Military ISR
Originally intended to be a military only FRS type intra squad radio service.
- Channel 1 - 396.875 MHz
 - Channel 2 - 397.125 MHz
 - Channel 3 - 397.175 MHz
 - Channel 4 - 397.375 MHz
 - Channel 5 - 397.425 MHz
 - Channel 6 - 397.475 MHz
 - Channel 7 - 397.550 MHz
 - Channel 8 - 397.950 MHz
 - Channel 9 - 398.050 MHz
 - Channel 10 - 399.425 MHz
 - Channel 11 - 399.475 MHz
 - Channel 12 - 399.725 MHz
 - Channel 13 - 399.925 MHz
 - Channel 14 - 399.975 MHz
Not to be confused with VHF/UHF militia patriot radio channel plans squad radio and 16 channel UHF low power intra-squad radio (Baofeng UV-5R, UV-82, VHF/UHF handheld COTS radios, etc.)
