Most of the transmissions you'll hear on these frequencies are from portable handheld radios - walkie-talkies, but sometimes high powered mobile radios or even portable repeaters are heard. Portable or temporary repeater output frequencies may be any of the VHF low or VHF high frequencies. On the UHF band, input frequency is 5 MHz above output frequency. In many situations all frequencies are used for simplex only. The 457 MHz, 462 MHz and 467 MHz frequencies are simplex use only and are often used for on-site communications using portable handheld radios. Several of the itinerant frequencies may be used as repeater output channels, repeater input channels or for simplex/talk-around purposes. Examples include the 464.500 MHz, 464.550 MHz and 469.500 MHz, 469.550 MHz frequencies. 464.550 MHz may be used as a repeater output (paired with 469.550 MHz) or both frequencies may be used for simplex purposes. The 457/467 MHz frequencies are also used by shipboard and dockside repeaters or simplex systems aboard ship (10 MHz offset or 10.225 MHz offset). The itinerant frequencies in the VHF bands do not have a set pairing or offset like the UHF bands do. Also note the odd frequency spacing around 154 MHz:
- 154.46375 MHz - SCADA/telemetry (narrowband data only)
- 154.47125 MHz - SCADA/telemetry (narrowband data only)
- 154.47875 MHz - SCADA/telemetry (narrowband data only)
- 154.4825 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.4900 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.4975 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.5050 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.5150 MHz - regular Business Radio use, 12.5 kHz bandwidth 10 kHz channel step
- 154.5275 MHz - regular Business Radio use, 12.5 kHz bandwidth 12.5 kHz channel step
- 154.53375 MHz - regular Business Radio use or SCADA/telemetry 6.25 kHz channel step
- 154.5400 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.5475 MHz - regular Business Radio use, 12.5 kHz bandwidth 7.5 kHz channel step
- 154.5550 MHz - narrowband voice/data (digital voice), 12.5 kHz bandwidth 7.5 kHz channel step
- 154.5700 MHz - MURS channel 4 20 kHz bandwidth 15 kHz channel step
- 154.5850 MHz - regular Business Radio use, 12.5 kHz bandwidth 15 kHz channel step
- 154.6000 MHz - MURS channel 5 20 kHz bandwidth 10 kHz channel step
- 154.6100 MHz - narrowband voice/data (digital voice) modes 10 kHz/15 kHz channel step
- 154.6250 MHz - regular Business Radio use, 12.5 kHz bandwidth 15 kHz channel step - used for on site paging
- 154.6400 MHz - regular Business Radio use, 12.5 kHz bandwidth 15 kHz channel step
- 154.6575 MHz - begin public safety allocation at 7.5 kHz channel steps
- 27.490 MHz - Itinerant, may be used as base, mobile and/or part of temporary or portable repeater
- 152.9000 MHz - Motorola RDX default channel 19
- 154.6250 MHz - Mobile or base (sometimes used for paging)
- 154.6400 MHz - Mobile or base (154.6475 MHz/154.650 MHz/154.655 MHz/154.6575 MHz/154.655 MHz start Public Safety frequency allocations)
- The default channels / frequencies for most job site / contractor / construction site crews will vary. Many crews use FRS, MURS or CB for on-site communications, especially if multiple contractors and subcontractors are working together on a large site. The default out of the box factory UHF channels are also often heavily used. These include 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.850 MHz, 467.875 MHz, etc. Most radios default to 67.0 Hz CTCSS tone (PL tone - called “code” in many instances). Other popular CTCSS and DCS tones or codes include 77.0 Hz, 88.5 Hz, 100.0 Hz, 203.5 Hz, 250.3 Hz, and the DCS / DPL codes 023, 025, 026, 032, and 754. Patience, a SDR and/or a scanner or frequency counter with CTCSS / DCS decode capability will yield interesting results. In urban areas it is very common to hear multiple users on the same frequency or channel, but with different CTCSS / DCS (PL / DPL) tones and/or codes in use. This is particularly common on the UHF business itinerants, the FRS channels and the MURS channels. Motorola MURS radios default to 154.570 MHz and 154.600 MHz out of the box. Motorola on-site VHF handhelds default to 151.625 MHz and 151.955 MHz out of the box (see list above for all available channels in both the VHF and UHF configurations. UHF is generally more popular in urban areas while VHF is more commonly used for mobile to mobile communications and in rural areas. However, all three bands can and are used in urban areas.
