MURS
Revision as of 12:58, 8 May 2019 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA, 85 miles from Washington, D.C., 105 miles from Richmond, VA)
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
Please use MURS channel 2 if possible when setting up a MURS simplex repeater "parrot" or MURS cross band repeater.
It is recommended that MURS simplex repeater and cross-band repeater users use 156.7 Hz or 167.9 Hz as these CTCSS tones are used for interoperability and emergency purposes. MURS simplex repeater and MURS GMRS FRS crossband repeater operators should monitor frequency usage in their area, ideally for several weeks or more, to ensure they do not select a PL or DPL (CTCSS or DCS) tone that is used by another MURS user. Use of carrier squelch (CSQ) is strongly discouraged. If you decide to use MURS channel 4 (154.57 MHz) or MURS channel 5 (154.6 MHz) please verify that there are no Wal-Mart, Costco, Wawa or other similar stores in your area using those frequencies, as those stores use 154.570 and 154.600 MHz nationwide.
Emergency preparedness radio and communications guides, including the interoperability guide, recommend programming the MURS and FRS frequencies into radios for compatibility with these systems.
