High HF and VHF/UHF Land mobile radio service authorized under Part 90 (Land Mobile Radio Services) of the FCC rules.   FCC eligibility verbiage states: Persons primarily engaged in any of the following activities are eligible to hold authorizations in the Industrial/Business Pool to provide commercial mobile radio service as defined in part 20 of this chapter or to operate stations for transmission of communications necessary to such activities of the licensee: (1) The operation commercial of business activity; (2) The operation of educational, philanthropic, or ecclesiastical institutions; (3) Clergy activities; or (4) The operation of hospitals, clinics, or medical associations.
| 25.020 MHz | |
| 25.040 MHz | |
| 25.060 MHz | |
| 25.080 MHz | |
| 25.100 MHz | |
| 25.120 MHz | |
| 25.140 MHz | |
| 25.160 MHz | |
| 25.180 MHz | |
| 25.200 MHz | |
| 25.220 MHz | |
| 25.240 MHz | |
| 25.260 MHz | |
| 25.280 MHz | |
| 25.300 MHz | |
| 25.320 MHz | |
| 27.430 MHz | |
| 27.450 MHz | |
| 27.470 MHz | |
| 29.710 MHz | |
| 29.730 MHz | |
| 29.750 MHz | |
| 29.770 MHz | |
| 29.790 MHz | |
| 30.580 MHz | |
| 30.600 MHz | |
| 30.620 MHz | |
| 30.680 MHz | |
| 30.720 MHz | |
| 30.760 MHz | |
| 30.800 MHz | |
| 30.880 MHz | |
| 30.920 MHz | |
| 30.960 MHz | |
| 31.000 MHz | |
| 31.040 MHz | |
| 31.080 MHz | |
| 31.120 MHz | |
| 31.160 MHz | |
| 31.200 MHz | |
| 31.240 MHz | |
| 31.280 MHz | |
| 31.320 MHz | |
| 31.360 MHz | |
| 31.400 MHz | |
| 31.440 MHz | |
| 31.480 MHz | |
| 31.520 MHz | |
| 31.560 MHz | |
| 31.600 MHz | |
| 31.640 MHz | |
| 31.680 MHz | |
| 31.720 MHz | |
| 31.760 MHz | |
| 31.800 MHz | |
| 31.840 MHz | |
| 31.880 MHz | |
| 31.920 MHz | |
| 31.960 MHz | |
| 33.160 MHz | |
| 33.180 MHz | |
| 33.200 MHz | |
| 33.220 MHz | |
| 33.240 MHz | |
| 33.260 MHz | |
| 33.280 MHz | |
| 33.300 MHz | |
| 33.320 MHz | |
| 33.340 MHz | |
| 33.360 MHz | |
| 33.380 MHz | |
| 35.060 MHz | |
| 35.080 MHz | |
| 35.100 MHz | |
| 35.120 MHz | |
| 35.160 MHz | |
| 35.180 MHz | |
| 35.280 MHz | |
| 35.320 MHz | |
| 35.360 MHz | |
| 35.400 MHz | |
| 35.440 MHz | |
| 35.480 MHz | |
| 35.520 MHz | |
| 35.700 MHz | |
| 35.720 MHz | |
| 35.740 MHz | |
| 35.760 MHz | |
| 35.780 MHz | |
| 35.820 MHz | |
| 35.840 MHz | |
| 35.860 MHz | |
| 35.880 MHz | |
| 35.900 MHz | |
| 35.920 MHz | |
| 35.940 MHz | |
| 35.960 MHz | |
| 35.980 MHz | |
| 37.440 MHz | |
| 37.460 MHz | |
| 37.480 MHz | |
| 37.500 MHz | |
| 37.520 MHz | |
| 37.520 MHz | |
| 37.560 MHz | |
| 37.580 MHz | |
| 37.620 MHz | |
| 37.640 MHz | |
| 37.660 MHz | |
| 37.680 MHz | |
| 37.700 MHz | |
| 37.720 MHz | |
| 37.760 MHz | |
| 37.780 MHz | |
| 37.800 MHz | |
| 37.820 MHz | |
| 37.840 MHz | |
| 37.860 MHz | |
| 37.880 MHz | |
| 42.960 MHz | |
| 43.000 MHz | |
| 43.020 MHz | |
| 43.060 MHz | |
| 43.080 MHz | |
| 43.100 MHz | |
| 43.120 MHz | |
| 43.140 MHz | |
