11 meter
Revision as of 17:07, 21 May 2020 by R4002 (Talk | contribs)
The 11 meter band is used by both CB radio, as well as freeband unlicensed hobbyists, Church radio broadcasts in Ireland and elsewhere in Europe, the military, for studio-to-transmitter links (STLs), data links, buoys, fishnet tracking systems, pagers and other non-voice purposes.
Aside from legal CB allocations and freebanding (or outbanding), there are several legal licensed services allocated to this interesting chunk of spectrum. This includes paging services, government, military, HF marine and FM land mobile. In the United States, the following bands are allocated for licensed use in the United States. The United States Government has exclusive usage rights to the 25.33 MHz-25.55 MHz band, the 26.48 MHz-26.95 MHz band, the 27.54 MHz-28.0 MHz band, the 29.89 MHz-29.91 MHz band and the 30.0 MHz-30.56 MHz band.
25.330 MHz to 25.550 MHz 25330 kHz to 25550 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks, eg. 25.354 MHz 25354 kHz
25.550 MHz to 25.670 MHz 25550 kHz to 25670 kHz Radio Astronomy and is supposed to be clear of stations (in reality, its not, since most export radios start at 25.615 MHz)
25.600 MHz to 26.100 MHz 25600 kHz to 26100 kHz 11 meter shortwave broadcast band SWBC or HFBC band. Rarely used. Some DRM tests done here. No US-based stations operate here. Previously 25600 kHz to 25670 kHz (25.6 MHz to 25.67 MHz)
25.870 MHz to 26.470 MHz 25870 kHz to 26470 kHz Remote Broadcast Pickup (Studio Transmitter Link or STL) service (overlaps with 11 meter broadcast band and HF marine) channelized 25.91 MHz, 25.93 MHz, 25.95 MHz, 25.97 MHz, 25.99 MHz, 26.01 MHz, 26.03 MHz, etc.
26.480 MHz to 26.950 MHz 26480 kHz to 26950 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks eg. 26.617 MHz, 26.620 MHz, 26.812 MHz, etc.
26.560 MHz to 27.410 MHz 26560 kHz to 27410 kHz Citizen's Band - CB radio - Germany, Czech Republic and other European countries (80 channels 26.565 MHz - 27.405 MHz)
26.957 MHz to 27.283 MHz 26957 kHz to 27283 kHz ISM Band (27.120 MHz +/- 163 kHz, see FCC Part 18)
26.960 MHz to 27.860 MHz 26960 kHz to 27860 kHz Citizen's Band - CB radio - Brazil and other Latin American countries (80 channels 26.965 MHz - 27.855 MHz)
27.430 MHz to 27.540 MHz 27410 kHz to 27540 kHz Business/Industrial Radio Service (20 kHz steps, FM mode)
27.540 MHz to 28.000 MHz 27540 kHz to 28000 kHz Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz
27.59625 MHz to 27.99625 MHz 27596.25 kHz to 27996.25 kHz Citizen's Band - CB radio - United Kingdom UK CB 27/81 UK FM CB 27.60125 MHz - 27.99125 MHz 40 channels
27.600 MHz to 28.0 MHz 27600 kHz to 27995 kHz Community Audio Distribution Service and Wireless Public Address Service (UK and Ireland) - 27.605 MHz - 27.995 MHz and 27.60125 MHz - 27.99125 MHz - 80 interleaved overlapping channels AM/FM
29.700 MHz to 29.800 MHz 29700 kHz to 29800 kHz Business/Industrial Radio Service (29.71 MHz to 29.79 MHz - 20 kHz steps, FM mode)
29.810 MHz to 29.910 MHz 29810 kHz to 29910 kHz Government and military fixed/mobile, including SHARES frequency 29.894 MHz 29894 kHz
29.800 MHz to 30.550 MHz 29800 kHz to 30550 kHz Government and military fixed/mobile, including SINCGARS above 30.000 MHz
What are the freeband CB frequencies? Freeband CB channels CB frequencies on a ham radio is CB 10 meter is CB 11 meter freebanding CB channels CB channels police CB channels ham radio Baofeng CB CB-27 PR-27 taxi cab radio Uber Lyft radio two-way radio walkie-talkie FRS GMRS UHF VHF MURS VHF245 PMR446 KDR444 409 MHz band 406 MHz
  • 25.615 MHz - 26.055 MHz - Band A - often used by taxi cabs and trucking companies (AM mode in the Americas, AM or FM elsewhere)
  • 26.065 MHz - 26.505 MHz - Band B - often used by taxi cabs, trucking companies and hunting clubs
  • 26.305 MHz AM - Latin American (and American) AM activity
  • 26.500 MHz LSB - Caribbean and Latin American calling/working frequency
