49 MHz RC Frequencies
- 72.010 MHz
- 72.030 MHz
- 72.050 MHz
- 72.070 MHz
- 72.090 MHz
- 72.110 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.230 MHz
- 72.250 MHz
- 72.270 MHz
- 72.290 MHz
- 72.310 MHz
- 72.330 MHz
- 72.350 MHz
- 72.370 MHz
- 72.390 MHz
- 72.410 MHz
- 72.430 MHz
- 72.450 MHz
- 72.470 MHz
- 72.490 MHz
- 72.510 MHz
- 72.530 MHz
- 72.550 MHz
- 72.570 MHz
- 72.590 MHz
- 72.610 MHz
- 72.630 MHz
- 72.650 MHz
- 72.670 MHz
- 72.690 MHz
- 72.710 MHz
- 72.730 MHz
- 72.750 MHz
- 72.770 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
- 72.890 MHz
- 72.910 MHz
- 72.930 MHz
- 72.950 MHz
- 72.970 MHz
- 72.990 MHz
- 75.410 MHz
- 75.430 MHz
- 75.450 MHz
- 75.470 MHz
- 75.490 MHz
- 75.510 MHz
- 75.530 MHz
- 75.550 MHz
- 75.570 MHz
- 75.590 MHz
- 75.610 MHz
- 75.630 MHz
- 75.650 MHz
- 75.670 MHz
- 75.690 MHz
- 75.710 MHz
- 75.730 MHz
- 75.750 MHz
- 75.770 MHz
- 75.790 MHz
- 75.810 MHz
- 75.830 MHz
- 75.850 MHz
- 75.870 MHz
- 75.890 MHz
- 75.910 MHz
- 75.930 MHz
- 75.950 MHz
- 75.970 MHz
- 75.990 MHz
- 154.570 MHz - MURS Channel 4 - Maximum 20 kHz bandwidth "Blue Dot"
- 154.600 MHz - MURS Channel 5 - Maximum 20 kHz bandwidth "Green Dot"
900 MHz RC Frequencies
902-928 MHz limits:
- 50,000 uV/m at 3m field strength for any device - 15.249 Part 15
- 1 watt ERP for digital modulation
- 1 watt ERP for spread spectrum / frequency hopping (if at least 50 frequencies / channels are used per hopset)
2.4 GHz RC Frequencies
Canada
47 MHz band
- 47.020 MHz
- 47.030 MHz
- 47.050 MHz
- 47.050 MHz
- 47.070 MHz
- 47.110 MHz
- 47.130 MHz
- 47.150 MHz
- 47.170 MHz
- 47.230 MHz
- 47.250 MHz
- 47.270 MHz
- 47.290 MHz
- 47.300 MHz
- 47.310 MHz
- 47.330 MHz
- 47.350 MHz
49 MHz band
72 MHz band
- 72.010 MHz - Channel 11
- 72.030 MHz - Channel 12
- 72.050 MHz - Channel 13
- 72.070 MHz - Channel 14
- 72.090 MHz - Channel 15
- 72.110 MHz - Channel 16
- 72.130 MHz - Channel 17
- 72.150 MHz - Channel 18
- 72.170 MHz - Channel 19
- 72.190 MHz - Channel 20
- 72.210 MHz - Channel 21
- 72.230 MHz - Channel 22
- 72.250 MHz - Channel 23
- 72.270 MHz - Channel 24
- 72.290 MHz - Channel 25
- 72.310 MHz - Channel 26
- 72.330 MHz - Channel 27
- 72.350 MHz - Channel 28
- 72.370 MHz - Channel 29
- 72.390 MHz - Channel 30
- 72.410 MHz - Channel 31
- 72.430 MHz - Channel 32
- 72.450 MHz - Channel 33
- 72.470 MHz - Channel 34
- 72.490 MHz - Channel 35
- 72.510 MHz - Channel 36
- 72.530 MHz - Channel 37
- 72.550 MHz - Channel 38
- 72.570 MHz - Channel 39
- 72.590 MHz - Channel 40
- 72.610 MHz - Channel 41
- 72.630 MHz - Channel 42
- 72.650 MHz - Channel 43
- 72.670 MHz - Channel 44
- 72.690 MHz - Channel 45
- 72.710 MHz - Channel 46
- 72.730 MHz - Channel 47
- 72.750 MHz - Channel 48
- 72.770 MHz - Channel 49
- 72.790 MHz - Channel 50
- 72.810 MHz - Channel 51
- 72.830 MHz - Channel 52
- 72.850 MHz - Channel 53
- 72.870 MHz - Channel 54
- 72.890 MHz - Channel 55
- 72.910 MHz - Channel 56
- 72.930 MHz - Channel 57
- 72.950 MHz - Channel 58
- 72.970 MHz - Channel 59
- 72.990 MHz - Channel 60
75 MHz band
- 75.410 MHz - Channel 61
- 75.430 MHz - Channel 62
- 75.450 MHz - Channel 63
- 75.470 MHz - Channel 64
- 75.490 MHz - Channel 65
- 75.510 MHz - Channel 66
- 75.530 MHz - Channel 67
- 75.550 MHz - Channel 68
- 75.570 MHz - Channel 69
- 75.590 MHz - Channel 70
- 75.610 MHz - Channel 71
- 75.630 MHz - Channel 72
- 75.650 MHz - Channel 73
- 75.670 MHz - Channel 74
- 75.690 MHz - Channel 75
- 75.710 MHz - Channel 76
- 75.730 MHz - Channel 77
- 75.750 MHz - Channel 78
- 75.770 MHz - Channel 79
- 75.790 MHz - Channel 80
- 75.810 MHz - Channel 81
- 75.830 MHz - Channel 82
- 75.850 MHz - Channel 83
- 75.870 MHz - Channel 84
- 75.890 MHz - Channel 85
- 75.910 MHz - Channel 86
- 75.930 MHz - Channel 87
- 75.950 MHz - Channel 88
- 75.970 MHz - Channel 89
- 75.990 MHz - Channel 90
See IR2030/23/1
- 26.965 MHz - RC Channel 1
- 26.975 MHz - RC Channel 2 - Black
- 26.985 MHz - RC Channel 3
- 26.995 MHz - RC Channel 4 - may be transmitted from airborne devices - Brown
- 27.005 MHz - RC Channel 5
- 27.015 MHz - RC Channel 6
- 27.025 MHz - RC Channel 7 - Brown-Red
- 27.035 MHz - RC Channel 8
- 27.045 MHz - RC Channel 9 - may be transmitted from airborne devices - Red
- 27.055 MHz - RC Channel 10
- 27.065 MHz - RC Channel 11
- 27.075 MHz - RC Channel 12 - Red-Orange
- 27.085 MHz - RC Channel 13
- 27.095 MHz - RC Channel 14 - may be transmitted from airborne devices - Orange
- 27.105 MHz - RC Channel 15
- 27.115 MHz - RC Channel 16
- 27.125 MHz - RC Channel 17 - Orange-Yellow
- 27.135 MHz - RC Channel 18
- 27.145 MHz - RC Channel 19 - may be transmitted from airborne devices - Yellow
- 27.155 MHz - RC Channel 20
- 27.165 MHz - RC Channel 21
- 27.175 MHz - RC Channel 22 - Yellow-Green
- 27.185 MHz - RC Channel 23
- 27.195 MHz - RC Channel 24 - may be transmitted from airborne devices - Green
- 27.205 MHz - RC Channel 25
- 27.215 MHz - RC Channel 26
- 27.225 MHz - RC Channel 27 - Green-Blue
- 27.235 MHz - RC Channel 28
- 27.245 MHz - RC Channel 29
- 27.255 MHz - RC Channel 30
- 27.265 MHz - RC Channel 31
- 27.275 MHz - RC Channel 32 - Purple or White
OLD FREQUENCY LIST - SOME SOURCES LIST THIS AS THE CURRENT LIST ????
