, along with capability information regarding the network. The radio NIC can then associate with the most preferable access point.
- After association, the station continues to scan for other beacons in case the signal from the currently-associated access point become too weak to maintain communications. As the radio NIC receives beacons from the associated access point, the radio NIC updates its local clock to maintain timing synchronization with the access point and other stations. In addition, the radio NIC will abide by any other changes, such as data rate, that the frame body of the beacon indicates.
- The beacons also support stations implementing power saving mode. With infrastructure networks, the access point buffers frames destined for "sleeping" stations and announces which radio NICs have frames waiting for, through the TIM that's part of the beacon.
AX.25 packet radio beacons
- Connolly, R.: "Navigation Beacons", Radio & Communications Monitoring Monthly, 3(4), ISSN 179-7809, p. 58, April 2008.
- Jessop, G.R., G6JP: "VHF-UHF manual" (4th ed), Radio Society of Great Britain, ISBN 0-900612-63-0, page 2.19, 1983.
- Pelagic Fishing Methods in the Pacific, Western Pacific Regional Fishery Management Council.
- Robert Connolly: "Greyline DXing, Fishing NDBs and NOTAM software", Radio User, 5(6), pp. 35–36, ISSN 1748-8117, June 2010.
- IEEE: "Local and metropolitan area networks — Specific requirements — Part 11: Wireless LAN Medium Access Control (MAC) and Physical Layer (PHY) specifications: Higher-Speed Physical Layer Extension in the 2.4 GHz Band (IEEE Std 802.11b-1999)", Institute of Electrical and Electronic Engineers, p. 2, 2003.
- AX.25 Link Access Protocol for Amateur Packet Radio
- Terry L. Fox, WB4JFI: "AX.25 Amateur Packet-Radio Link-Layer Protocol, Version 2.0", The American Radio Relay League, Newington, CT, ISBN 0-87259-011-9, p. 18, 1984.
- Remington, S., KH6SR: "On the Art of NDB DXing", The Longwave Club of America, 1987-1989
- Robert Connolly: "Time to get NDB hunting", Radio User, 6(6), pp. 5, ISSN 1748-8117, June 2011.
- Keneth Davies: "Ionospheric Radio", The Institution of Electrical Engineers, ISBN 0-86341-186-X, 1990, p. 296.
- NDB list website by Alan Gale, G4TMV
- Sheldon Remington, NI6E (ex KH6SR): "On the Art of NDB DXing", The Lowdown, 1987-1988.
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Electric_beacon | WP |