| 43.180 MHz | |
| 43.280 MHz | |
| 43.320 MHz | |
| 43.360 MHz | |
| 43.400 MHz | |
| 43.440 MHz | |
| 43.480 MHz | |
| 43.520 MHz | |
| 43.700 MHz | |
| 43.760 MHz | |
| 43.780 MHz | |
| 43.860 MHz | |
| 43.880 MHz | |
| 43.900 MHz | |
| 43.940 MHz | |
| 44.000 MHz | |
| 44.020 MHz | |
| 44.040 MHz | |
| 44.060 MHz | |
| 44.080 MHz | |
| 44.140 MHz | |
| 44.220 MHz | |
| 44.240 MHz | |
| 44.260 MHz | |
| 44.280 MHz | |
| 44.300 MHz | |
| 44.340 MHz | |
| 44.380 MHz | |
| 44.420 MHz | |
| 44.440 MHz | |
| 44.500 MHz | |
| 44.520 MHz | |
| 44.540 MHz | |
| 44.560 MHz | |
| 44.600 MHz | |
| 47.440 MHz | |
| 47.480 MHz | |
| 47.520 MHz | |
| 47.560 MHz | |
| 47.600 MHz | |
| 47.640 MHz | |
| 47.680 MHz | |
| 47.700 MHz | |
| 47.720 MHz | |
| 47.740 MHz | |
| 47.760 MHz | |
| 47.780 MHz | |
| 47.800 MHz | |
| 47.820 MHz | |
| 47.840 MHz | |
| 47.860 MHz | |
| 47.880 MHz | |
| 47.900 MHz | |
| 47.920 MHz | |
| 47.940 MHz | |
| 47.960 MHz | |
| 47.980 MHz | |
| 48.000 MHz | |
| 48.020 MHz | |
| 48.040 MHz | |
| 48.060 MHz | |
| 48.080 MHz | |
| 48.100 MHz | |
| 48.120 MHz | |
| 48.140 MHz | |
| 48.160 MHz | |
| 48.180 MHz | |
| 48.200 MHz | |
| 48.220 MHz | |
| 48.240 MHz | |
| 48.260 MHz | |
| 48.280 MHz | |
| 48.300 MHz | |
| 48.320 MHz | |
| 48.340 MHz | |
| 48.360 MHz | |
| 48.380 MHz | |
| 48.400 MHz | |
| 48.420 MHz | |
| 48.440 MHz | |
| 48.480 MHz | |
| 48.500 MHz | |
| 48.520 MHz | |
| 48.540 MHz | |
| 48.560 MHz | |
| 48.580 MHz | |
| 48.600 MHz | |
| 48.620 MHz | |
| 48.640 MHz | |
| 48.660 MHz | |
| 48.680 MHz | |
| 48.700 MHz | |
| 48.720 MHz | |
| 48.740 MHz | |
| 48.760 MHz | |
| 48.780 MHz | |
| 48.800 MHz | |
| 48.820 MHz | |
| 48.840 MHz | |
| 48.860 MHz | |
| 48.880 MHz | |
| 48.900 MHz | |
| 48.920 MHz | |
| 48.940 MHz | |
| 48.960 MHz | |
| 48.980 MHz | |
| 49.000 MHz | |
| 49.020 MHz | |
| 49.040 MHz | |
| 49.060 MHz | |
| 49.080 MHz | |
| 49.100 MHz | |
| 49.120 MHz | |
| 49.140 MHz | |
| 49.160 MHz | |
| 49.180 MHz | |
| 49.200 MHz | |
| 49.220 MHz | |
| 49.240 MHz | |
| 49.260 MHz | |
| 49.280 MHz | |
| 49.300 MHz | |
| 49.320 MHz | |
| 49.340 MHz | |
| 49.360 MHz | |
| 49.380 MHz | |
| 49.400 MHz | |
| 49.420 MHz | |
| 49.440 MHz | |
| 49.480 MHz | |
| 49.500 MHz | |
| 49.520 MHz | |
| 49.540 MHz | |
| 49.560 MHz | |
| 49.580 MHz |
| Frequency (MHz) |
| 72.020 MHz |
| 72.040 MHz |
| 72.060 MHz |
| 72.080 MHz |
| 72.100 MHz |
| 72.120 MHz |
| 72.140 MHz |
| 72.160 MHz |
| 72.180 MHz |
| 72.200 MHz |
| 72.220 MHz |
| 72.240 MHz |
| 72.260 MHz |
| 72.280 MHz |
| 72.300 MHz |
| 72.320 MHz |
| 72.340 MHz |
| 72.360 MHz |
| 72.380 MHz |
| 72.400 MHz |
| 152.4725 MHz | |
| 154.4825 MHz | |
| 154.490 MHz | |
| 154.4975 MHz | |
| 154.515 MHz | |
| 154.5275 MHz | Mobiles |
| 154.540 MHz | |
| 154.5475 MHz | |
| 154.555 MHz | |
| 154.610 MHz | |
| 154.640 MHz | Mobiles |
| 157.7325 MHz | |
