FM
No static at all.
Frequency Modulation
It is rarely used on HF frequencies, with some exceptions - land mobile systems operating in the 25-30 MHz region and the 27 MHz 11 meter CB operators in many countries - often in conjunction with AM and SSB, amateur radio operators using the FM in the 10 meter band, land mobile radio users operating on a small number of channelized frequencies in the 25 to 30 MHz range and some specialized maritime mobile (marine radio) systems used by fishing fleets, fishery radio networks, etc. In military contexts, "FM" is used to refer to the VHF-FM combat net radio / tactical radio systems operating in the (roughly) 30-88 MHz range, e.g. SINCGARS.
Narrow Band FM - Land Mobile Above 150 MHz
In the United States, Part 90 land mobile (business radio, public safety radio systems) operating above 150 MHz must use narrow band FM deviation (2.5 kHz deviation, 11.25 kHz bandwidth limit). The Part 95 license free Family Radio Service (FRS) also uses narrow for all 22 channels in simplex mode. For GMRS, regular "wide" deviation (4 kHz - 5 kHz deviation) is allowed on channels 15-22 (in simplex mode and as part of GMRS repeaters). Narrow mode is required on 3 of the 5 license free MURS channels on the VHF band.
Amateur radio and the VHF marine band are exempt from this requirement, as are services operating below 150 MHz (for land mobile, that means the 25 MHz - 50 MHz VHF low band and 72-76 MHz VHF mid band). Outside the U.S., use of narrow deviation is commonplace even on VHF low band.
