Revision as of 14:54, 4 July 2026 by R4002 (Talk | contribs)
  • 26.995 MHz - 26995 kHz - Brown or 27 MHz RC Channel 1 (Unofficial CB "channel" 3A) - 4 watt power limit
  • 27.045 MHz - 27045 kHz - Red or 27 MHz RC Channel 2 (Unofficial CB "channel" 7A) - 4 watt power limit
  • 27.095 MHz - 27095 kHz - Orange or 27 MHz RC Channel 3 (Unofficial CB "channel" 11A) - 4 watt power limit
  • 27.145 MHz - 27145 kHz - Yellow or 27 MHz RC Channel 4 (Unofficial CB "channel" 15A) - 4 watt power limit
  • 27.195 MHz - 27195 kHz - Green or 27 MHz RC Channel 5 (Unofficial CB "channel" 19A) - 4 watt power limit
  • 27.255 MHz - 27255 kHz - Blue or 27 MHz RC Channel 6 (CB Channel 23 - shared with Part D CB voice users) - 25 watt power limit
40 MHz RC Frequencies
As of the mid 2020s, 40 MHz R/C toys (operating under Part 15 Subpart C Part 15C of the FCC rules - like all other intentional radiatiors - specifically 15.229 ) have appeared on the market. 40.68 MHz operating frequency. AFSK modulation - tone signal control using a FM radio channel on 40.680 MHz, FSK modulation and on/off keying (OOK) type signals. Audio shift keying with 46.96 dBuV/m transmitter power.
40.66 MHz - 40.70 MHz frequency band. Field strength is limited to 1,000 microvolts/meter at 3m. 40.68 MHz, 40.681 MHz, 40.685 MHz and other frequencies reportedly in use. Inexpensive RC toys are now offered in three different frequency band versions - the 27 MHz version, 40 MHz version and 49 MHz version.
49 MHz RC Frequencies
  • 49.830 MHz - Channel A
  • 49.845 MHz - Channel B
  • 49.860 MHz - Channel C
  • 49.875 MHz - Channel D
  • 49.890 MHz - Channel E
  • 50.800 MHz - 50 MHz RC Channel 00 freq 50.8 MHz
  • 50.820 MHz - 50 MHz RC Channel 01 freq 50.82 MHz
  • 50.840 MHz - 50 MHz RC Channel 02 freq 50.84 MHz
  • 50.860 MHz - 50 MHz RC Channel 03 freq 50.86 MHz
  • 50.880 MHz - 50 MHz RC Channel 04 freq 50.88 MHz
  • 50.900 MHz - 50 MHz RC Channel 05 freq 50.9 MHz
  • 50.920 MHz - 50 MHz RC Channel 06 freq 50.92 MHz
  • 50.940 MHz - 50 MHz RC Channel 07 freq 50.94 MHz
  • 50.960 MHz - 50 MHz RC Channel 08 freq 50.96 MHz
  • 50.980 MHz - 50 MHz RC Channel 09 freq 50.98 MHz
  • 53.100 MHz - 53 MHz RC Brown/Black 53.1 MHz
  • 53.200 MHz - 53 MHz RC Red/Black 53.2 MHz
  • 53.300 MHz - 53 MHz RC Orange/Black 53.3 MHz
  • 53.400 MHz - 53 MHz RC Yellow/Black 53.4 MHz
  • 53.500 MHz - 53 MHz RC Green/Black 53.5 MHz
  • 53.600 MHz - 53 MHz RC Blue/Black 53.6 MHz
  • 53.700 MHz - 53 MHz RC Purple/Black 53.7 MHz
  • 53.800 MHz - 53 MHz RC Grey/Black 53.8 MHz
Frequency coordination groups often do not include the 53MHz frequencies as assigned for remote control, instead recommending only use of the 50.8 MHz - 50.98 MHz band
This spectrum is also shared with military radios / combat net radio (CNR) FM tactical radio systems operating both in fixed frequency single channel (SC) mode and frequency hopping (FH) mode. This includes older generation 30-76 MHz systems and newer 30-88 MHz systems.