| 158.4525 MHz | |
| 158.460 MHz | |
| 173.2375 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.2625 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.2875 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.3125 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.3375 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.3625 MHz | May also be used for fixed data link, SCADA or other telemetry services |
| 173.390 MHz | Operational fixed (narrow band SCADA, data or telemetry only) |
| 173.39625 MHz | Operational fixed (narrow band SCADA, data or telemetry only) |
Like the UHF-T (UHF-TV) band 470-512 MHz, the 421-430 MHz band was allocated to alleviate pressure in large metro areas where frequency congestion is a significant problem.  Detroit, Cleveland and Buffalo are located near large Canadian cities.  Frequency coordination with Canada is performed for license authorization in these areas.
Often heard at construction sites, special events, shopping malls, stores, gas stations, etc.  There is also movement in the hunting community away from CB/11 meter and VHF marine towards licensed Part 90 land mobile/business radio systems.  See hunt club radio frequencies and American militia or patriot tactical frequencies.
Narrow band (12.5 kHz bandwidth) and low power (2 watts transmitter power for portable or handheld radios) simplex use of any of the 22 FRS frequencies is permitted license free. The old GMRS frequencies are labelled with their original color dot designation even though most users will simply refer to the FRS channel number. Regular "wide band" 25 kHz bandwidth (20K0F3E emission or 16K0F3E emission) may be used on the 7 GMRS simplex frequencies, although most FRS radios run NFM on those frequencies as well.
- Narrow digital voice and/or data modes include 11K2F9W (combined or mixed mode analog and digital), 11K0F1D (unspecified FSK or frequency-shift FM data), 8K30F1E (Icom IDAS wide 12.5 kHz channel voice, NEXEDGE wideband voice), 8K30F1D (Icom IDAS wide 12.5 kHz channel data, NEXEDGE wideband data), 8K30F7W (Icom IDAS wide 12.5 kHz channel combined voice/data, NEXEDGE 12.5 kHz channel wide combined voice/data), 4K00F1E (NXDN IDAS NEXEDGE 6.25 kHz narrow channel voice), 4K00F1D (NXDN IDAS NEXEDGE 6.25 kHz narrow channel data), 4K00F1W (NXDN IDAS NEXEDGE 6.25 kHz narrow channel combined voice and data), 7K60FXE (2-slot DMR TDMA - Motorola MotoTRBO TRBO voice), 7K60FXD (2-slot DMR TDMA - Motorola MotoTRBO TRBO data), 7K60FXW (2-slot DMR TDMA - Motorola MotoTRBO TRBO voice and data combined), 8K10F1E (Project 25 P25 Phase I digital voice C4FM), 8K10F1D (Project 25 P25 Phase I digital data C4FM), 5K76G1E (Project 25 P25 CQPSK digital voice) and variations of these emissions.
The most commonly found ones are narrow FM, DMR, IDAS or NXDN and P25 digital voice and data emissions.
