PMR446
Revision as of 18:57, 9 May 2020 by R4002 (Talk | contribs)
Analog and digital license-free low power radio service, similar to the 462 MHz - 467 MHz FRS and GMRS services in the United States, the 477 MHz UHF CB in Australia and New Zealand, the 448 MHz South Korean Personal Radio Service and several other UHF band license free two-way walkie-talkie radio services.
PMR446 was originally assigned 8 analog FM voice channels from 446.0 MHz to 446.1 MHz then expanded to 16 analog/digital channels + 32 digital only voice/data channels in the 446.0 to 446.2 MHz range for a total of 48 channels.
Channel Freq MHz
1 446.00625 MHz
2 446.01875 MHz
3 446.03125 MHz
4 446.04375 MHz
5 446.05625 MHz
6 446.06875 MHz
7 446.08125 MHz
8 446.09375 MHz
9 446.10625 MHz
10 446.11875 MHz
11 446.13125 MHz
12 446.14375 MHz
13 446.15625 MHz
14 446.16875 MHz
15 446.18125 MHz
16 446.19375 MHz
Digital FDMA dPMR446
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s (3600 baud). These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital dPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
Channel Freq MHz
1 446.003125 MHz
2 446.009375 MHz
3 446.015625 MHz
4 446.021875 MHz
5 446.028125 MHz
6 446.034375 MHz
7 446.040625 MHz
8 446.046875 MHz
9 446.053125 MHz
10 446.059375 MHz
11 446.065625 MHz
12 446.071875 MHz
13 446.078125 MHz
14 446.084375 MHz
15 446.090625 MHz
16 446.096875 MHz
17 446.103125 MHz
18 446.109375 MHz
19 446.115625 MHz
20 446.121875 MHz
21 446.128125 MHz
22 446.134375 MHz
23 446.140625 MHz
24 446.146875 MHz
25 446.153125 MHz
26 446.159375 MHz
27 446.165625 MHz
28 446.171875 MHz
29 446.178125 MHz
30 446.184375 MHz
31 446.190625 MHz
32 446.196875 MHz
  • Channel 1 - 446.00625 MHz - “Children’s Channel” - baby monitors, etc.
Authorized PMR446 Countries