Note that 30.000 to 87.975 MHz is shared with the SINCGARS VHF FM military land mobile communications system, which operates in either frequency hopping FH mode or single channel SC mode. This is often referred to as "FM" within the military. 30 to 88 MHz in 25 kHz steps. While the military usually stays in the military/government sub-bands (29.80-30.55 MHz, 32-33 MHz, 34-35 MHz, 36-37 MHz, 38-39 MHz, 40-42 MHz, 46.6-47 MHz and 49.6-50 MHz they can also be found in the land mobile sub-bands using 25 kHz steps and 150 Hz CTCSS tone. Military operations in the United States use both FH and SC mode with or without voice encryption. These channels are often referred to as “FM” or “Fox Mike”. For example, 38.500 MHz would be called “FM 38.50” or “38.50 FM”
Frequencies below 150 MHz may continue to use 20K0F3E or 16K0F3E "wideband" FM mode (also known as 25 kHz bandwidth or 20 kHz bandwidth). In the land mobile / business radio industry the term is often “25 kHz channels” or “25 kHz bandwidth”. VHF low band 25-50 MHz / 29-50 MHz / 30-50 MHz frequencies are not subject to the FCC narrowbanding requirements that are in force for the 150-174 MHz VHF band and 420-470 MHz UHF band. However, some systems may use 12.5 kHz channels 11K3F3E, 11K2F3E or 11K0F3E emissions on these frequencies.
| 27.555 MHz | Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB |
| 29.730 MHz | |
| 29.750 MHz | |
| 29.770 MHz | |
| 29.790 MHz | |
| 30.580 MHz | |
| 30.600 MHz | |
| 30.620 MHz | |
| 30.680 MHz | |
| 30.720 MHz | |
| 30.760 MHz | |
| 30.800 MHz | |
| 30.880 MHz | |
| 30.920 MHz | |
| 30.960 MHz | |
| 31.000 MHz | |
| 31.040 MHz | |
| 31.080 MHz | |
| 31.120 MHz | |
| 31.160 MHz | |
| 31.200 MHz | |
| 31.240 MHz | |
| 31.280 MHz | |
| 31.320 MHz | |
| 31.360 MHz | |
| 31.400 MHz | |
| 31.440 MHz | |
| 31.480 MHz | |
| 31.520 MHz | |
| 31.560 MHz | |
| 31.600 MHz | |
| 31.640 MHz | |
| 31.680 MHz | |
| 31.720 MHz | |
| 31.760 MHz | |
| 31.800 MHz | |
| 31.840 MHz | |
| 31.880 MHz | |
| 31.920 MHz | |
| 31.960 MHz | |
| 33.160 MHz | |
| 33.180 MHz | |
| 33.200 MHz | |
| 33.220 MHz | |
| 33.240 MHz | |
| 33.260 MHz | |
| 33.280 MHz | |
| 33.300 MHz | |
| 33.320 MHz | |
| 33.340 MHz | |
| 33.360 MHz | |
| 33.380 MHz | |
| 35.060 MHz | |
| 35.080 MHz | |
| 35.100 MHz | |
| 35.120 MHz | |
| 35.160 MHz | |
| 35.180 MHz | |
| 35.280 MHz | |
| 35.320 MHz | |
| 35.360 MHz | |
| 35.400 MHz | |
| 35.440 MHz | |
| 35.480 MHz | |
| 35.520 MHz | |
| 35.700 MHz | |
| 35.720 MHz | |
| 35.740 MHz | |
| 35.760 MHz | |
| 35.780 MHz | |
| 35.820 MHz | |
| 35.840 MHz | |
| 35.860 MHz | |
| 35.880 MHz | |
| 35.900 MHz | |
| 35.920 MHz | |
| 35.940 MHz | |
| 35.960 MHz | |
| 35.980 MHz | |
| 37.440 MHz | |
| 37.460 MHz | |
| 37.480 MHz | |
| 37.500 MHz | |
| 37.520 MHz | |
| 37.520 MHz | |
| 37.560 MHz | |
| 37.580 MHz | |
| 37.620 MHz | |
| 37.640 MHz | |
| 37.660 MHz | |
| 37.680 MHz | |
| 37.700 MHz | |
| 37.720 MHz | |
| 37.760 MHz | |
| 37.780 MHz | |
| 37.800 MHz | |
| 37.820 MHz | |