 - 151.5125 MHz - Itinerant
 - 151.6400 MHz - Itinerant - narrow band only, maximum bandwidth 6.25 kHz (generally 6K00F3E, 4K00F1E, 4K00F1D, etc.)
 - 151.6550 MHz
 - 151.6850 MHz
 - 151.7150 MHz
 - 151.7450 MHz
 - 151.7750 MHz
 - 151.8050 MHz
 - 151.8350 MHz
 - 151.8650 MHz
 - 151.8950 MHz
 - 151.9250 MHz
 - 151.9550 MHz - Purple Dot
 - 152.8850 MHz
 - 152.9000 MHz
 - 152.9150 MHz
 - 152.9450 MHz
 - 153.0050 MHz
 - 154.4900 MHz
 - 154.5150 MHz
 - 154.5400 MHz
 - 154.5475 MHz
 - 158.4000 MHz - Itinerant
 - 158.4075 MHz - Itinerant
 - 451.1875 MHz
 - 451.2375 MHz
 - 451.2875 MHz
 - 451.3375 MHz
 - 451.4375 MHz
 - 451.5375 MHz
 - 451.6375 MHz
 - 452.3125 MHz
 - 452.4125 MHz
 - 452.5125 MHz
 - 452.5375 MHz
 - 452.7625 MHz
 - 452.8625 MHz
 - 456.1875 MHz
 - 456.2375 MHz
 - 456.2875 MHz
 - 456.3375 MHz
 - 456.4375 MHz
 - 456.5375 MHz
 - 456.6375 MHz
 - 457.3125 MHz
 - 457.4125 MHz
 - 457.5125 MHz
 - 457.6375 MHz
 - 457.6625 MHz
 - 457.7125 MHz
 - 457.7375 MHz
 - 457.7625 MHz
 - 457.8625 MHz
 - 461.0375 MHz
 - 461.0625 MHz
 - 461.0875 MHz
 - 461.1125 MHz
 - 461.1375 MHz
 - 461.1625 MHz
 - 461.1875 MHz
 - 461.2125 MHz
 - 461.2375 MHz
 - 461.2625 MHz
 - 461.2875 MHz
 - 461.3125 MHz
 - 461.3375 MHz
 - 461.3625 MHz
 - 462.1875 MHz
 - 462.4625 MHz
 - 462.4875 MHz
 - 462.5125 MHz
 - 464.4875 MHz - Itinerant
 - 464.5125 MHz - Itinerant
 - 464.5375 MHz - Itinerant
 - 464.5625 MHz - Itinerant
 - 466.0375 MHz
 - 466.0625 MHz
 - 466.0875 MHz
 - 466.1125 MHz
 - 466.1375 MHz
 - 466.1625 MHz
 - 466.1875 MHz
 - 466.2125 MHz
 - 466.2375 MHz
 - 466.2625 MHz
 - 466.2875 MHz
 - 466.3125 MHz
 - 466.3375 MHz
 - 466.3625 MHz
 - 467.1875 MHz
 - 467.4625 MHz
 - 467.4875 MHz
 - 467.5125 MHz
 - 468.2125 MHz
 - 468.2625 MHz
 - 468.3125 MHz
 - 468.3375 MHz
 - 468.3625 MHz
 - 468.4125 MHz
 - 468.4625 MHz
 - 468.5125 MHz
 - 468.5625 MHz
 - 468.5875 MHz
 - 468.6125 MHz
 - 468.6375 MHz
 - 469.4875 MHz - Itinerant
 - 469.5125 MHz - Itinerant
 - 469.5375 MHz - Itinerant
 - 469.5625 MHz - Itinerant
Do I need a license to transmit on 151.625 MHz? Yes, you do.  You need a license to use all the business band frequencies, including 151.625 MHz, 151.505 MHz, 158.400 MHz, 151.955 MHz, 151.700 MHz, 151.760 MHz, 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.875 MHz, 467.900 MHz, etc.  Only the 22 FRS frequencies, the 5 MURS frequencies and the 40 CB channels do not require a license.  Getting a business license for the Itinerant channels is extremely easy.
