Radio propagation beacon
Revision as of 19:05, 24 May 2015 by SV1XV (Talk | contribs)
DK0WCY & DRA5 beacons
History
Transmission characteristics
160 meters beacons
60 meters beacons
DRA5 5195.0 kHz JO44VQ DARC
LX0HF 5205.3 kHz
GB3RAL 5290.0 kHz IO91IN RSGB
GB3WES 5290.0 kHz IO84QN RSGB
GB3ORK 5290.0 kHz IO89JA RSGB
30 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
Band Beacon Sub-band (MHz)
IARU R1 IARU R2 IARU R3
33 cm N/A Varies Locally N/A
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
ON0EME moon beacon
144 MHz transatlantic beacons
CU2VHF HM77DT 144401
CU8DUB HM49KL 144420
D4C/B 144436 Copied by Dave Pedersen, PJ4VHF/N7BHC, on Bonaire Island on May 6, 2015 [4]
ED8ZAA/B IL18 144484
NP2X/B FK77PR 144291 St. Croix, US Virgin Islands - 240 feet AMSL (73 meters AMSL) - RF Concepts 160 watt, reduced to 100 watts for beacon operation - 15 element yagi @ beam heading of 55 degrees (Portgual) - np2xbeacon@gmail.com
VE1SMU/H 144.288
VO1ZA GN37JS 144400 Inactive
Indian Ocean beacon project
SHF and microwave beacons
1.2 cm Beacons are rare
Optical and infrared beacons
Main articles: LowFER, HiFER.
MedFER 510 & 1704 kHz
(510-1705 kHz)
USA, Canada § 15.219
BeFER 6776 kHz Canada -
49ers 49846 kHz
(49820-49900 kHz)
USA § 15.235
Beacon projects
NCDXF-IARU beacon setup
IARU Beacon Project
url="http://www.darc.de"
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7) (20)
Radio Beacon LN2A
14395 00 - 20 - 40
20945 04 - 24 - 44
5470 08 - 28 - 48
7870 12 - 32 - 52
10407 16 - 36 - 56
The contact address is:
P O Box 447 Sentrum
N-0104 Oslo
Norway
Radio Beacon VL8IPS
5470 00 - 20 - 40
7870 04 - 24 - 44
10407 08 - 28 - 48
14395 12 - 32 - 52
20945 16 - 36 - 56
  • Reception reports could be sent beacon@ips.gov.au
DARC beacon project
RSGB 5 MHz beacon project
U.S. Navy beacons
WSPR Network
Notes and references
  6. HF 0-20 MHz beacons
Beacon lists
IK0WRB beacon keyer schematic
WP