  • 72.010 MHz
  • 72.030 MHz
  • 72.050 MHz
  • 72.070 MHz
  • 72.090 MHz
  • 72.110 MHz
  • 72.130 MHz
  • 72.150 MHz
  • 72.170 MHz
  • 72.190 MHz
  • 72.210 MHz
  • 72.230 MHz
  • 72.250 MHz
  • 72.270 MHz
  • 72.290 MHz
  • 72.310 MHz
  • 72.330 MHz
  • 72.350 MHz
  • 72.370 MHz
  • 72.390 MHz
  • 72.410 MHz
  • 72.430 MHz
  • 72.450 MHz
  • 72.470 MHz
  • 72.490 MHz
  • 72.510 MHz
  • 72.530 MHz
  • 72.550 MHz
  • 72.570 MHz
  • 72.590 MHz
  • 72.610 MHz
  • 72.630 MHz
  • 72.650 MHz
  • 72.670 MHz
  • 72.690 MHz
  • 72.710 MHz
  • 72.730 MHz
  • 72.750 MHz
  • 72.770 MHz
  • 72.790 MHz
  • 72.810 MHz
  • 72.830 MHz
  • 72.850 MHz
  • 72.870 MHz
  • 72.890 MHz
  • 72.910 MHz
  • 72.930 MHz
  • 72.950 MHz
  • 72.970 MHz
  • 72.990 MHz
  • 75.410 MHz
  • 75.430 MHz
  • 75.450 MHz
  • 75.470 MHz
  • 75.490 MHz
  • 75.510 MHz
  • 75.530 MHz
  • 75.550 MHz
  • 75.570 MHz
  • 75.590 MHz
  • 75.610 MHz
  • 75.630 MHz
  • 75.650 MHz
  • 75.670 MHz
  • 75.690 MHz
  • 75.710 MHz
  • 75.730 MHz
  • 75.750 MHz
  • 75.770 MHz
  • 75.790 MHz
  • 75.810 MHz
  • 75.830 MHz
  • 75.850 MHz
  • 75.870 MHz
  • 75.890 MHz
  • 75.910 MHz
  • 75.930 MHz
  • 75.950 MHz
  • 75.970 MHz
  • 75.990 MHz
900 MHz RC Frequencies
902-928 MHz limits:
2.4 GHz RC Frequencies
5.8 GHz RC Frequencies
5725 MHz - 5875 MHz 5.725 GHz - 5.875 GHz 5.8G band 5.8 GHz band center frequency 5800 MHz
Canada
47 MHz band
  • 47.020 MHz
  • 47.030 MHz
  • 47.050 MHz
  • 47.050 MHz
  • 47.070 MHz
  • 47.110 MHz
  • 47.130 MHz
  • 47.150 MHz
  • 47.170 MHz
  • 47.230 MHz
  • 47.250 MHz
  • 47.270 MHz
  • 47.290 MHz
  • 47.300 MHz
  • 47.310 MHz
  • 47.330 MHz
  • 47.350 MHz
49 MHz band
72 MHz band
  • 72.010 MHz - Channel 11
  • 72.030 MHz - Channel 12
  • 72.050 MHz - Channel 13
  • 72.070 MHz - Channel 14
  • 72.090 MHz - Channel 15
  • 72.110 MHz - Channel 16
  • 72.130 MHz - Channel 17
  • 72.150 MHz - Channel 18
  • 72.170 MHz - Channel 19
  • 72.190 MHz - Channel 20
  • 72.210 MHz - Channel 21
  • 72.230 MHz - Channel 22
  • 72.250 MHz - Channel 23
  • 72.270 MHz - Channel 24
  • 72.290 MHz - Channel 25
  • 72.310 MHz - Channel 26
  • 72.330 MHz - Channel 27
  • 72.350 MHz - Channel 28
  • 72.370 MHz - Channel 29
  • 72.390 MHz - Channel 30
  • 72.410 MHz - Channel 31
  • 72.430 MHz - Channel 32
  • 72.450 MHz - Channel 33
  • 72.470 MHz - Channel 34
  • 72.490 MHz - Channel 35
  • 72.510 MHz - Channel 36
  • 72.530 MHz - Channel 37
  • 72.550 MHz - Channel 38
  • 72.570 MHz - Channel 39
  • 72.590 MHz - Channel 40
  • 72.610 MHz - Channel 41
  • 72.630 MHz - Channel 42
  • 72.650 MHz - Channel 43
  • 72.670 MHz - Channel 44
  • 72.690 MHz - Channel 45
  • 72.710 MHz - Channel 46
  • 72.730 MHz - Channel 47
  • 72.750 MHz - Channel 48
  • 72.770 MHz - Channel 49
  • 72.790 MHz - Channel 50
  • 72.810 MHz - Channel 51
  • 72.830 MHz - Channel 52
  • 72.850 MHz - Channel 53
  • 72.870 MHz - Channel 54
  • 72.890 MHz - Channel 55
  • 72.910 MHz - Channel 56
  • 72.930 MHz - Channel 57
  • 72.950 MHz - Channel 58
  • 72.970 MHz - Channel 59
  • 72.990 MHz - Channel 60
75 MHz band
  • 75.410 MHz - Channel 61
  • 75.430 MHz - Channel 62
  • 75.450 MHz - Channel 63
  • 75.470 MHz - Channel 64
  • 75.490 MHz - Channel 65
  • 75.510 MHz - Channel 66
  • 75.530 MHz - Channel 67
  • 75.550 MHz - Channel 68
  • 75.570 MHz - Channel 69
  • 75.590 MHz - Channel 70
  • 75.610 MHz - Channel 71
  • 75.630 MHz - Channel 72
  • 75.650 MHz - Channel 73
  • 75.670 MHz - Channel 74
  • 75.690 MHz - Channel 75
  • 75.710 MHz - Channel 76
  • 75.730 MHz - Channel 77
  • 75.750 MHz - Channel 78
  • 75.770 MHz - Channel 79
  • 75.790 MHz - Channel 80
  • 75.810 MHz - Channel 81
  • 75.830 MHz - Channel 82
  • 75.850 MHz - Channel 83
  • 75.870 MHz - Channel 84
  • 75.890 MHz - Channel 85
  • 75.910 MHz - Channel 86
  • 75.930 MHz - Channel 87
  • 75.950 MHz - Channel 88
  • 75.970 MHz - Channel 89
  • 75.990 MHz - Channel 90
The UK has relatively strict regulations regarding model control or telecommand for RC R/C devices. 900 MHz band is not allowed for RC purposes. Both the 72 MHz and 75 MHz bands are not legal to use in the UK
26.96 MHz to 27.28 MHz band. New channel numbering sequence. New UK 27 MHz RC channels. 100mW ERP transmit power limit, 10 kHz bandwidth limit. 27MHz AM RC. Only 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz are specifically designated for non-CB voice use. The other channels are shared with the EU standardized CEPT or "mid band" CB allocation (AM/FM/SSB) and therefore may experience serious interference due to nearby strong CB signals. Older-generation 20 kHz bandwidth equipment remains legal to use.