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Retevis RT-68 FRS 16 channel
- Channel 1 - 400.1250 MHz
 - Channel 2 - 410.1250 MHz
 - Channel 3 - 420.1250 MHz
 - Channel 4 - 430.1250 MHz
 - Channel 5 - 440.1250 MHz
 - Channel 6 - 450.1250 MHz
 - Channel 7 - 460.1250 MHz
 - Channel 8 - 470.1250 MHz
 - Channel 9 - 480.1250 MHz
 - Channel 10 - 490.1250 MHz
 - Channel 11 - 500.1250 MHz
 - Channel 12 - 510.1250 MHz
 - Channel 13 - 519.9750 MHz
 - Channel 14 - 136.1250 MHz
 - Channel 15 - 145.1250 MHz
 - Channel 16 - 155.1250 MHz
 - Channel 17 - 165.1250 MHz
 - Channel 18 - 173.9750 MHz
 - Channel 14 - 471.8900 MHz 67.0 Hz PL - 471.8875 MHz
Rental radios commonly use the UHF itinerant frequencies, along with the local control channels:
- 451.4000 MHz
 - 451.4125 MHz
 - 451.8000 MHz
 - 451.8125 MHz
 - 464.3250 MHz
 - 464.3750 MHz
 - 464.4250 MHz
 - 464.4750 MHz
 - 464.5000 MHz
 - 464.5250 MHz
 - 464.5500 MHz
 - 464.5750 MHz
 - 464.6750 MHz
 - 464.7000 MHz
 - 464.7500 MHz
 - 464.7750 MHz
 - 464.8250 MHz
 - 464.8500 MHz
 - 464.8750 MHz
 - 464.9250 MHz
 - 464.9750 MHz
 - 469.5000 MHz
 - 469.5500 MHz
Rental radios will often be programmed with a mixture of the low-power UHF itinerants, FRS/GMRS channels (often 462.575 MHz, 462.625 MHz, 462.675 MHz and 462.725 MHz) and local control channels. FRS channel 8-14 are popular as well. Larger events will utilize portable repeaters. The high power UHF itinerant pairs 451.800 MHz, 451.8125 MHz, 464.500 MHz and 464.550 MHz are popular for portable repeaters, but often those frequencies will be set aside for simplex use with a different 464.xxxx MHz frequency used as a dedicated repeater frequency. 452.xxxx MHz, 457.xxxx MHz, 461.xxxx MHz, 462.xxxx MHz, 466.xxxx MHz, 467.xxxx MHz and 469.xxxx MHz are also popular bands. Radio rental companies have rented radios with the "secret" guard band frequencies 462.5375 MHz, 462.7375 MHz, 467.5375 MHz and 467.7375 MHz programmed in for larger events. 462.5375 MHz and 462.7375 MHz are used, under FCC waivers, for large trunking systems (only with narrowband digital modes such as TRBO, DMR or NXDN/IDAS digital voice.
- Freq 1 - 464.5000 MHz
 - Freq 2 - 464.5500 MHz
 - Freq 3 - 467.7625 MHz
 - Freq 4 - 467.8125 MHz
 - Freq 5 - 467.8500 MHz
 - Freq 6 - 467.8750 MHz
 - Freq 7 - 467.9000 MHz
 - Freq 8 - 467.9250 MHz
 - Freq 9 - 461.0375 MHz
 - Freq 10 - 461.0625 MHz
 - Freq 11 - 461.0875 MHz
