Radio propagation beacon
History
The earliest record of radio propagation beacons goes back to World War II, when the German military operated propagation beacons on wavelengths of approximate 80 m and 10 m. Many propagation beacons were installed during the International Geophysical Year 1957-1958 These included amateur radio beacons OZ7IGY and GB3IGY (later GB3RAL) on 144 MHz, which are still operational, as well as the now defunct DM3IGY in East Germany on 28001 kHz. (19)
Transmission characteristics
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Inactive. Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
| SZ1SV | 5398.5 kHz | KM17UX | Op SV1IW & SV1JG. Inactive. |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
ON0EME moon beacon
SHF and microwave beacons
Optical and infrared beacons
| Type | Frequencies | Countries | FCC Part 15 rules |
| LowFER | 160-190 kHz | USA, Canada | § 15.217 |
| MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
| BeFER | 6776 kHz | Canada | - |
| HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
| 49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7) (20)
Radio Beacon VL8IPS
- Identification signal (in Morse code): VL8IPS
- Location: Humpty Doo, near Darwin, Northen Territory, 12 deg 36 min S - 131 deg 16 min 51 sec E
- Hours of transmission: 24 hours per day
- Assigned frequencies: 5470 kHz, 7870 kHz, 10407 kHz, 14395 kHz and 20945 kHz
- Transmitter: Rockwell Collins HF-8022
- Transmitter power: approximately 2 kW on all frequencies
- Antenna: AEA 628D biconical monopole
- Mode: suppressed carrier SSB (USB & LSB) with the reference frequencies (suppressed carrier frequencies) 1225 Hz below the assigned frequencies, with the FSK "mark" 800 Hz above reference frequency and the FSK "space" 1650 Hz above the reference frequency.
- Signal duration and format: as specified in Recommendation ITU-R P.845; 4 min for each frequency, 20 min for all five frequencies according to the following schedule:
| Reference frequency (kHz) | Minutes after each hour |
| 5470 | 00 - 20 - 40 |
| 7870 | 04 - 24 - 44 |
| 10407 | 08 - 28 - 48 |
| 14395 | 12 - 32 - 52 |
| 20945 | 16 - 36 - 56 |
- Reception reports could be sent beacon@ips.gov.au
DARC beacon project
RSGB 5 MHz beacon project
WSPR Network
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
Beacon lists
- Aurora Beacon DK0WCY
- ON0EME moon beacon status