Only channel 4 (Brown), Channel 9 (Red), Channel 14 (Yellow) and Channel 19 (Green) are allocated for remote control and data/telemetry use. The other frequencies are also used for the CB radio service. Channels 4, 9, 14 and 19 may be used for airborne transmissions.
See IR2030/23/1
  • 26.965 MHz - RC Channel 1
  • 26.985 MHz - RC Channel 3
  • 26.995 MHz - RC Channel 4 - Brown
  • 27.005 MHz - RC Channel 5
  • 27.015 MHz - RC Channel 6
  • 27.035 MHz - RC Channel 8
  • 27.045 MHz - RC Channel 9 - Red
  • 27.055 MHz - RC Channel 10
  • 27.065 MHz - RC Channel 11
  • 27.085 MHz - RC Channel 13
  • 27.095 MHz - RC Channel 14 - Orange
  • 27.105 MHz - RC Channel 15
  • 27.115 MHz - RC Channel 16
  • 27.135 MHz - RC Channel 18
  • 27.145 MHz - RC Channel 19 - Yellow
  • 27.155 MHz - RC Channel 20
  • 27.165 MHz - RC Channel 21
  • 27.185 MHz - RC Channel 23
  • 27.195 MHz - RC Channel 24 - Green
  • 27.205 MHz - RC Channel 25
  • 27.215 MHz - RC Channel 26
  • 27.235 MHz - RC Channel 28
  • 27.245 MHz - RC Channel 29
  • 27.265 MHz - RC Channel 31
Channel numbering varies, may be sequential channels 1-36 inclusive.
  • 34.950 MHz - Channel 55
  • 34.960 MHz - Channel 56
  • 34.970 MHz - Channel 57
  • 34.980 MHz - Channel 58
  • 34.990 MHz - Channel 59
  • 35.000 MHz - Channel 60
  • 35.010 MHz - Channel 61
  • 35.020 MHz - Channel 62
  • 35.030 MHz - Channel 63
  • 35.040 MHz - Channel 64
  • 35.050 MHz - Channel 65
  • 35.060 MHz - Channel 66
  • 35.070 MHz - Channel 67
  • 35.080 MHz - Channel 68
  • 35.090 MHz - Channel 69
  • 35.100 MHz - Channel 70
  • 35.110 MHz - Channel 71
  • 35.120 MHz - Channel 72
  • 35.130 MHz - Channel 73
  • 35.140 MHz - Channel 74
  • 35.150 MHz - Channel 75
  • 35.160 MHz - Channel 76
  • 35.170 MHz - Channel 77
  • 35.180 MHz - Channel 78
  • 35.190 MHz - Channel 79
  • 35.200 MHz - Channel 80
  • 35.210 MHz - Channel 81
  • 35.220 MHz - Channel 82
  • 35.230 MHz - Channel 83
  • 35.240 MHz - Channel 84
  • 35.250 MHz - Channel 85
  • 35.260 MHz - Channel 86
  • 35.270 MHz - Channel 87
  • 35.280 MHz - Channel 88
  • 35.290 MHz - Channel 89
  • 35.300 MHz - Channel 90
49 MHz Band - Non Specific Short Range Devices
IR2030/1/5
Airborne transmitter use prohibited.