 - Freq 12 - 461.1125 MHz
 - Freq 13 - 461.1375 MHz
 - Freq 14 - 461.1625 MHz
 - Freq 15 - 461.1875 MHz
 - Freq 16 - 461.2125 MHz
 - Freq 17 - 461.2375 MHz
 - Freq 18 - 461.2625 MHz
 - Freq 19 - 461.2875 MHz
 - Freq 20 - 461.3125 MHz
 - Freq 21 - 461.3375 MHz
 - Freq 22 - 461.3625 MHz
 - Freq 23 - 462.7625 MHz
 - Freq 24 - 462.7875 MHz
 - Freq 25 - 462.8125 MHz
 - Freq 26 - 462.8375 MHz
 - Freq 27 - 462.8625 MHz
 - Freq 28 - 462.8875 MHz
 - Freq 29 - 462.9125 MHz
 - Freq 30 - 464.4875 MHz
 - Freq 31 - 464.5125 MHz
 - Freq 32 - 464.5375 MHz
 - Freq 33 - 464.5625 MHz
 - Freq 34 - 466.0375 MHz
 - Freq 35 - 466.0625 MHz
 - Freq 36 - 466.0875 MHz
 - Freq 37 - 466.1125 MHz
 - Freq 38 - 466.1375 MHz
 - Freq 39 - 466.1625 MHz
 - Freq 40 - 466.1875 MHz
 - Freq 41 - 466.2125 MHz
 - Freq 42 - 466.2375 MHz
 - Freq 43 - 466.2625 MHz
 - Freq 44 - 466.2875 MHz
 - Freq 45 - 466.3125 MHz
 - Freq 46 - 466.3375 MHz
 - Freq 47 - 466.3625 MHz
 - Freq 48 - 467.7875 MHz
 - Freq 49 - 467.8375 MHz
 - Freq 50 - 467.8625 MHz
 - Freq 51 - 467.8875 MHz
 - Freq 52 - 467.9125 MHz
 - Freq 53 - 469.4875 MHz
 - Freq 54 - 469.5125 MHz
 - Freq 55 - 469.5375 MHz
 - Freq 56 - 469.5625 MHz
 - Freq 9 - 462.5750 MHz
 - Freq 10 - 462.6250 MHz
 - Freq 11 - 462.6750 MHz
 - Freq 12 - 464.3250 MHz
 - Freq 13 - 464.8250 MHz
 - Freq 14 - 469.2625 MHz
 - Freq 15 - 469.5000 MHz
 - Freq 16 - 469.5500 MHz
 - Freq 17 - 462.7625 MHz
 - Freq 18 - 462.7875 MHz
 - Freq 19 - 462.8125 MHz
 - Freq 20 - 462.8375 MHz
 - Freq 21 - 462.8625 MHz
 - Freq 22 - 462.8875 MHz
 - Freq 23 - 462.9125 MHz
 - Freq 24 - 464.4875 MHz
 - Freq 25 - 461.0375 MHz
 - Freq 26 - 461.0625 MHz
 - Freq 27 - 461.0875 MHz
 - Freq 28 - 461.1125 MHz
 - Freq 29 - 461.1375 MHz
 - Freq 30 - 461.1625 MHz
 - Freq 31 - 461.1875 MHz
 - Freq 32 - 461.2125 MHz
 - Freq 33 - 461.2375 MHz
 - Freq 34 - 461.2625 MHz
 - Freq 35 - 461.2875 MHz
 - Freq 36 - 461.3125 MHz
 - Freq 37 - 461.3375 MHz
 - Freq 38 - 461.3625 MHz
 - Freq 39 - 462.7625 MHz
 - Freq 40 - 462.7875 MHz
 - Freq 41 - 462.8125 MHz
 - Freq 42 - 462.8375 MHz
 - Freq 43 - 462.8625 MHz
 - Freq 44 - 462.8875 MHz
 - Freq 45 - 462.9125 MHz
 - Freq 46 - 464.4875 MHz
 - Freq 47 - 464.5125 MHz
 - Freq 48 - 464.5375 MHz
 - Freq 49 - 464.5625 MHz
 - Freq 50 - 466.0375 MHz
 - Freq 51 - 466.0625 MHz
 - Freq 52 - 466.0875 MHz
 - Freq 53 - 466.1125 MHz
 - Freq 54 - 466.1375 MHz
 - Freq 55 - 466.1625 MHz
 - Freq 56 - 466.1875 MHz