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
- 40.665 MHz - Channel 665 / 40MHz RC Channel 66
- 40.675 MHz - Channel 675 / 40MHz RC Channel 67
- 40.685 MHz - Channel 685 / 40MHz RC Channel 68
- 40.695 MHz - Channel 695 / 40MHz RC Channel 69
- 40.705 MHz - Channel 705 / 40MHz RC Channel 70
- 40.715 MHz - Channel 715 / 40MHz RC Channel 71
- 40.725 MHz - Channel 725 / 40MHz RC Channel 72
- 40.735 MHz - Channel 735 / 40MHz RC Channel 73
- 40.745 MHz - Channel 745 / 40MHz RC Channel 74
- 40.755 MHz - Channel 755 / 40MHz RC Channel 75
- 40.765 MHz - Channel 765 / 40MHz RC Channel 76
- 40.775 MHz - Channel 775 / 40MHz RC Channel 77
- 40.785 MHz - Channel 785 / 40MHz RC Channel 78
- 40.795 MHz - Channel 795 / 40MHz RC Channel 79
- 40.805 MHz - Channel 805 / 40MHz RC Channel 80
- 40.815 MHz - Channel 815 / 40MHz RC Channel 81
- 40.825 MHz - Channel 825 / 40MHz RC Channel 82
- 40.835 MHz - Channel 835 / 40MHz RC Channel 83
- 40.845 MHz - Channel 845 / 40MHz RC Channel 84
- 40.855 MHz - Channel 855 / 40MHz RC Channel 85
- 40.865 MHz - Channel 865 / 40MHz RC Channel 86
- 40.875 MHz - Channel 875 / 40MHz RC Channel 87
- 40.885 MHz - Channel 885 / 40MHz RC Channel 88
- 40.895 MHz - Channel 895 / 40MHz RC Channel 89
- 40.905 MHz - Channel 905 / 40MHz RC Channel 90
- 40.915 MHz - Channel 915 / 40MHz RC Channel 91
- 40.925 MHz - Channel 925 / 40MHz RC Channel 92
- 40.935 MHz - Channel 935 / 40MHz RC Channel 93
- 40.945 MHz - Channel 945 / 40MHz RC Channel 94
- 40.955 MHz - Channel 955 / 40MHz RC Channel 95
- 40.965 MHz - Channel 965 / 40MHz RC Channel 96
- 40.975 MHz - Channel 975 / 40MHz RC Channel 97
- 40.985 MHz - Channel 985 / 40MHz RC Channel 98
- 40.995 MHz - Channel 995 / 40MHz RC Channel 99
459 MHz Band - UHF
- 458.525 MHz - Channel 1
- 458.550 MHz - Channel 2
- 458.575 MHz - Channel 3
- 458.600 MHz - Channel 4
- 458.625 MHz - Channel 5
- 458.650 MHz - Channel 6
- 458.675 MHz - Channel 7
- 458.700 MHz - Channel 8
- 458.725 MHz - Channel 9
- 458.750 MHz - Channel 10
- 458.775 MHz - Channel 11
- 458.800 MHz - Channel 12
- 458.825 MHz - Channel 13
- 458.850 MHz - Channel 14
- 458.875 MHz - Channel 15
- 458.900 MHz - Channel 16
- 458.925 MHz - Channel 17
- 458.950 MHz - Channel 18
- 458.975 MHz - Channel 19
- 459.000 MHz - Channel 20
- 459.025 MHz - Channel 21
- 459.050 MHz - Channel 22
- 459.075 MHz - Channel 23
- 459.100 MHz - Channel 24
- 459.125 MHz - Channel 25
- 459.150 MHz - Channel 26
- 459.175 MHz - Channel 27
- 459.200 MHz - Channel 28
- 459.225 MHz - Channel 29
- 459.250 MHz - Channel 30
- 459.275 MHz - Channel 31
- 459.300 MHz - Channel 32
- 459.325 MHz - Channel 33
- 459.350 MHz - Channel 34
- 459.375 MHz - Channel 35
- 459.400 MHz - Channel 36
- 459.425 MHz - Channel 37
- 459.450 MHz - Channel 38
- 459.475 MHz - Channel 39
- 2.4 GHz Band
- 5.8 GHz Band
- Channel A1 - 5865 MHz / 5.865 GHz
- Channel A2 - 5845 MHz / 5.845 GHz
- Channel A3 - 5825 MHz / 5.825 GHz
- Channel A4 - 5805 MHz / 5.805 GHz
- Channel A5 - 5785 MHz / 5.785 GHz
- Channel A6 - 5765 MHz / 5.765 GHz
- Channel A7 - 5745 MHz / 5.745 GHz
- Channel A8 - 5725 MHz / 5.725 GHz
- B1-B8 channels, 19 MHz channel bandwidth / 19 MHz spacing, 5.733GHz - 5.866GHz
- Channel B1 - 5733 MHz / 5.733 GHz
- Channel B2 - 5752 MHz / 5.752 GHz
- Channel B3 - 5771 MHz / 5.771 GHz
- Channel B4 - 5790 MHz / 5.790 GHz
- Channel B5 - 5809 MHz / 5.809 GHz
- Channel B6 - 5828 MHz / 5.828 GHz
- Channel B7 - 5847 MHz / 5.847 GHz
- Channel B8 - 5866 MHz / 5.866 GHz
- E1-E8 channels, not legal in UK (outside band allocation)
- Channel E1 - 5705 MHz / 5.705 GHz
- Channel E2 - 5685 MHz / 5.685 GHz
- Channel E3 - 5665 MHz / 5.665 GHz
- Channel E4 - 5645 MHz / 5.645 GHz
- Channel E5 - 5885 MHz / 5.885 GHz
- Channel E6 - 5905 MHz / 5.905 GHz
- Channel E7 - 5925 MHz / 5.925 GHz
- Channel E8 - 5945 MHz / 5.945 GHz
- F1-F8 channels, 20 MHz channel bandwidth 19 MHz spacing, 5.74GHz - 5.86GHz
- Channel F1 - 5740 MHz / 5.740 GHz
- Channel F2 - 5760 MHz / 5.760 GHz
- Channel F3 - 5780 MHz / 5.780 GHz
- Channel F4 - 5800 MHz / 5.800 GHz
- Channel F5 - 5820 MHz / 5.820 GHz
- Channel F6 - 5840 MHz / 5.840 GHz
- Channel F7 - 5860 MHz / 5.860 GHz
- Channel F8 - 5880 MHz / 5.880 GHz - not legal in the UK
- CEPT ETSI SRD Bands
- 26.957 MHz to 27.283 MHz
- 26.995 MHz - 100mW ERP
- 27.045 MHz - 100mW ERP
- 27.095 MHz - 100mW ERP
- 27.145 MHz - 100mW ERP
- 27.195 MHz - 100mW ERP
- 40.660 MHz to 40.700 MHz
- 138.200 MHz to 138.450 MHz
- 169.400 MHz to 169.8125 MHz
- 863 MHz to 876 MHz
- 34.995 MHz to 35.225 MHz and 35.8 MHz to 35.92 MHz - 35 MHz RC band European standardized aero models only (flying models, aircraft models only, including drones / UAVs / UAS links or whatever you want to call them) CEPT 35 MHz band, 5/10 kHz spacing, generally starting at 35.000 MHz going up to 35.220 MHz in 10 kHz steps. Some countries have additional allocations above and below the EU standardized band. ITU “worldwide” standardization for SRDs - Short Range Devices - on the 40.66 MHz - 40.70 MHz band exists, but with a power limit of 10mW ERP. Several countries permit 100mW on the 35 MHz RC channels and/or the 40 MHz RC channels.