49.82 MHz - 49.9 MHz band, 10mW EIRP maximum.
25 kHz spacing 433.05 MHz - 434.775 MHz
459 MHz Band - UHF
  • 458.525 MHz - Channel 1
  • 458.550 MHz - Channel 2
  • 458.575 MHz - Channel 3
  • 458.600 MHz - Channel 4
  • 458.625 MHz - Channel 5
  • 458.650 MHz - Channel 6
  • 458.675 MHz - Channel 7
  • 458.700 MHz - Channel 8
  • 458.725 MHz - Channel 9
  • 458.750 MHz - Channel 10
  • 458.775 MHz - Channel 11
  • 458.800 MHz - Channel 12
  • 458.825 MHz - Channel 13
  • 458.850 MHz - Channel 14
  • 458.875 MHz - Channel 15
  • 458.900 MHz - Channel 16
  • 458.925 MHz - Channel 17
  • 458.950 MHz - Channel 18
  • 458.975 MHz - Channel 19
  • 459.000 MHz - Channel 20
  • 459.025 MHz - Channel 21
  • 459.050 MHz - Channel 22
  • 459.075 MHz - Channel 23
  • 459.100 MHz - Channel 24
  • 459.125 MHz - Channel 25
  • 459.150 MHz - Channel 26
  • 459.175 MHz - Channel 27
  • 459.200 MHz - Channel 28
  • 459.225 MHz - Channel 29
  • 459.250 MHz - Channel 30
  • 459.275 MHz - Channel 31
  • 459.300 MHz - Channel 32
  • 459.325 MHz - Channel 33
  • 459.350 MHz - Channel 34
  • 459.375 MHz - Channel 35
  • 459.400 MHz - Channel 36
  • 459.425 MHz - Channel 37
  • 459.450 MHz - Channel 38
  • 459.475 MHz - Channel 39
  • 900 MHz Band
  • 2.4 GHz Band
100mW power output EIRP permitted. 80 discrete channels. Some sources indicate 40 channels. Previous power limited to 10mW or 25mW. UK regulations for the 2.4 GHz band and the 5 GHz band are considerably more strict compared to the United States.
  • 5.8 GHz Band
  • CEPT ETSI SRD Bands
100 milliwatt limit on the 5 RC 26-28 MHz channels. 10 kHz bandwidth limit on the 5 specific channels. 10 milliwatt limit on any other frequency within the 26957-27283 SRD band. Model control devices may operate without any duty cycle restriction. Other nonspecific short range devices are limited to 0.1% duty cycle on the 27 MHz frequencies
  • 26957 kHz - 27283 kHz or 26.957 MHz - 27.283 MHz - 10mW ERP - "Band No. 28"
  • 26990 kHz - 27000 kHz or 26.990 MHz - 27.000 MHz - center frequency 26995 kHz or 26.995 MHz - 100mW ERP - ERC/DEC(01)10 - "Band No. 29"
  • 27040 kHz - 27090 kHz or 27.040 MHz - 27.050 MHz - center frequency 27045 kHz or 27.045 MHz - 100mW ERP - ERC/DEC(01)10 - "Band No. 30"
  • 27090 kHz - 27100 kHz or 27.090 MHz - 27.100 MHz - center frequency 27095 kHz or 27.095 MHz - 100mW ERP - ERC/DEC(01)10 - "Band No. 31"
  • 27140 kHz - 27150 kHz or 27.140 MHz - 27.150 MHz - center frequency 27145 kHz or 27.145 MHz - 100mW ERP - ERC/DEC(01)10 - "Band No. 32"
  • 27190 kHz - 27200 kHz or 27.190 MHz - 27.200 MHz - center frequency 27195 kHz or 27.195 MHz - 100mW ERP - ERC/DEC(01)10 - "Band No. 33"
  • 138.200 MHz to 138.450 MHz
  • 169.400 MHz to 169.8125 MHz
  • 863 MHz to 876 MHz
  • 34.995 MHz to 35.225 MHz and 35.8 MHz to 35.92 MHz - 35 MHz RC band European standardized aero models only (flying models, aircraft models only, including drones / UAVs / UAS links or whatever you want to call them) CEPT 35 MHz band, 5/10 kHz spacing, generally starting at 35.000 MHz going up to 35.220 MHz in 10 kHz steps. Some countries have additional allocations above and below the EU standardized band. ITU “worldwide” standardization for SRDs - Short Range Devices - on the 40.66 MHz - 40.70 MHz band exists, but with a power limit of 10mW ERP. Several countries permit 100mW on the 35 MHz RC channels and/or the 40 MHz RC channels. As of 2026, this is referred to as "Model Control - Aeromodels Band B". Some counties only allow some of the following 35 MHz frequencies to be used, and/or the frequencies are shared with other services.
  • 35.820 MHz - Channel 182
  • 35.830 MHz - Channel 183
  • 35.840 MHz - Channel 184
  • 35.850 MHz - Channel 185
  • 35.860 MHz - Channel 186
  • 35.870 MHz - Channel 187
  • 35.880 MHz - Channel 188
  • 35.890 MHz - Channel 189
  • 35.900 MHz - Channel 190
  • 35.910 MHz - Channel 191
  • 40.660 MHz to 40.700 MHz and 40.700 MHz to 41.000 MHz 40 MHz RC band or "40.68 MHz Band" See above, many countries provide additional frequencies above and/or below the 40.68 MHz center frequency. Note the additional allocation from 40.715 MHz to 40.985 MHz (with several skipped channels). The 40.665 MHz, 40.675 MHz, 40.680 MHz 40.685 MHz and 40.695 MHz frequencies available for aircraft or surface craft (cars, boats, etc.) use. This spectrum is also used for R/C model control purposes in the United States under limited circumstances.
