MURS
Revision as of 12:11, 26 March 2019 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
MURS Channel 1 MURS-1 151.820 MHz 11.25 kHz (any mode - narrowband FM/NFM most common)
MURS Channel 2 MURS-2 151.880 MHz 11.25 kHz (any mode - narrowband FM/NFM most common)
MURS Channel 3 MURS-3 151.940 MHz 11.25 kHz (any mode - narrowband FM/NFM most common)
MURS Channel 4 Blue Dot MURS-4 154.570 MHz 20.00 kHz (any mode - wideband - FM and NFM are both used)
MURS Channel 5 Green Dot MURS-5 154.600 MHz 20.00 kHz (any mode - wideband - FM and NFM are both used)
Repeaters are not allowed on the MURS frequencies per FCC rules. This includes duplex and simplex repeaters, also known as "store-and-forward" repeaters. This rule is apparently often ignored by MURS users as evidenced by the existence of simplex repeaters operating on the MURS frequencies as well as cross-band repeater setups using MURS (on VHF) and FRS/GMRS channels (on UHF). There are several reports on various radio hobbyist Internet forums of MURS repeaters including wide-area simplex repeaters located on mountaintops or MURS simplex repeaters with antennas located on high-rise buildings in urban areas.
  • 151.8200 MHz MURS Channel 1 118.8 Hz CTCSS/PL - crossband with GMRS channel 22 462.725 118.8 Hz CTCSS/PL (New Jersey)
  • 151.8800 MHz MURS Channel 2 CSQ or unknown CTCSS/PL - Monee, Illinois (grid square DM09)
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia
  • 154.5700 MHz MURS Channel 4 156.7 Hz CTCSS/PL - Orange County, New York
Please use MURS channel 2 if possible when setting up a MURS simplex repeater "parrot" or MURS cross band repeater.
It is recommended that MURS simplex repeater and cross-band repeater users use 156.7 Hz or 167.9 Hz as these CTCSS tones are used for interoperability and emergency purposes. Use of default tone 67.0 Hz is not recommended. MURS simplex repeater and MURS GMRS FRS crossband repeater operators should monitor frequency usage in their area to ensure they do not select a PL or DPL (CTCSS or DCS) tone that is used by another MURS, GMRS or FRS user as this would cause heavy interference issues and attract FCC attention.
In other words, don't use carrier squelch aka CSQ, 67.0 Hz CTCSS, 023 DCS/DPL and don't use FRS channel 1 (462.5625 MHz) as a crossband frequency. Don't use 154.570 or 154.600 with CSQ, 67.0 Hz, 71.9 Hz, 74.4 Hz or 77.0 Hz CTCSS tones as these are default tones and are often used by Wal-Mart and similar retail stores on MURS
Emergency preparedness radio and communications guides, including the interoperability guide, recommend programming the MURS and FRS frequencies into radios for compatibility with these systems.
There is an effort to standardize the use of "channel 3" as a general "prepper" or emergency preparedness "calling" channel across the three Part 95 services, MURS, CB and FRS (MURS channel 3 - 151.94 MHz, CB channel 3 - 26.985 MHz and FRS channel 3 - 462.6125 MHz) in conjunction with HF/VHF/UHF amateur frequencies. MURS channels 1, 2 and 3 often have less activity on them compared to channel 4 and 5. See notes above regarding setting up simplex repeaters on MURS for emergency preparedness/militia user purposes.