- 35.820 MHz - Channel 182
- 35.830 MHz - Channel 183
- 35.840 MHz - Channel 184
- 35.850 MHz - Channel 185
- 35.860 MHz - Channel 186
- 35.870 MHz - Channel 187
- 35.880 MHz - Channel 188
- 35.890 MHz - Channel 189
- 35.900 MHz - Channel 190
- 35.910 MHz - Channel 191
Czech Republic
26 MHz/27 MHz Band.
- 26.995 MHz - 26995 kHz - General model control and RC use - 100mW ERP maximum power
- 27.045 MHz - 27045 kHz - General model control and RC use - 100mW ERP maximum power
- 27.095 MHz - 27095 kHz - General model control and RC use - 100mW ERP maximum power
- 27.145 MHz - 27145 kHz - General model control and RC use - 100mW ERP maximum power
- 27.195 MHz - 27195 kHz - General model control and RC use - 100mW ERP maximum power
- 27.975 MHz - 27975 kHz - Data transmission FSK use/RC use - 100mW ERP maximum power
- 27.985 MHz - 27985 kHz - Data transmission FSK use/RC use - 100mW ERP maximum power
- 27.995 MHz - 27995 kHz - Data transmission FSK use/RC use - 100mW ERP maximum power
- 32.875 MHz
- 32.900 MHz
- 32.925 MHz
- 32.950 MHz
- 32.975 MHz
34 MHz FM - 1 watt ERP maximum power (16 kHz bandwidth limit, 16K0F1D or 16K0F2D
34.05 MHz to 34.175 MHz
- 34.050 MHz
- 34.075 MHz
- 34.150 MHz
- 34.175 MHz
- 35.000 MHz - C1
- 35.010 MHz - C2
- 35.020 MHz - C3
- 35.030 MHz - C4
- 35.040 MHz - C5
- 35.050 MHz - C6
- 35.060 MHz - C7
- 35.070 MHz - C8
- 35.080 MHz - C9
- 35.090 MHz - C10
- 35.100 MHz - C11
- 35.110 MHz - C12
- 35.120 MHz - C13
- 35.130 MHz - C14
- 35.140 MHz - C15
- 35.150 MHz - C16
- 35.160 MHz - C17
- 35.170 MHz - C18
- 35.180 MHz - C19
- 35.190 MHz - C20
- 35.200 MHz - C21
- 35.210 MHz - C22
- 35.220 MHz - C23
- 35.820 MHz - D1
- 35.830 MHz - D2
- 35.840 MHz - D3
- 35.850 MHz - D4
- 35.860 MHz - D5
- 35.870 MHz - D6
- 35.880 MHz - D7
- 35.890 MHz - D8
- 35.900 MHz - D9
- 35.910 MHz - D10
57 MHz Low Power Data Links:
- 57.225 MHz
- 57.250 MHz
- 57.275 MHz
- 57.300 MHz
- 77.025 MHz
- 77.050 MHz
- 77.075 MHz
- 77.100 MHz
- 77.725 MHz
- 78.000 MHz
- 81.725 MHz
- 81.870 MHz
France
26/27 MHz - AM or FM - for all types of models (general model use). 10 kHz bandwidth limit, 100mW power output - E.I.R.P. limit
- 26.815 MHz - 26815 kHz
- 26.825 MHz - 26825 kHz
- 26.835 MHz - 26835 kHz
- 26.845 MHz - 26845 kHz
- 26.855 MHz - 26855 kHz
- 26.865 MHz - 26865 kHz
- 26.875 MHz - 26875 kHz
- 26.885 MHz - 26885 kHz
- 26.895 MHz - 26895 kHz
- 26.905 MHz - 26905 kHz
- 26.915 MHz - 26915 kHz
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 41.110 MHz - General model use - "Euro 41MHz Channel 11"
- 41.120 MHz - General model use - "Euro 41MHz Channel 12"
- 41.130 MHz - General model use - "Euro 41MHz Channel 13"
- 41.140 MHz - General model use - "Euro 41MHz Channel 14"
- 41.150 MHz - General model use - "Euro 41MHz Channel 15"
- 41.160 MHz - General model use - "Euro 41MHz Channel 16"
- 41.170 MHz - General model use - "Euro 41MHz Channel 17"
- 41.180 MHz - General model use - "Euro 41MHz Channel 18"
- 41.190 MHz - General model use - "Euro 41MHz Channel 19"
- 41.200 MHz - General model use - "Euro 41MHz Channel 11"
- 72 MHz AM or FM
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.820 MHz
- 35.830 MHz
- 35.840 MHz
- 35.850 MHz
- 35.860 MHz
- 35.870 MHz
- 35.880 MHz
- 35.890 MHz
- 35.900 MHz
- 35.910 MHz
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
Italy
- 27.045 MHz
- 27.095 MHz
- 27.145 MHz
- 27.195 MHz
- 27.235 MHz
- 27.255 MHz
- 27.275 MHz
40 MHz band - Note: the 40.665 MHz, 40.675 MHz, 40.685 MHz and 40.695 MHz frequencies are also used for "priest's radio" - basically the Italian version of the 27 MHz CB radio based CADS / WPAS - parish radio broadcast service. These frequencies are also used for paging and numerous other services and are shared with the 8m amateur radio band.