  • 40.66 MHz - 40.67 MHz - C1 - 100mW ERP
  • 40.67 MHz - 40.68 MHz - C2 - 100mW ERP
  • 40.68 MHz - 40.69 MHz - C3 - 100mW ERP
  • 40.69 MHz - 40.70 MHz - C4 - 100mW ERP
Czech Republic
13.56 MHz band / 22 meter band
  • 13.560 MHz 13560 kHz 13,560 kHz
100mW E.I.R.P. limit, may be used to control any type of device. Covered under regulation “General Authorisation No. VO-R/15/08.2005-27 for the use of radio frequencies and for the operation of equipment for remote control of models in the 13 MHz to 40 MHz band”
  • 25,670 kHz - 26,100 kHz
  • 26,100 kHz - 26,175 kHz
  • 26,175 kHz - 26,200 kHz
  • 26,200 kHz - 26,350 kHz
  • 26,350 kHz - 26,957 kHz
  • 26,560 kHz - 27,410 kHz
  • 26,957 kHz - 27,405 kHz
  • 27,405 kHz - 27,500 kHz
  • 27,500 kHz - 28,000 kHz
The 27MHz frequencies overlap with other remote control, data link, telemetry, paging as well as land mobile services, the CADS / WPAS Church Radio Service / Parish Radio Services and the UK FM 27/81 CB radio service.
  • 32.875 MHz
  • 32.900 MHz
  • 32.925 MHz
  • 32.950 MHz
  • 32.975 MHz
34 MHz FM - 1 watt ERP maximum power 4 channels. 16 kHz bandwidth limit, 16K0F1D or 16K0F2D 34.05 MHz to 34.175 MHz
  • 34.050 MHz
  • 34.075 MHz
  • 34.150 MHz
  • 34.175 MHz
  • 35.000 MHz - C1
  • 35.010 MHz - C2
  • 35.020 MHz - C3
  • 35.030 MHz - C4
  • 35.040 MHz - C5
  • 35.050 MHz - C6
  • 35.060 MHz - C7
  • 35.070 MHz - C8
  • 35.080 MHz - C9
  • 35.090 MHz - C10
  • 35.100 MHz - C11
  • 35.110 MHz - C12
  • 35.120 MHz - C13
  • 35.130 MHz - C14
  • 35.140 MHz - C15
  • 35.150 MHz - C16
  • 35.160 MHz - C17
  • 35.170 MHz - C18
  • 35.180 MHz - C19
  • 35.190 MHz - C20
  • 35.200 MHz - C21
  • 35.210 MHz - C22
  • 35.220 MHz - C23
  • 35.820 MHz - D1
  • 35.830 MHz - D2
  • 35.840 MHz - D3
  • 35.850 MHz - D4
  • 35.860 MHz - D5
  • 35.870 MHz - D6
  • 35.880 MHz - D7
  • 35.890 MHz - D8
  • 35.900 MHz - D9
  • 35.910 MHz - D10
57 MHz Low Power Data Links:
  • 57.225 MHz
  • 57.250 MHz
  • 57.275 MHz
  • 57.300 MHz
VHF Mid Band 77-81 MHz Low Power Service - 1 watt ERP maximum output power. 16 kHz bandwidth limits. Portable stations only. See the related “wireless local information service” (BMIS) that also operates on the 70 MHz spectrum.
  • 77.025 MHz
  • 77.050 MHz
  • 77.075 MHz
  • 77.100 MHz
  • 77.725 MHz
  • 78.000 MHz
  • 81.725 MHz
  • 81.750 MHz
VHF High Band
France
  • 26.815 MHz - 26815 kHz
  • 26.825 MHz - 26825 kHz
  • 26.835 MHz - 26835 kHz
  • 26.845 MHz - 26845 kHz
  • 26.855 MHz - 26855 kHz
  • 26.865 MHz - 26865 kHz
  • 26.875 MHz - 26875 kHz
  • 26.885 MHz - 26885 kHz
  • 26.895 MHz - 26895 kHz
  • 26.905 MHz - 26905 kHz
  • 26.915 MHz - 26915 kHz
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
2.4 GHz Band
2400 MHz - 2500 MHz, center frequency 2.45 GHz
Maximum power 100mW
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.820 MHz
  • 35.830 MHz
  • 35.840 MHz
  • 35.850 MHz
  • 35.860 MHz
  • 35.870 MHz
  • 35.880 MHz
  • 35.890 MHz
  • 35.900 MHz
  • 35.910 MHz
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
Italy
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
35 MHz Band -
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.705 MHz
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
  • 40.805 MHz
  • 40.815 MHz
  • 40.825 MHz
  • 40.835 MHz
  • 40.845 MHz
  • 40.855 MHz
  • 40.865 MHz
  • 40.875 MHz
  • 72.080 MHz
  • 72.240 MHz
433 MHz Band - LPD433
2.4 GHz Band
5.8 GHz Band
Spain
27 MHz fixed/mobile service, 27.5 MHz to 27.6 MHz and 27.84 MHz to 27.86 MHz
Power output limited to 20 watts. Paging, telecommand, telemetry and data, including to/from mobile units, data or voice. F3E, F3D, A3E, F2D, F1D, A2D, A1D, A0A, G3E, G3D, G2D, G1D emissions. Overlaps with Swiss 27MHz PAMR allocation for frequencies 27.545 MHz and 27.845 MHz. The 27.575 MHz and 27.585 MHz frequencies clash with the U.S. Government’s Short Distance Low Power Radio Service. Also partially overlaps with the UK FM CB radio 27/81 allocation and related CADS / WPAS 27MHz church radio broadcast systems used in Ireland, etc.
