MURS
Multi Use Radio Service
MURS Frequencies / Channels:
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA, 85 miles from Washington, D.C., 105 miles from Richmond, VA)
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
