MURS
Revision as of 20:42, 19 December 2018 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS, VHF CB, also rendered as "Multi-Use Radio Service" - not to be confused with similar services such as FRS/GMRS, regular old 26-27 MHz CB, VHF marine or licensed land mobile (business radio) services.
MURS Frequencies / Channels:
MURS Channel Identifier Frequency Maximum Bandwidth
MURS Channel 1 MURS-1 151.820 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 2 MURS-2 151.880 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 3 MURS-3 151.940 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 4 Blue Dot MURS-4 154.570 MHz 20.00 kHz (any mode - wideband)
MURS Channel 5 Green Dot MURS-5 154.600 MHz 20.00 kHz (any mode - wideband)
Repeaters are not allowed on the MURS frequencies per FCC rules. This includes duplex and simplex repeaters, also known as "store-and-forward" repeaters. This rule is apparently often ignored by MURS users as evidenced by the existence of simplex repeaters operating on the MURS frequencies as well as cross-band repeater setups using MURS (on VHF) and FRS/GMRS channels (on UHF). There are several reports on various radio hobbyist Internet forums of MURS repeaters including wide-area simplex repeaters located on mountaintops or in urban areas.
The 154 MHz frequencies were moved from the Business Radio Service (Part 90 of the FCC rules) and stations previously licensed to use these frequencies with higher power levels are considered grandfathered users and may legally transmit high power transmissions. Wal-Mart and other retailers using 154.600 MHz and 154.570 MHz have continued to use these frequencies after they were made license-free.
