MURS
Multi Use Radio Service
Were you looking for militia tactical radio channel plans? (MURS is an important part).
MURS Frequencies / Channels:
MURS Channel 2 MURS-2 151.880 MHz 11.25 kHz Recommended simplex repeater/crossband repeater channel (156.7 Hz CTCSS tone) and SAFETY channel - TX 210.7 Hz CTCSS 210.7 PL
MURS Channel 3 MURS-3 151.940 MHz 11.25 kHz Recommended prepper/emergency management/disaster response calling/working channel - TX 88.5 Hz CTCSS or 141.3 Hz CTCSS 141.3 PL
Digital Voice On MURS FAQ
  • Digital voice modes meet the bandwidth requirements for all 5 MURS channels.
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Despite their age, the Motorola CP110M series, Motorola RMM2050 and RDM2070D are still very popular jobsite radios. The RMM and RDM radios should not be confused with the Motorola RDV. RMV, RMU or RDU series radios (which require licenses to use).
  • 151.820 MHz (Output) 154.600 MHz (Input) - San Francisco area "MURS 82-60" or "MURSR" - MURS channel 1 output, MURS channel 5 repeater input +2.780 MHz offset (program RX 151.8200 MHz, TX 154.6000 MHz) - unknown CTCSS or PL tone
  • 151.880 MHz MURS Channel 2 151.88 MHz 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 Hz CTCSS. The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
  • 151.940 MHz MURS Channel 3 151.94 MHz 103.5 Hz CTCSS/PL - Oregon (additional information unconfirmed)
  • 151.940 MHz MURS Channel 3 151.94 MHz 156.7 Hz CTCSS/PL - Sacramento, CA area