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.705 MHz
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
- 40.805 MHz
- 40.815 MHz
- 40.825 MHz
- 40.835 MHz
- 40.845 MHz
- 40.855 MHz
- 40.865 MHz
- 40.875 MHz
Spain
27 MHz fixed/mobile service: Power output limited to 20 watts. Paging, telecommand, telemetry and data, including to/from mobile units, data or voice:
- 27.505 MHz
- 27.515 MHz
- 27.525 MHz
- 27.535 MHz
- 27.545 MHz
- 27.555 MHz
- 27.565 MHz
- 27.575 MHz
- 27.585 MHz
- 27.595 MHz
- 27.845 MHz
- 27.855 MHz
- 29.710 MHz
- 29.720 MHz
- 29.730 MHz
- 29.740 MHz
- 29.750 MHz
- 29.760 MHz
- 29.770 MHz
- 29.780 MHz
- 29.790 MHz
- 29.800 MHz
- 29.810 MHz
- 29.820 MHz
- 29.830 MHz
- 29.840 MHz
- 29.850 MHz
- 29.860 MHz
- 29.870 MHz
- 29.880 MHz
- 29.890 MHz
- 29.900 MHz
- 29.910 MHz
- 29.920 MHz
- 29.930 MHz
- 29.940 MHz
- 29.950 MHz
- 29.960 MHz
- 29.970 MHz
- 29.980 MHz
- 29.990 MHz
- 30.035 MHz
- 30.045 MHz
- 30.055 MHz
- 30.065 MHz
- 30.075 MHz
- 30.085 MHz
- 30.095 MHz
- 30.105 MHz
- 30.115 MHz
- 30.125 MHz
- 30.135 MHz
- 30.145 MHz
- 30.155 MHz
- 30.165 MHz
- 30.175 MHz
- 30.185 MHz
- 30.195 MHz
- 30.205 MHz
- 30.215 MHz
- 30.225 MHz
- 30.235 MHz
- 30.245 MHz
- 30.255 MHz
- 30.265 MHz
- 30.275 MHz
- 30.285 MHz
- 30.295 MHz
- 40 MHz Band
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.875 MHz
- 40.900 MHz
- 40.925 MHz
- 40.950 MHz
Switzerland
RIR1007 specifications
27 MHz SRDs 27 MHz RC
- 26995 kHz - Channel A 26990 kHz - 27000 kHz
- 27045 kHz - Channel B 27040 kHz - 27050 kHz
- 27095 kHz - Channel C 27090 kHz - 27100 kHz
- 27145 kHz - Channel D 27140 kHz - 27150 kHz
- 27195 kHz - Channel E 27190 kHz - 27200 kHz
- 26995 kHz - 26.995 MHz - also used for model control in addition to uses listed above
- 27045 kHz - 27.045 MHz - also used for model control in addition to uses listed above
- 27095 kHz - 27.095 MHz - also used for model control in addition to uses listed above
- 27145 kHz - 27.145 MHz - also used for model control in addition to uses listed above
- 27195 kHz - 27.195 MHz - also used for model control in addition to uses listed above
- 27255 kHz - 27.255 MHz
- 27545 kHz - 27.545 MHz
- 27615 kHz - 27.615 MHz
- 27625 kHz - 27.625 MHz
- 27635 kHz - 27.635 MHz
- 27655 kHz - 27.655 MHz
- 27675 kHz - 27.675 MHz
- 27725 kHz - 27.725 MHz
- 27755 kHz - 27.755 MHz
- 27775 kHz - 27.775 MHz
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.210 MHz
- 35.220 MHz
- 40.665 MHz - Channel A
- 40.675 MHz - Channel B
- 40.685 MHz - Channel C
- 40.695 MHz - Channel D
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
- 40.805 MHz
- 40.815 MHz
- 40.825 MHz
- 40.835 MHz
- 40.845 MHz
- 40.855 MHz
- 40.865 MHz
- 40.875 MHz
- 40.885 MHz
- 40.895 MHz
- 40.905 MHz
- 40.915 MHz
- 40.925 MHz
- 40.935 MHz
- 40.945 MHz
- 40.955 MHz
- 40.965 MHz
- 40.975 MHz
- 40.985 MHz
2.4 GHz band
- 100mW ERP - For Frequency hopping spread spectrum modulation (FHSS), the maximum e.i.r.p. spectral density is limited to 100mW/100kHz.
- 100mW / 100 kHz for FHSS - For wide band modulations other then FHSS (e.g. DSSS, OFDM, etc.), the maximum e.i.r.p. spectral density is limited to 10 mW/MHz.
- 10mW / MHz for wideband applications
2.4 GHz band
- Band A: 5150 MHz - 5250 MHz / 5.15 GHz - 5.25 GHz
- Band B: 5250 MHz - 5350 MHz / 5.25 GHz - 5.35 GHz
- 5170 MHz - 5250 MHz - Use by Unmanned Aircraft Systems is limited to within the 5170 - 5250 MHz / 5.17 GHz - 5.25 GHz band;
- 5250 MHz - 5350 MHz - Indoor use only Indoor use: inside buildings only. Installations in road vehicles, trains and aircraft (exception see ECC/DEC/(04)08) are not permitted. Outdoor use of the 5.25 GHz - 5.35 GHz portion (Band B) is not allowed.
5.8 GHz band
Sweden
- 35.000 MHz - RC Channel 60
- 35.010 MHz - RC Channel 61
- 35.020 MHz - RC Channel 62
- 35.030 MHz - RC Channel 63
- 35.040 MHz - RC Channel 64
- 35.050 MHz - RC Channel 65
- 35.060 MHz - RC Channel 66
- 35.070 MHz - RC Channel 67
- 35.080 MHz - RC Channel 68
- 35.090 MHz - RC Channel 69
- 35.100 MHz - RC Channel 70
- 35.110 MHz - RC Channel 71
- 35.120 MHz - RC Channel 72
- 35.130 MHz - RC Channel 73
- 35.140 MHz - RC Channel 74
- 35.150 MHz - RC Channel 75
- 35.160 MHz - RC Channel 76
- 35.170 MHz - RC Channel 77
- 35.180 MHz - RC Channel 78
- 35.190 MHz - RC Channel 79
- 35.200 MHz - RC Channel 80
- 35.210 MHz - RC Channel 81
- 35.220 MHz - RC Channel 82
- 35.230 MHz - RC Channel 83
- 35.240 MHz - RC Channel 84
- 35.250 MHz - RC Channel 85
- 35.260 MHz - RC Channel 86
- 35.270 MHz - RC Channel 87
- 40.665 MHz
- 40.675 MHz
- 40.685 MHz
- 40.695 MHz
- 40.705 MHz
- 40.715 MHz
- 40.725 MHz
- 40.735 MHz
- 40.745 MHz
- 40.755 MHz
- 40.765 MHz
- 40.775 MHz
- 40.785 MHz
- 40.795 MHz
Finland
- 26825 kHz 26.825 MHz
- 26845 kHz 26.845 MHz
- 26865 kHz 26.865 MHz
- 26885 kHz 26.885 MHz
- 26905 kHz 26.905 MHz
- 26925 kHz 26.925 MHz
- 26935 kHz 26.935 MHz
- 26945 kHz 26.945 MHz
- 26995 kHz 26.995 MHz
- 27095 kHz 27.045 MHz
- 27095 kHz 27.095 MHz
- 27145 kHz 27.145 MHz
- 27195 kHz 27.195 MHz
- 27255 kHz 27.255 MHz
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.210 MHz
- 35.220 MHz
Denmark
- Frequencies
- 138.650 MHz - 500mW ERP
- Bands
Russia
- 26945 kHz and 26960 kHz are limited to 3dB antenna gain
- 26.945 MHz - Car alarm data links 10% duty cycle, 12 kHz bandwidth limit
- 26.945 MHz - General data, telemetry, RCRS type services, 2 watt power
- 26.960 MHz - Security alarm data links 10% duty cycle 12 kHz bandwidth limit
- 26.955 MHz - Data links, paging
- 26.960 MHz - General data, telemetry, RCRS type services, 2 watt power
- 27.080 MHz - unknown power limit
27 MHz
- 26.975 MHz - Channel 01
- 26.995 MHz - Channel 02
- 27.025 MHz - Channel 03
- 27.045 MHz - Channel 04 - note, this overlaps with 27.048 MHz listed above
- 27.075 MHz - Channel 05
- 27.095 MHz - Channel 06
- 27.125 MHz - Channel 07 - overlaps with and offset to 27.120 MHz frequency listed above
- 27.145 MHz - Channel 08
- 27.175 MHz - Channel 09
- 27.195 MHz - Channel 10
- 27.225 MHz - Channel 11
- 27.255 MHz - Channel 12
- 40.680 MHz - General RC use - Offset frequency, shared with ISM, wireless microphones, etc.