  • 27505 kHz - 27.505 MHz
  • 27515 kHz - 27.515 MHz
  • 27525 kHz - 27.525 MHz
  • 27535 kHz - 27.535 MHz
  • 27545 kHz - 27.545 MHz
  • 27555 kHz - 27.555 MHz
  • 27565 kHz - 27.565 MHz
  • 27575 kHz - 27.575 MHz
  • 27585 kHz - 27.585 MHz
  • 27595 kHz - 27.595 MHz
  • 27845 kHz - 27.845 MHz
  • 27855 kHz - 27.855 MHz
  • 29.710 MHz
  • 29.720 MHz
  • 29.730 MHz
  • 29.740 MHz
  • 29.750 MHz
  • 29.760 MHz
  • 29.770 MHz
  • 29.780 MHz
  • 29.790 MHz
  • 29.800 MHz
  • 29.810 MHz
  • 29.820 MHz
  • 29.830 MHz
  • 29.840 MHz
  • 29.850 MHz
  • 29.860 MHz
  • 29.870 MHz
  • 29.880 MHz
  • 29.890 MHz
  • 29.900 MHz
  • 29.910 MHz
  • 29.920 MHz
  • 29.930 MHz
  • 29.940 MHz
  • 29.950 MHz
  • 29.960 MHz
  • 29.970 MHz
  • 29.980 MHz
  • 29.990 MHz
  • 30.035 MHz
  • 30.045 MHz
  • 30.055 MHz
  • 30.065 MHz
  • 30.075 MHz
  • 30.085 MHz
  • 30.095 MHz
  • 30.105 MHz
  • 30.115 MHz
  • 30.125 MHz
  • 30.135 MHz
  • 30.145 MHz
  • 30.155 MHz
  • 30.165 MHz
  • 30.175 MHz
  • 30.185 MHz
  • 30.195 MHz
  • 30.205 MHz
  • 30.215 MHz
  • 30.225 MHz
  • 30.235 MHz
  • 30.245 MHz
  • 30.255 MHz
  • 30.265 MHz
  • 30.275 MHz
  • 30.285 MHz
  • 30.295 MHz
  • 40 MHz Band
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.875 MHz
  • 40.900 MHz
  • 40.925 MHz
  • 40.950 MHz
Switzerland
RIR1007 specifications
27 MHz SRDs 27 MHz RC
27.42 MHz to 27.49 MHz, 27.54 MHz to 27.55 MHz and 27.61 MHz to 27.93 MHz allocations - 27.610 MHz to 27.930 MHz 27610 kHz to 27930 kHz band overlaps with various other services, including UK FM CB radio 27/81 band 27.60125 MHz - 27.99125 MHz, allocations in Spain for paging systems, the CADS / WPAS "Parish radio" services 27.6 MHz - 28.0 MHz used in Ireland and the UK, and many others.
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
  • 40.665 MHz - Channel A
  • 40.675 MHz - Channel B
  • 40.685 MHz - Channel C
  • 40.695 MHz - Channel D
The 40.715 MHz - 40.985 MHz allocation is no longer available, it was withdrawn in 2012.