- Freq 1 - 151.6250 MHz
 - Freq 2 - 151.9550 MHz
 - Freq 3 - 154.5700 MHz
 - Freq 4 - 154.6000 MHz
 - Freq 5 - 151.7000 MHz
 - Freq 6 - 151.7600 MHz
 - Freq 7 - 151.8200 MHz
 - Freq 8 - 151.8800 MHz
 - Freq 9 - 151.9400 MHz
 - Freq 10 - 151.5125 MHz
 - Freq 11 - 151.6550 MHz
 - Freq 12 - 151.6850 MHz
 - Freq 13 - 151.7150 MHz
 - Freq 14 - 151.7450 MHz
 - Freq 15 - 151.7750 MHz
 - Freq 16 - 151.8650 MHz
 - Freq 17 - 151.8950 MHz
 - Freq 18 - 151.9250 MHz
 - Freq 20 - 154.4900 MHz
 - Freq 21 - 154.5150 MHz
 - Freq 22 - 154.5275 MHz
 - Freq 23 - 154.5400 MHz
 - Freq 24 - 154.6000 MHz
 - Freq 26 - 158.4000 MHz
 - Freq 27 - 158.4075 MHz
 - Freq 57 - 462.1875 MHz
 - Freq 58 - 462.4625 MHz
 - Freq 59 - 462.4875 MHz
 - Freq 60 - 462.5125 MHz
 - Freq 61 - 467.1875 MHz
 - Freq 62 - 467.4625 MHz
 - Freq 63 - 467.4875 MHz
 - Freq 64 - 467.5125 MHz
 - Freq 65 - 451.1875 MHz
 - Freq 66 - 451.2375 MHz
 - Freq 67 - 451.2875 MHz
 - Freq 68 - 451.3375 MHz
 - Freq 69 - 451.4375 MHz
 - Freq 70 - 451.5375 MHz
 - Freq 71 - 451.6375 MHz
 - Freq 72 - 452.3125 MHz
 - Freq 73 - 452.5375 MHz
 - Freq 74 - 452.4125 MHz
 - Freq 75 - 452.5125 MHz
 - Freq 76 - 452.7625 MHz
 - Freq 77 - 452.8625 MHz
 - Freq 78 - 456.1875 MHz
 - Freq 79 - 456.2375 MHz
 - Freq 80 - 456.2875 MHz
 - Freq 81 - 468.2125 MHz
 - Freq 82 - 468.2625 MHz
 - Freq 83 - 468.3125 MHz
 - Freq 84 - 468.3625 MHz
 - Freq 85 - 468.4125 MHz
 - Freq 86 - 468.4625 MHz
 - Freq 87 - 468.5125 MHz
 - Freq 88 - 468.5625 MHz
 - Freq 89 - 468.6125 MHz
 - Freq 90 - 468.6625 MHz
 - Freq 81 - 456.3375 MHz
 - Freq 82 - 456.4375 MHz
 - Freq 83 - 456.5375 MHz
 - Freq 84 - 456.6375 MHz
 - Freq 85 - 457.3125 MHz
 - Freq 86 - 457.4125 MHz
 - Freq 87 - 457.5125 MHz
 - Freq 88 - 457.7625 MHz
 - Freq 89 - 457.8625 MHz
 - Freq 3 - 152.8850 MHz
 - Freq 4 - 152.9150 MHz
 - Freq 7 - 152.9450 MHz
 - Freq 8 - 151.8350 MHz
 - Freq 9 - 151.8050 MHz
 - Freq 24 - 153.0050 MHz
 - Code 1 - 67.0 Hz PL - XZ
 - Code 2 - 71.9 Hz PL - XA
 - Code 3 - 74.4 Hz PL - WA
 - Code 4 - 77.0 Hz PL - XB
 - Code 5 - 79.7 Hz PL - WB
 - Code 6 - 82.5 Hz PL - YZ
 - Code 7 - 85.4 Hz PL - YA
 - Code 8 - 88.5 Hz PL - YB
 - Code 9 - 91.5 Hz PL - ZZ
 - Code 10 - 94.8 Hz PL - ZA
 - Code 11 - 97.4 Hz PL - ZB
 - Code 12 - 100.0 Hz PL - 1Z
 - Code 13 - 103.5 Hz PL - 1A
 - Code 14 - 107.2 Hz PL - 2Z
 - Code 15 - 110.9 Hz PL - 2Z
 - Code 16 - 114.8 Hz PL - 2A
 - Code 17 - 118.8 Hz PL - 2B