  • 26.500 MHz USB - Caribbean and Latin American calling/working frequency
  • 26.515 MHz - 26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
  • 26.565 MHz - 26.955 MHz - German CB channels 41-80, FM mode only, heavily used in Europe
  • 26.565 MHz FM - German FM CB DX calling channel (Channel 41)
  • 26.575 MHz FM - German FM CB DX calling channel (Channel 42)
  • 26.740 MHz LSB - European packet and PSK31 frequency
  • 26.810 MHz LSB - European packet and PSK31 frequency
  • 26.820 MHz LSB - European packet and PSK31 frequency
  • 26.830 MHz LSB - European packet and PSK31 frequency
  • 26.840 MHz LSB - European packet and PSK31 frequency
  • 26.905 MHz AM - alternate to 26.915 MHz, others, Mexican taxicab dispatcher lady also logged on this frequency
  • 26.965 MHz - 27.405 MHz - Band D - legal CB band - "mid band", "FCC band" or "CEPT" band
  • 27.135 MHz AM - Russian Trucker channel (see also 27.135 MHz FM, 27.180 MHz)
  • 27.235 MHz FM - European packet PSK31 channel - channel 24
  • 27.235 MHz USB - Swedish and Nordic SSB calling Sweden
  • 27.235 MHz USB - European digital modes ROS data modes channel
  • 27.245 MHz FM - European packet PSK31 channel
  • 27.245 MHz USB - European digital modes ROS data modes channel
  • 27.275 MHz USB - UK SSB calling England mid band SSB frequency ch. 27
  • 27.285 MHz USB - Finland SSB calling
  • 27.315 MHz AM - CB channel 31 - AM DX calling channel (secondary)
  • 27.315 MHz FM - European FM calling channel
  • 27.355 MHz LSB - CB channel 35 - SSB DX calling channel Australia and Oceania
  • 27.405 MHz - 27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
  • 27.465 MHz AM - Italian high power channel - canal 45 - similar to 27.025 MHz or 26.705/26.715 MHz in the Americas
  • 27.500 MHz LSB - Caribbean and Latin American calling/working frequency (see also: 26.225 MHz USB, 26.555 MHz LSB)
  • 27.500 MHz USB - Caribbean and Latin American calling/working frequency
  • 27.500 MHz AM or CW - unofficial 11 meter beacon frequency
  • 27.580 MHz USB - Knight Patrol club frequency (see also: 27.515 LSB)
  • 27.60125 MHz - 27.99125 MHz - UK FM 27/81 CB (UK only) also CADS/WPAS Channels LW01-LW40 UK, Ireland (AM/FM modes, Church broadcasts) straight 10 kHz channel steps
  • 27.605 MHz - 27.995 MHz - CADS/WPAS Channels UW01-UW40 UK, Ireland and elsewhere straight 10 kHz channel steps
  • 27.635 MHz USB - digital modes found here in Europe (ROS, PSK31)
  • 27.635 MHz AM - CB channel 19 "up one band" - truckers are often heard here (see also 26.735 MHz, 28.085 MHz, 25.635 MHz, 26.285 MHz)
  • 27.765 MHz FM - “Deutsche Welle”, German speaking stations out of band freeband
  • 27.765 MHz USB - “Deutsche Welle” SSB freebanders
  • 27.855 MHz - 28.305 MHz - Band F - up to 27.995 MHz (channel 11A) popular with taxicabs and truckers, although truckers are often heard above 28.000 MHz it is strongly advised that freebanders stay below 28 MHz
Federal and Non-Federal Allocations 25 MHz to 30 MHz
  • Allocated Exclusively To Federal Government Use:
  • 24995 kHz to 25005 kHz 24.995 MHz to 25.005 MHz - WWV 25.000 MHz 25000 kHz
  • 25330 kHz to 25550 kHz 25.330 MHz to 25.550 MHz
  • 26480 kHz to 26950 kHz 26.480 MHz to 26.950 MHz
  • 27540 kHz to 28000 kHz 27.540 MHz to 28.000 MHz
  • 29890 kHz to 29910 kHz 29.890 MHz to 29.910 MHz
  • 30000 kHz to 30560 kHz 30.000 MHz to 30.560 MHz
  • 32000 kHz to 33000 kHz 32.000 MHz to 33.000 MHz
  • 34000 kHz to 35000 kHz 34.000 MHz to 35.000 MHz
  • Allocated Exclusively To Non-Federal Use:
  • 24890 kHz to 24990 kHz 24.890 MHz to 24.990 MHz
  • 25005 kHz to 25010 kHz 25.005 MHz to 25.010 MHz
  • 25210 kHz to 25330 kHz 25.210 MHz to 25.330 MHz
  • 26175 kHz to 26480 kHz 26.175 MHz to 26.480 MHz
  • 26950 kHz to 27540 kHz 26.950 MHz to 27.540 MHz
  • 28000 kHz to 29700 kHz 28.000 MHz to 29.700 MHz
  • 29700 kHz to 29890 kHz 29.700 MHz to 29.890 MHz
  • 29910 kHz to 30000 kHz 29.910 MHz to 30.000 MHz