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
  • 40.805 MHz
  • 40.815 MHz
  • 40.825 MHz
  • 40.835 MHz
  • 40.845 MHz
  • 40.855 MHz
  • 40.865 MHz
  • 40.875 MHz
  • 40.885 MHz
  • 40.895 MHz
  • 40.905 MHz
  • 40.915 MHz
  • 40.925 MHz
  • 40.935 MHz
  • 40.945 MHz
  • 40.955 MHz
  • 40.965 MHz
  • 40.975 MHz
  • 40.985 MHz
433 MHz Band
  • 433.250 MHz
  • 433.300 MHz
  • 433.600 MHz
  • 433.700 MHz
  • 433.750 MHz
  • 434.150 MHz
  • 434.400 MHz
  • 434.450 MHz
  • 434.500 MHz
2.4 GHz band
2.4 GHz band or 2.4G band
5.8 GHz band
Sweden
  • 35.000 MHz - RC Channel 60
  • 35.010 MHz - RC Channel 61
  • 35.020 MHz - RC Channel 62
  • 35.030 MHz - RC Channel 63
  • 35.040 MHz - RC Channel 64
  • 35.050 MHz - RC Channel 65
  • 35.060 MHz - RC Channel 66
  • 35.070 MHz - RC Channel 67
  • 35.080 MHz - RC Channel 68
  • 35.090 MHz - RC Channel 69
  • 35.100 MHz - RC Channel 70
  • 35.110 MHz - RC Channel 71
  • 35.120 MHz - RC Channel 72
  • 35.130 MHz - RC Channel 73
  • 35.140 MHz - RC Channel 74
  • 35.150 MHz - RC Channel 75
  • 35.160 MHz - RC Channel 76
  • 35.170 MHz - RC Channel 77
  • 35.180 MHz - RC Channel 78
  • 35.190 MHz - RC Channel 79
  • 35.200 MHz - RC Channel 80
  • 35.210 MHz - RC Channel 81
  • 35.220 MHz - RC Channel 82
  • 35.230 MHz - RC Channel 83
  • 35.240 MHz - RC Channel 84
  • 35.250 MHz - RC Channel 85
  • 35.260 MHz - RC Channel 86
  • 35.270 MHz - RC Channel 87
  • 40.665 MHz
  • 40.675 MHz
  • 40.685 MHz
  • 40.695 MHz
  • 40.705 MHz
  • 40.715 MHz
  • 40.725 MHz
  • 40.735 MHz
  • 40.745 MHz
  • 40.755 MHz
  • 40.765 MHz
  • 40.775 MHz
  • 40.785 MHz
  • 40.795 MHz
439 MHz UHF band 25 kHz channel spacing Power limit (EIRP) 500mW 0.5w limit E.I.R.P.
  • 439.700 MHz
  • 439.725 MHz
  • 439.750 MHz
  • 439.775 MHz
  • 439.800 MHz
  • 439.825 MHz
  • 439.850 MHz
  • 439.875 MHz
  • 439.900 MHz
  • 439.925 MHz
  • 439.950 MHz
  • 439.975 MHz
2.4 GHz band
2.4 GHz - 2.4835 GHz or 2400 MHz - 2483.5 MHz
Max 100 mW E.I.R.P. if spread spectrum technology is used, otherwise 10 mW/MHz eirp.
Finland
  • 26825 kHz 26.825 MHz
  • 26845 kHz 26.845 MHz
  • 26865 kHz 26.865 MHz
  • 26885 kHz 26.885 MHz
  • 26905 kHz 26.905 MHz
  • 26925 kHz 26.925 MHz
  • 26935 kHz 26.935 MHz
  • 26945 kHz 26.945 MHz
  • 26995 kHz 26.995 MHz
  • 27095 kHz 27.045 MHz
  • 27095 kHz 27.095 MHz
  • 27145 kHz 27.145 MHz
  • 27195 kHz 27.195 MHz
  • 27255 kHz 27.255 MHz
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
Norway
  • 30.010 MHz
  • 30.020 MHz
  • 30.030 MHz
  • 30.040 MHz
  • 30.050 MHz
  • 30.060 MHz
  • 30.070 MHz
  • 30.080 MHz
  • 30.090 MHz
  • 30.100 MHz
  • 30.110 MHz
  • 30.120 MHz
  • 30.130 MHz
  • 30.140 MHz
  • 30.150 MHz
  • 30.160 MHz
  • 30.170 MHz
  • 30.180 MHz
  • 30.190 MHz
  • 30.200 MHz
  • 30.210 MHz
  • 30.220 MHz
  • 30.230 MHz
  • 30.240 MHz
  • 30.250 MHz
  • 30.260 MHz
  • 30.270 MHz
  • 30.280 MHz
  • 30.290 MHz
  • 30.290 MHz
  • 30.300 MHz
Denmark
  • Frequencies
  • 138.650 MHz - 500mW ERP
  • Bands
Russia
  • 26.995 MHz - 10mW power limit, 3dB antenna gain, 26990 kHz - 27000 kHz
  • 27.045 MHz - 10mW power limit, 3dB antenna gain, 27040 kHz - 27050 kHz
  • 27.095 MHz - 10mW power limit, 3dB antenna gain, 27090 kHz - 27100 kHz
  • 27.145 MHz - 10mW power limit, 3dB antenna gain, 27140 kHz - 27150 kHz
  • 27.195 MHz - 10mW power limit, 3dB antenna gain, 27190 kHz - 27200 kHz
  • 28.000 MHz - 28.200 MHz - 1 watt power limit, 3dB antenna gain limit (shared with ham radio)
35 MHz band - 34.995 MHz - 35.225 MHz 10 kHz spacing
40 MHz band - 40.66 MHz - 40.7 MHz 1 watt power limit, 3dB antenna gain
2.4 GHz band - 2400 MHz - 2483.5 MHz 100mW / 10mW limit
5.8 GHz band - 5725 MHz - 5875 MHz
27 MHz
  • 26.975 MHz - Channel 01
  • 26.995 MHz - Channel 02
  • 27.025 MHz - Channel 03
  • 27.075 MHz - Channel 05
  • 27.095 MHz - Channel 06
  • 27.145 MHz - Channel 08
  • 27.175 MHz - Channel 09
  • 27.195 MHz - Channel 10
  • 27.225 MHz - Channel 11
  • 27.255 MHz - Channel 12
  • 72.130 MHz - Aircraft only
  • 72.150 MHz - Aircraft only
  • 72.170 MHz - Aircraft only
  • 72.190 MHz - Aircraft only
  • 72.210 MHz - Aircraft only
  • 72.790 MHz - Aircraft only
  • 72.810 MHz - Aircraft only
  • 72.830 MHz - Aircraft only
  • 72.850 MHz - Aircraft only
  • 72.870 MHz - Aircraft only
  • 73.220 MHz - General RC use
  • 73.230 MHz - General RC use
  • 73.240 MHz - General RC use
  • 73.250 MHz - General RC use
  • 73.260 MHz - General RC use
  • 73.270 MHz - General RC use
  • 73.280 MHz - General RC use
  • 73.290 MHz - General RC use
  • 73.300 MHz - General RC use
  • 73.310 MHz - General RC use
  • 73.320 MHz - General RC use
  • 2441.75 MHz
  • 2484 MHz
  • Specified Low Power Radio Stations (this includes telemetery, telecommand or "telecontrol" (remote control, wireless control) as well as the Specified Low Power Radio Service. UHF service, 420 MHz - 430 MHz, plus 449 MHz and 469 MHz bands.