- 72.130 MHz - Aircraft only -
- 72.150 MHz - Aircraft only
- 72.170 MHz - Aircraft only
- 72.190 MHz - Aircraft only
- 72.210 MHz - Aircraft only
- 72.790 MHz - Aircraft only
- 72.810 MHz - Aircraft only
- 72.830 MHz - Aircraft only
- 72.850 MHz - Aircraft only
- 72.870 MHz - Aircraft only
- 73.220 MHz - General RC use
- 73.230 MHz - General RC use
- 73.240 MHz - General RC use
- 73.250 MHz - General RC use
- 73.260 MHz - General RC use
- 73.270 MHz - General RC use
- 73.280 MHz - General RC use
- 73.290 MHz - General RC use
- 73.300 MHz - General RC use
- 73.310 MHz - General RC use
- 73.320 MHz - General RC use
- 2441.75 MHz
- 2484 MHz
- Specified Low Power Radio Stations (this includes telemetery, telecommand or "telecontrol" (remote control, wireless control) as well as the Specified Low Power Radio Service.
- 426.028125 MHz
- 426.034375 MHz
- 426.040625 MHz
- 426.046875 MHz
- 426.053125 MHz
- 426.059375 MHz
- 426.065625 MHz
- 426.071875 MHz
- 426.078125 MHz
- 426.084375 MHz
- 426.090625 MHz
- 426.096875 MHz
- 426.103125 MHz
- 426.109375 MHz
- 426.115625 MHz
- 426.121875 MHz
- 426.128125 MHz
- 426.134375 MHz
- 429.178125 MHz
- 429.184375 MHz
- 429.190625 MHz
- 429.196875 MHz
- 429.203125 MHz
- 429.209375 MHz
- 429.215625 MHz
- 429.221875 MHz
- 429.228125 MHz
- 429.234375 MHz
- 429.240625 MHz
- 429.246875 MHz
- 429.253125 MHz
- 429.259375 MHz
- 429.265625 MHz
- 429.271875 MHz
- 429.278125 MHz
- 429.284375 MHz
- 429.290625 MHz
- 429.296875 MHz
- 429.303125 MHz
- 429.409375 MHz
- 429.415625 MHz
- 429.421875 MHz
- 429.428125 MHz
- 429.434375 MHz
- 429.440625 MHz
- 429.446875 MHz
- 429.453125 MHz
- 429.459375 MHz
- 429.465625 MHz
- 429.471875 MHz
- 429.478125 MHz
- 429.484375 MHz
- 429.490625 MHz
- 429.496875 MHz
- 429.503125 MHz
- 429.509375 MHz
- 429.515625 MHz
- 429.521875 MHz
- 429.528125 MHz
- 429.534375 MHz
- 429.540625 MHz
- 429.546875 MHz
- 429.553125 MHz
- 429.559375 MHz
- 429.565625 MHz
- 429.571875 MHz
- 429.578125 MHz
- 429.584375 MHz
- 429.590625 MHz
- 429.596875 MHz
- 429.603125 MHz
- 429.609375 MHz
- 429.615625 MHz
- 429.621875 MHz
- 429.628125 MHz
- 429.634375 MHz
- 429.640625 MHz
- 429.646875 MHz
- 429.653125 MHz
- 429.659375 MHz
- 429.665625 MHz
- 429.671875 MHz
- 429.678125 MHz
- 429.684375 MHz
- 429.690625 MHz
- 429.696875 MHz
- 429.703125 MHz
- 429.709375 MHz
- 429.715625 MHz
- 429.721875 MHz
- 429.728125 MHz
- 429.734375 MHz
- 429.815625 MHz
- 429.821875 MHz
- 429.828125 MHz
- 429.834375 MHz
- 429.840625 MHz
- 429.846875 MHz
- 429.853125 MHz
- 429.859375 MHz
- 429.865625 MHz
- 429.871875 MHz
- 429.878125 MHz
- 429.884375 MHz
- 429.890625 MHz
- 429.896875 MHz
- 429.903125 MHz
- 429.909375 MHz
- 429.915625 MHz
- 429.921875 MHz
- 449.715625 MHz
- 449.721875 MHz
- 449.734375 MHz
- 449.740625 MHz
- 449.746875 MHz
- 449.753125 MHz
- 449.759375 MHz
- 449.765625 MHz
- 449.771875 MHz
- 449.778125 MHz
- 449.784375 MHz
- 449.790625 MHz
- 449.796875 MHz
- 449.803125 MHz
- 449.809375 MHz
- 449.815625 MHz
- 449.821875 MHz
- 426.0250 MHz
- 426.0375 MHz
- 426.0500 MHz
- 426.0625 MHz
- 426.0750 MHz
- 426.0875 MHz
- 426.1000 MHz
- 426.1125 MHz
- 426.1250 MHz
- 426.1375 MHz
- 429.1750 MHz
- 429.1875 MHz
- 429.2000 MHz
- 429.2125 MHz
- 429.2250 MHz
- 429.2375 MHz
- 429.2500 MHz
- 429.2625 MHz
- 429.2750 MHz
- 429.2875 MHz
- 429.3000 MHz
- 429.3125 MHz
- 429.3250 MHz
- 429.3375 MHz
- 429.3500 MHz
- 429.3625 MHz
- 429.3750 MHz
- 429.3875 MHz
- 429.4000 MHz
- 429.4125 MHz
- 429.4250 MHz
- 429.4375 MHz
- 429.4500 MHz
- 429.4625 MHz
- 429.4750 MHz
- 429.4875 MHz
- 429.5000 MHz
- 429.5125 MHz
- 429.5250 MHz
- 429.5375 MHz
- 429.5500 MHz
- 429.5625 MHz
- 429.5750 MHz
- 429.5875 MHz
- 429.6000 MHz
- 429.6125 MHz
- 429.6250 MHz
- 429.6375 MHz
- 429.6500 MHz
- 429.6625 MHz
- 429.6750 MHz
- 429.6875 MHz
- 429.7000 MHz
- 429.7125 MHz
- 429.7250 MHz
- 429.7375 MHz
- 429.8125 MHz
- 429.9250 MHz
- 449.7125 MHz
- 449.7250 MHz
- 449.7375 MHz
- 449.7500 MHz
- 449.7625 MHz
- 449.7750 MHz
- 449.7875 MHz
- 449.8000 MHz
- 449.8125 MHz
- 449.8250 MHz
- 449.8375 MHz
- 449.8500 MHz
- 449.8625 MHz
- 449.8750 MHz
- 449.8875 MHz
- 449.8000 MHz
- 449.8125 MHz
- 449.8250 MHz
- 449.8375 MHz
- 449.8500 MHz
- 449.8625 MHz
- 449.8750 MHz
- 449.8875 MHz
- 469.7375 MHz
- 469.7500 MHz
- 469.7625 MHz
- 469.7750 MHz
- 469.7875 MHz
- 469.8000 MHz
- 469.8125 MHz
- 469.8250 MHz
- 469.8375 MHz
- 469.8500 MHz
- 469.8625 MHz
- 469.8750 MHz
- 469.8875 MHz
People's Republic of China
- 40.610 MHz
- 40.630 MHz
- 40.650 MHz
- 40.670 MHz
- 40.690 MHz
- 40.710 MHz
- 40.730 MHz
- 40.750 MHz
- 40.770 MHz
- 40.790 MHz
- 40.810 MHz
- 40.830 MHz
- 40.850 MHz
- 72.130 MHz
- 72.150 MHz
- 72.170 MHz
- 72.190 MHz
- 72.210 MHz
- 72.790 MHz
- 72.810 MHz
- 72.830 MHz
- 72.850 MHz
- 72.870 MHz
- 223.100 MHz
- 223.700 MHz
- 223.975 MHz
- 224.600 MHz
- 225.025 MHz
- 225.325 MHz
- 230.100 MHz
- 230.700 MHz
- 230.975 MHz
- 231.600 MHz
- 232.025 MHz
- 232.325 MHz
- 418.950 MHz
- 418.975 MHz
- 419.000 MHz
- 419.025 MHz
- 419.050 MHz
- 419.075 MHz
- 419.100 MHz
- 419.125 MHz
- 419.150 MHz
- 419.175 MHz
- 419.200 MHz
- 419.225 MHz
- 419.250 MHz
- 419.275 MHz
Korea
Republic of Korea South Korea
Remote control or wireless control of vehicles, surface craft, boats and aircraft - A1D, A2D, F1D, F2D, G1D, G2D emission. 16 kHz bandwidth emission limit.
