FRS
Family Radio Service
Ch | Freq MHz | - Notes - |
1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
20 | 462.6750 | Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power |
21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a "monitor" or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours).
These wireless intercom systems generally include a GROUP CALL or HOME channel feature, that switches all intercoms to a dedicated channel/code combination.
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz PL
- Code 2 - 69.3 Hz PL
- Code 3 - 67.0 Hz PL
- CHANNEL 1 - 462.5625 MHz
- Code 3 - 67.0 PL
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- Calford Technology Ltd. AF333 wireless intercom
234mw power output, 11K0F3E emission
- Calford Technology Ltd. AF411 wireless intercom
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- SAMCOM / SANCON FTAN10AA 10 channel wireless intercom
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz PL
- Code B - 136.5 Hz PL
- Code C - 186.2 Hz PL
- SAMCOM / SANCON FTAN20AA 20 channel wireless intercom
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same code.
- Shenzhen Macros Industrial Co. Ltd. WL666 or LD666 wireless intercom
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