| 37.840 MHz | |
| 37.860 MHz | |
| 37.880 MHz | |
| 42.960 MHz | |
| 43.000 MHz | |
| 43.020 MHz | |
| 43.060 MHz | |
| 43.080 MHz | |
| 43.100 MHz | |
| 43.120 MHz | |
| 43.140 MHz | |
| 43.180 MHz | |
| 43.280 MHz | |
| 43.320 MHz | |
| 43.360 MHz | |
| 43.400 MHz | |
| 43.440 MHz | |
| 43.480 MHz | |
| 43.520 MHz | |
| 43.700 MHz | |
| 43.760 MHz | |
| 43.780 MHz | |
| 43.860 MHz | |
| 43.880 MHz | |
| 43.900 MHz | |
| 43.940 MHz | |
| 44.000 MHz | |
| 44.020 MHz | |
| 44.040 MHz | |
| 44.060 MHz | |
| 44.080 MHz | |
| 44.140 MHz | |
| 44.220 MHz | |
| 44.240 MHz | |
| 44.260 MHz | |
| 44.280 MHz | |
| 44.300 MHz | |
| 44.340 MHz | |
| 44.380 MHz | |
| 44.440 MHz | |
| 44.500 MHz | |
| 44.520 MHz | |
| 44.540 MHz | |
| 44.560 MHz | |
| 44.600 MHz | |
| 47.440 MHz | |
| 47.480 MHz | |
| 47.520 MHz | |
| 47.560 MHz | |
| 47.600 MHz | |
| 47.640 MHz | |
| 47.680 MHz | |
| 47.700 MHz | |
| 47.720 MHz | |
| 47.740 MHz | |
| 47.760 MHz | |
| 47.780 MHz | |
| 47.800 MHz | |
| 47.820 MHz | |
| 47.840 MHz | |
| 47.860 MHz | |
| 47.880 MHz | |
| 47.900 MHz | |
| 47.920 MHz | |
| 47.940 MHz | |
| 47.960 MHz | |
| 47.980 MHz | |
| 48.000 MHz | |
| 48.020 MHz | |
| 48.040 MHz | |
| 48.060 MHz | |
| 48.080 MHz | |
| 48.100 MHz | |
| 48.120 MHz | |
| 48.140 MHz | |
| 48.160 MHz | |
| 48.180 MHz | |
| 48.200 MHz | |
| 48.220 MHz | |
| 48.240 MHz | |
| 48.260 MHz | |
| 48.280 MHz | |
| 48.300 MHz | |
| 48.320 MHz | |
| 48.340 MHz | |
| 48.360 MHz | |
| 48.380 MHz | |
| 48.400 MHz | |
| 48.420 MHz | |
| 48.440 MHz | |
| 48.480 MHz | |
| 48.500 MHz | |
| 48.520 MHz | |
| 48.540 MHz | |
| 48.560 MHz | |
| 48.580 MHz | |
| 48.600 MHz | |
| 48.620 MHz | |
| 48.640 MHz | |
| 48.660 MHz | |
| 48.680 MHz | |
| 48.700 MHz | |
| 48.720 MHz | |
| 48.740 MHz | |
| 48.760 MHz | |
| 48.780 MHz | |
| 48.800 MHz | |
| 48.820 MHz | |
| 48.840 MHz | |
| 48.860 MHz | |
| 48.880 MHz | |
| 48.900 MHz | |
| 48.920 MHz | |
| 48.940 MHz | |
| 48.960 MHz | |
| 48.980 MHz | |
| 49.000 MHz | |
| 49.020 MHz | |
| 49.040 MHz | |
| 49.060 MHz | |
| 49.080 MHz | |
| 49.100 MHz | |
| 49.120 MHz | |
| 49.140 MHz | |
| 49.160 MHz | |
| 49.180 MHz | |
| 49.200 MHz | |
| 49.220 MHz | |
| 49.240 MHz | |
| 49.260 MHz | |
| 49.280 MHz | |
| 49.300 MHz | |
| 49.320 MHz | |
| 49.340 MHz | |
| 49.360 MHz | |
| 49.380 MHz | |
| 49.400 MHz | |
| 49.420 MHz | |
| 49.440 MHz | |
| 49.480 MHz | |
| 49.500 MHz | |
| 49.520 MHz | |
| 49.540 MHz | |
| 49.560 MHz | |
| 49.580 MHz |
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.080 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.160 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.240 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.320 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 72.400 MHz |
| 154.505 MHz | |
| 154.515 MHz | |
| 154.585 MHz | |
| 154.610 MHz | |
| 154.625 MHz | |
| 154.640 MHz | |
| 157.470-157.725 MHz | 7.5 kHz steps, 157.5225 MHz to 157.725 MHz mobile/input freqs from old Taxicab Radio Service |