- 16K0A1D
- 16K0A2D
- 16K0F1D
- 16K0F2D
- 16K0G1D
- 16K0G2D
Field strength limited to 200 uV/m at 500 meters or 10 mV/m at 10m or 333 uW 333 microwatts ERP - sources conflict regarding the field strength limits vs. output power and antenna limits for the 27 MHz and 40 MHz bands
- 13.552 MHz - 13.568 MHz - telecommand, remote control for toys, security alarm radio links
- 26.958 MHz - 27.282 MHz - telecommand, remote control for toys, security alarm radio links
- 40.656 MHz - 40.704 MHz - telecommand, remote control for toys, security alarm radio links
- 26.995 MHz - surface vehicles, boats and aircraft - any type of device
- 27.045 MHz - surface vehicles, boats and aircraft - any type of device
- 27.095 MHz - surface vehicles, boats and aircraft - any type of device
- 27.145 MHz - surface vehicles, boats and aircraft - any type of device
- 27.195 MHz - surface vehicles, boats and aircraft - any type of device
- 40.255 MHz - surface vehicles, boats and aircraft - any type of device
- 40.275 MHz - surface vehicles, boats and aircraft - any type of device
- 40.295 MHz - surface vehicles, boats and aircraft - any type of device
- 40.315 MHz - surface vehicles, boats and aircraft - any type of device
- 40.335 MHz - surface vehicles, boats and aircraft - any type of device
- 40.355 MHz - surface vehicles, boats and aircraft - any type of device
- 40.375 MHz - surface vehicles, boats and aircraft - any type of device
- 40.395 MHz - surface vehicles, boats and aircraft - any type of device
- 40.415 MHz - surface vehicles, boats and aircraft - any type of device
- 40.435 MHz - surface vehicles, boats and aircraft - any type of device
- 40.455 MHz - surface vehicles, boats and aircraft - any type of device
- 40.475 MHz - surface vehicles, boats and aircraft - any type of device
- 40.495 MHz - surface vehicles, boats and aircraft - any type of device
- 40.705 MHz - Remote control or wireless control of aircraft only
- 40.715 MHz - Remote control or wireless control of aircraft only
- 40.735 MHz - Remote control or wireless control of aircraft only
- 40.755 MHz - Remote control or wireless control of aircraft only
- 40.775 MHz - Remote control or wireless control of aircraft only
- 40.795 MHz - Remote control or wireless control of aircraft only
- 40.815 MHz - Remote control or wireless control of aircraft only
- 40.835 MHz - Remote control or wireless control of aircraft only
- 40.855 MHz - Remote control or wireless control of aircraft only
- 40.875 MHz - Remote control or wireless control of aircraft only
- 40.895 MHz - Remote control or wireless control of aircraft only
- 40.915 MHz - Remote control or wireless control of aircraft only
- 40.935 MHz - Remote control or wireless control of aircraft only
- 40.955 MHz - Remote control or wireless control of aircraft only
- 40.975 MHz - Remote control or wireless control of aircraft only
- 40.995 MHz - Remote control or wireless control of aircraft only
72 MHz band, remote control of aero models only
- 72.630 MHz - Remote control or wireless control of aircraft only
- 72.650 MHz - Remote control or wireless control of aircraft only
- 72.670 MHz - Remote control or wireless control of aircraft only
- 72.690 MHz - Remote control or wireless control of aircraft only
- 72.710 MHz - Remote control or wireless control of aircraft only
- 72.730 MHz - Remote control or wireless control of aircraft only
- 72.750 MHz - Remote control or wireless control of aircraft only
- 72.770 MHz - Remote control or wireless control of aircraft only
- 72.790 MHz - Remote control or wireless control of aircraft only
- 72.810 MHz - Remote control or wireless control of aircraft only
- 72.830 MHz - Remote control or wireless control of aircraft only
- 72.850 MHz - Remote control or wireless control of aircraft only
- 72.870 MHz - Remote control or wireless control of aircraft only
- 72.890 MHz - Remote control or wireless control of aircraft only
- 72.910 MHz - Remote control or wireless control of aircraft only
- 72.930 MHz - Remote control or wireless control of aircraft only
- 72.950 MHz - Remote control or wireless control of aircraft only
- 72.970 MHz - Remote control or wireless control of aircraft only
- 72.990 MHz - Remote control or wireless control of aircraft only
- 75 MHz band, allocated for remote control of any type of device or model
- 75.630 MHz - surface vehicles, boats and aircraft - any type of device
- 75.650 MHz - surface vehicles, boats and aircraft - any type of device
- 75.670 MHz - surface vehicles, boats and aircraft - any type of device
- 75.690 MHz - surface vehicles, boats and aircraft - any type of device
- 75.710 MHz - surface vehicles, boats and aircraft - any type of device
- 75.730 MHz - surface vehicles, boats and aircraft - any type of device
- 75.750 MHz - surface vehicles, boats and aircraft - any type of device
- 75.770 MHz - surface vehicles, boats and aircraft - any type of device
- 75.790 MHz - surface vehicles, boats and aircraft - any type of device
- Low power short range radio paging (one way transmissions), F1B, F1D, G1B, G1D, F2B, F2D, G2B, G2D, F3E, G3E, F9W and G9W emissions.
