FM
No static at all.
Frequency Modulation
It is rarely used on HF frequencies, with some exceptions - land mobile systems operating in the 25-30 MHz region and the 27 MHz 11 meter CB operators in many countries - often in conjunction with AM and SSB, amateur radio operators using the FM in the 10 meter band, land mobile radio users operating on a small number of channelized frequencies in the 25 to 30 MHz range and some specialized maritime mobile (marine radio) systems used by fishing fleets, fishery radio networks, etc. In military contexts, "FM" is used to refer to the VHF-FM combat net radio / tactical radio systems operating in the (roughly) 30-88 MHz range, e.g. SINCGARS.
Narrow Band FM - Land Mobile Above 150 MHz
In the United States, the FCC requires Part 90 land mobile (business radio, public safety radio systems) operating above 150 MHz must use narrow band FM deviation (2.5 kHz deviation, 11.25 kHz bandwidth limit). This requirement went into effect in 2013 and is commonly known as the FCC narrowbanding mandate. Land mobile radios (Motorola, etc.) should be set to "12.5 kHz channel spacing" or "12.5 kHz channel" mode for narrow mode.
Other radios call this "12K" mode or simply "NARR" or "NARROW". Computer programming settings generally require switching the radio to NFM mode for narrowband FM (vs. FM mode for regular 4/5 kHz bandwidth). Land mobile licenses must reflect the use of the narrowband emission designator - 11K3F3E, 11K2F3E, 11K0F3E are all considered identical in the eyes of the FCC. Another example would be Alinco radios, which use 8.5 kHz bandwidth narrow band FM for narrow mode - emission: 8K50F3E and 16 kHz bandwidth for regular wide mode - emission: 16K0F3E.
The Part 95 license free Family Radio Service (FRS) also uses narrow for all 22 channels in simplex mode. For GMRS, regular "wide" deviation (4 kHz - 5 kHz deviation) is allowed on channels 15-22 (in simplex mode and as part of GMRS repeaters). Narrow mode is required on 3 of the 5 license free MURS channels on the VHF band. 4 kHz deviation is generally identified as "20 kHz bandwidth" or "20 kHz channel" with emission designator 16K0F3E or 16K0G3E on VHF marine, 5 kHz is called "25 kHz bandwidth" with emission designator 20K0F3E. In practice, 4 kHz and 5 kHz deviation are interchangeable with each other, however the wider deviation signal will sound louder on most receivers, and may cause distortion if the receiver is configured in the narrowband mode.
Amateur radio and the VHF marine band are exempt from this requirement, as are services operating below 150 MHz (for land mobile, that means the 25 MHz - 50 MHz VHF low band and 72-76 MHz VHF mid band). Outside the U.S., use of narrow deviation is commonplace even on VHF low band.