 - Code 18 - 123.0 Hz PL - 3Z
 - Code 19 - 127.3 Hz PL - 3A
 - Code 20 - 131.8 Hz PL - 3B
 - Code 21 - 136.5 Hz PL - 4Z
 - Code 22 - 141.3 Hz PL - 4A
 - Code 23 - 146.2 Hz PL - 4B
 - Code 24 - 151.4 Hz PL - 5Z
 - Code 25 - 156.7 Hz PL - 5A
 - Code 26 - 162.2 Hz PL - 5B
 - Code 27 - 167.9 Hz PL - 6Z
 - Code 28 - 173.8 Hz PL - 6A
 - Code 29 - 179.9 Hz PL - 6B
 - Code 30 - 186.2 Hz PL - 7Z
 - Code 31 - 192.8 Hz PL - 7A
 - Code 32 - 203.5 Hz PL - M1
 - Code 33 - 210.7 Hz PL - M2
 - Code 34 - 218.1 Hz PL - M3
 - Code 35 - 225.7 Hz PL - M4
 - Code 36 - 233.6 Hz PL - M5
 - Code 37 - 241.8 Hz PL - M6
 - Code 38 - 250.3 Hz PL - M7
 - Code 39 - 023 DPL
 - Code 40 - 025 DPL
 - Code 41 - 026 DPL
 - Code 42 - 031 DPL
 - Code 43 - 032 DPL
 - Code 44 - 043 DPL
 - Code 45 - 047 DPL
 - Code 46 - 051 DPL
 - Code 47 - 054 DPL
 - Code 48 - 065 DPL
 - Code 49 - 071 DPL
 - Code 50 - 072 DPL
 - Code 51 - 073 DPL
 - Code 52 - 074 DPL
 - Code 53 - 114 DPL
 - Code 54 - 115 DPL
 - Code 55 - 116 DPL
 - Code 56 - 125 DPL
 - Code 57 - 131 DPL
 - Code 58 - 132 DPL
 - Code 59 - 134 DPL
 - Code 60 - 143 DPL
 - Code 61 - 152 DPL
 - Code 62 - 155 DPL
 - Code 63 - 156 DPL
 - Code 64 - 162 DPL
 - Code 65 - 165 DPL
 - Code 66 - 172 DPL
 - Code 67 - 174 DPL
 - Code 68 - 205 DPL
 - Code 69 - 223 DPL
 - Code 70 - 226 DPL
 - Code 71 - 243 DPL
 - Code 72 - 244 DPL
 - Code 73 - 245 DPL
 - Code 74 - 251 DPL
 - Code 75 - 261 DPL
 - Code 76 - 263 DPL
 - Code 77 - 265 DPL
 - Code 78 - 271 DPL
 - Code 79 - 306 DPL
 - Code 80 - 311 DPL
 - Code 81 - 315 DPL
 - Code 82 - 331 DPL
 - Code 83 - 343 DPL
 - Code 84 - 346 DPL
 - Code 85 - 351 DPL
 - Code 86 - 364 DPL
 - Code 87 - 365 DPL
 - Code 88 - 371 DPL
 - Code 89 - 411 DPL
 - Code 90 - 412 DPL
 - Code 91 - 413 DPL
 - Code 92 - 423 DPL
 - Code 93 - 431 DPL
 - Code 94 - 432 DPL
 - Code 95 - 445 DPL
 - Code 96 - 464 DPL
 - Code 97 - 465 DPL
 - Code 98 - 466 DPL
 - Code 99 - 503 DPL
 - Code 100 - 506 DPL
 - Code 101 - 516 DPL
 - Code 102 - 532 DPL
 - Code 103 - 546 DPL
 - Code 104 - 565 DPL
 - Code 105 - 606 DPL
 - Code 106 - 612 DPL
 - Code 107 - 624 DPL
 - Code 108 - 627 DPL
 - Code 109 - 631 DPL
 - Code 110 - 632 DPL
 - Code 111 - 654 DPL
 - Code 112 - 662 DPL
 - Code 113 - 664 DPL
 - Code 114 - 703 DPL
 - Code 115 - 712 DPL
 - Code 116 - 723 DPL
 - Code 117 - 731 DPL
 - Code 118 - 732 DPL
 - Code 119 - 734 DPL
 - Code 120 - 743 DPL
 - Code 121 - 754 DPL
- Freq 0 - OFF (BLANK)