- 219.150 MHz
- 219.175 MHz
- 219.200 MHz
- 219.225 MHz
- 2.4 GHz band - Wi-Fi, data links, remote control, telecommand, fixed point to point links
- 2.400 GHz - 2.480 GHz 2400 MHz - 2480 MHz
- 2410 MHz - Video transmissions, directional or non-directional antennas 2.41 GHz
- 2430 MHz - Video transmissions, directional or non-directional antennas 2.43 GHz
- 2450 MHz - Video transmissions, directional or non-directional antennas 2.45 GHz
- 2470 MHz - Video transmissions, directional or non-directional antennas 2.47 GHz
- 5.8 GHz band - Wi-Fi, data links, remote control, telecommand, fixed point to point links
- The absolute gain of the transmitting antenna shall be equal to or less than 6 dBi (20 dBi for fixed point-to-point application).
- The frequency tolerance should be equal to or less than 50 × 10–6. The antenna power should be equal to or less than 10 mW/MHz.
- The occupied bandwidth should be equal to or less than 26 MHz.
- The antenna power should be equal to or less than 10 mW/MHz. The occupied bandwidth should be equal to or less than 5 MHz/channel.
India
"New" channel plan:
Old (???) channel plan:
Several bands available.
- 27 MHz band - 27MHz AM
- 29 MHz band - 29MHz FM
- 35 MHz band - 35MHz FM
- 36 MHz band - 36MHz FM
- 40 MHz band - 40MHz FM
- 72 MHz band - 72MHz FM
- 2.4 GHz band
- Channel 22 - 476.9500 MHz
- Channel 23 - 476.9750 MHz
- Channel 61 - 476.9375 MHz
- Channel 62 - 476.9625 MHz
- Channel 63 - 476.9875 MHz
- 35.000 MHz - RC Channel 500
- 35.010 MHz - RC Channel 501
- 35.020 MHz - RC Channel 502
- 35.030 MHz - RC Channel 503
- 35.040 MHz - RC Channel 504
- 35.050 MHz - RC Channel 505
- 35.060 MHz - RC Channel 506
- 35.070 MHz - RC Channel 507
- 35.080 MHz - RC Channel 508
- 35.090 MHz - RC Channel 509
- 35.100 MHz - RC Channel 510
- 35.110 MHz - RC Channel 511
- 35.120 MHz - RC Channel 512
- 35.130 MHz - RC Channel 513
- 35.140 MHz - RC Channel 514
- 35.150 MHz - RC Channel 515
- 35.160 MHz - RC Channel 516
- 35.170 MHz - RC Channel 517
- 35.180 MHz - RC Channel 518
- 35.190 MHz - RC Channel 519
- 35.200 MHz - RC Channel 520
- 35.210 MHz - RC Channel 521
- 35.220 MHz - RC Channel 522
- 35.230 MHz - RC Channel 523
- 35.240 MHz - RC Channel 524
- 35.250 MHz - RC Channel 525
- 35.260 MHz - RC Channel 526
- 35.270 MHz - RC Channel 527
- 35.280 MHz - RC Channel 528
- 35.290 MHz - RC Channel 529
- 35.300 MHz - RC Channel 530
- 36.250 MHz - RC Channel 625
- 36.260 MHz - RC Channel 626
- 36.270 MHz - RC Channel 627
- 36.280 MHz - RC Channel 628
- 36.290 MHz - RC Channel 629
- 36.300 MHz - RC Channel 630
- 36.310 MHz - RC Channel 631
- 36.320 MHz - RC Channel 632
- 36.330 MHz - RC Channel 633
- 36.340 MHz - RC Channel 634
- 36.350 MHz - RC Channel 635
- 36.360 MHz - RC Channel 636
- 36.370 MHz - RC Channel 637
- 36.380 MHz - RC Channel 638
- 36.390 MHz - RC Channel 639
- 36.400 MHz - RC Channel 640
- 36.410 MHz - RC Channel 641
- 36.420 MHz - RC Channel 642
- 36.430 MHz - RC Channel 643
- 36.440 MHz - RC Channel 644
- 36.450 MHz - RC Channel 645
- 36.460 MHz - RC Channel 646
- 36.470 MHz - RC Channel 647
- 36.480 MHz - RC Channel 648
- 36.490 MHz - RC Channel 649
- 36.500 MHz - RC Channel 650
- 36.510 MHz - RC Channel 651
- 36.520 MHz - RC Channel 652
- 36.530 MHz - RC Channel 653
- 36.540 MHz - RC Channel 654
- 36.550 MHz - RC Channel 655
- 36.560 MHz - RC Channel 656
- 36.570 MHz - RC Channel 657
- 36.580 MHz - RC Channel 658
- 36.590 MHz - RC Channel 659
- 72.010 MHz - RC Channel 701
- 72.030 MHz - RC Channel 703
- 72.050 MHz - RC Channel 705
- 72.070 MHz - RC Channel 707
- 72.090 MHz - RC Channel 709
- 72.110 MHz - RC Channel 711
- 72.130 MHz - RC Channel 713
- 72.150 MHz - RC Channel 715
- 72.170 MHz - RC Channel 717
- 72.190 MHz - RC Channel 719
- 72.210 MHz - RC Channel 721
- 72.230 MHz - RC Channel 723
- 72.250 MHz - RC Channel 725
- 72.270 MHz - RC Channel 727
- 72.290 MHz - RC Channel 729
- 72.310 MHz - RC Channel 731
- 72.330 MHz - RC Channel 733
- 72.350 MHz - RC Channel 735
- 72.370 MHz - RC Channel 737
- 72.390 MHz - RC Channel 739
- 72.410 MHz - RC Channel 741
- 72.430 MHz - RC Channel 743
- 72.450 MHz - RC Channel 745
- 72.470 MHz - RC Channel 747
- 72.490 MHz - RC Channel 749
- 72.510 MHz - RC Channel 751
- 72.530 MHz - RC Channel 753
- 72.550 MHz - RC Channel 755
- 72.570 MHz - RC Channel 757
- 72.590 MHz - RC Channel 759
- 72.610 MHz - RC Channel 761
- 72.630 MHz - RC Channel 763
- 72.650 MHz - RC Channel 765
- 72.670 MHz - RC Channel 767
- 72.690 MHz - RC Channel 769
