11 meter
27.430 MHz to 27.540 MHz | 27410 kHz to 27540 kHz | Business/Industrial Radio Service (20 kHz steps, FM mode) |
27.540 MHz to 28.000 MHz | 27540 kHz to 28000 kHz | Government and Fixed/Mobile |
28.000 MHz to 29.700 MHz | 28000 kHz to 29700 kHz | Amateur Radio Ham Radio 10 Meter Band |
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz). Common freeband frequencies include:
- 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