- 72.710 MHz - RC Channel 771
- 72.730 MHz - RC Channel 773
- 72.750 MHz - RC Channel 775
- 72.770 MHz - RC Channel 777
- 72.790 MHz - RC Channel 779
- Channel 22 - 476.950 MHz
- Channel 23 - 476.975 MHz
- 36.010 MHz - RC Channel 601
- 36.020 MHz - RC Channel 602
- 36.030 MHz - RC Channel 603
- 36.040 MHz - RC Channel 604
- 36.050 MHz - RC Channel 605
- 36.060 MHz - RC Channel 606
- 36.070 MHz - RC Channel 607
- 36.080 MHz - RC Channel 608
- 36.090 MHz - RC Channel 609
- 36.100 MHz - RC Channel 610
- 36.110 MHz - RC Channel 611
- 36.120 MHz - RC Channel 612
- 36.130 MHz - RC Channel 613
- 36.140 MHz - RC Channel 614
- 36.150 MHz - RC Channel 615
- 36.160 MHz - RC Channel 616
- 36.170 MHz - RC Channel 617
- 36.180 MHz - RC Channel 618
- 36.190 MHz - RC Channel 619
- 36.200 MHz - RC Channel 620
- 36.210 MHz - RC Channel 621
- 36.220 MHz - RC Channel 622
- 36.230 MHz - RC Channel 623
- 36.240 MHz - RC Channel 624
- 40.665 MHz - RC Channel 50
- 40.675 MHz - RC Channel 51
- 40.685 MHz - RC Channel 52
- 40.695 MHz - RC Channel 53
Swaziland / Eswatini
- 27 MHz Band - shared with nonspecific short range devices and CB radio, 26990 kHz to 27200 kHz and 26960 kHz to 27410 kHz, respectively.
- 26.995 MHz 26995 kHz - 100mW ERP power limit
- 27.045 MHz 27045 kHz - 100mW ERP power limit
- 27.095 MHz 27095 kHz - 100mW ERP power limit
- 27.145 MHz 27145 kHz - 100mW ERP power limit
- 27.195 MHz 27195 kHz - 100mW ERP power limit
- 35 MHz, identical to the European standard band under CEPT standard EN 300 220, 34.995MHz to 35.225MHz, 10kHz spacing. Overlaps with PMR land mobile radio channeling offset 12.5 kHz spacing vs. 10 kHz spacing band plan.
- 35.000 MHz
- 35.010 MHz
- 35.020 MHz
- 35.030 MHz
- 35.040 MHz
- 35.050 MHz
- 35.060 MHz
- 35.070 MHz
- 35.080 MHz
- 35.090 MHz
- 35.100 MHz
- 35.110 MHz
- 35.120 MHz
- 35.130 MHz
- 35.140 MHz
- 35.150 MHz
- 35.160 MHz
- 35.170 MHz
- 35.180 MHz
- 35.190 MHz
- 35.200 MHz
- 35.210 MHz
- 35.220 MHz
- 40 MHz band, shared with ISM and land mobile radio.
- 40.665 MHz - 100mW power limit, 40.690 MHz - 40.700 MHz
- 40.675 MHz - 100mW power limit, 40.690 MHz - 40.700 MHz
- 40.685 MHz - 100mW power limit, 40.690 MHz - 40.700 MHz
- 40.695 MHz - 100mW power limit, 40.690 MHz - 40.700 MHz
- 54 MHz band, model control.
- 54.4500 MHz
- 54.4625 MHz
- 54.4750 MHz
- 54.4875 MHz
- 54.5000 MHz
- 54.5125 MHz
- 54.5250 MHz
- 54.5375 MHz
- 54.5500 MHz
European regulations
- 2.4 GHz band
- 34.9975 MHz, mobile input for 31.9975 MHz - Channel 159, two frequency pair mobile TX
- 35.0100 MHz, mobile input for 32.0100 MHz - Channel 160, two frequency pair mobile TX
- 35.0225 MHz, mobile input for 32.0225 MHz - Channel 161, two frequency pair mobile TX
- 35.0350 MHz, mobile input for 32.0350 MHz - Channel 162, two frequency pair mobile TX
- 35.0475 MHz, mobile input for 32.0475 MHz - Channel 163, two frequency pair mobile TX
- 35.0600 MHz, mobile input for 32.0600 MHz - Channel 164, two frequency pair mobile TX
- 35.0725 MHz, mobile input for 32.0725 MHz - Channel 165, two frequency pair mobile TX
- 35.0850 MHz, mobile input for 32.0850 MHz - Channel 166, two frequency pair mobile TX
- 35.0975 MHz, mobile input for 32.0975 MHz - Channel 167, two frequency pair mobile TX
- 35.1100 MHz, mobile input for 32.1100 MHz - Channel 168, two frequency pair mobile TX
- 35.1225 MHz, mobile input for 32.1225 MHz - Channel 169, two frequency pair mobile TX
- 35.1350 MHz, mobile input for 32.1350 MHz - Channel 170, two frequency pair mobile TX
- 35.1475 MHz, mobile input for 32.1475 MHz - Channel 171, two frequency pair mobile TX
- 35.1600 MHz, mobile input for 32.1600 MHz - Channel 172, two frequency pair mobile TX
- 35.1725 MHz, mobile input for 32.1725 MHz - Channel 173, two frequency pair mobile TX
- 35.1850 MHz, mobile input for 32.1850 MHz - Channel 174, two frequency pair mobile TX
- 35.1975 MHz, mobile input for 32.1975 MHz - Channel 175, two frequency pair mobile TX
- 35.2100 MHz, mobile input for 32.2100 MHz - Channel 176, two frequency pair mobile TX
- 35.2225 MHz, mobile input for 32.2225 MHz - Channel 177, two frequency pair mobile TX
- 35.2350 MHz, mobile input for 32.2350 MHz - Channel 178, two frequency pair mobile TX
- 40.6610 MHz - Channel 575, single frequency simplex
- 40.6735 MHz - Channel 576, single frequency simplex
- 40.6860 MHz - Channel 577, single frequency simplex
- 40.6985 MHz - Channel 578, single frequency simplex
- 40.7110 MHz - Channel 579, single frequency simplex