  • 426.028125 MHz
  • 426.034375 MHz
  • 426.040625 MHz
  • 426.046875 MHz
  • 426.053125 MHz
  • 426.059375 MHz
  • 426.065625 MHz
  • 426.071875 MHz
  • 426.078125 MHz
  • 426.084375 MHz
  • 426.090625 MHz
  • 426.096875 MHz
  • 426.103125 MHz
  • 426.109375 MHz
  • 426.115625 MHz
  • 426.121875 MHz
  • 426.128125 MHz
  • 426.134375 MHz
  • 429.178125 MHz
  • 429.184375 MHz
  • 429.190625 MHz
  • 429.196875 MHz
  • 429.203125 MHz
  • 429.209375 MHz
  • 429.215625 MHz
  • 429.221875 MHz
  • 429.228125 MHz
  • 429.234375 MHz
  • 429.240625 MHz
  • 429.246875 MHz
  • 429.253125 MHz
  • 429.259375 MHz
  • 429.265625 MHz
  • 429.271875 MHz
  • 429.278125 MHz
  • 429.284375 MHz
  • 429.290625 MHz
  • 429.296875 MHz
  • 429.303125 MHz
  • 429.409375 MHz
  • 429.415625 MHz
  • 429.421875 MHz
  • 429.428125 MHz
  • 429.434375 MHz
  • 429.440625 MHz
  • 429.446875 MHz
  • 429.453125 MHz
  • 429.459375 MHz
  • 429.465625 MHz
  • 429.471875 MHz
  • 429.478125 MHz
  • 429.484375 MHz
  • 429.490625 MHz
  • 429.496875 MHz
  • 429.503125 MHz
  • 429.509375 MHz
  • 429.515625 MHz
  • 429.521875 MHz
  • 429.528125 MHz
  • 429.534375 MHz
  • 429.540625 MHz
  • 429.546875 MHz
  • 429.553125 MHz
  • 429.559375 MHz
  • 429.565625 MHz
  • 429.571875 MHz
  • 429.578125 MHz
  • 429.584375 MHz
  • 429.590625 MHz
  • 429.596875 MHz
  • 429.603125 MHz
  • 429.609375 MHz
  • 429.615625 MHz
  • 429.621875 MHz
  • 429.628125 MHz
  • 429.634375 MHz
  • 429.640625 MHz
  • 429.646875 MHz
  • 429.653125 MHz
  • 429.659375 MHz
  • 429.665625 MHz
  • 429.671875 MHz
  • 429.678125 MHz
  • 429.684375 MHz
  • 429.690625 MHz
  • 429.696875 MHz
  • 429.703125 MHz
  • 429.709375 MHz
  • 429.715625 MHz
  • 429.721875 MHz
  • 429.728125 MHz
  • 429.734375 MHz
  • 429.815625 MHz
  • 429.821875 MHz
  • 429.828125 MHz
  • 429.834375 MHz
  • 429.840625 MHz
  • 429.846875 MHz
  • 429.853125 MHz
  • 429.859375 MHz
  • 429.865625 MHz
  • 429.871875 MHz
  • 429.878125 MHz
  • 429.884375 MHz
  • 429.890625 MHz
  • 429.896875 MHz
  • 429.903125 MHz
  • 429.909375 MHz
  • 429.915625 MHz
  • 429.921875 MHz
  • 449.715625 MHz
  • 449.721875 MHz
  • 449.734375 MHz
  • 449.740625 MHz
  • 449.746875 MHz
  • 449.753125 MHz
  • 449.759375 MHz
  • 449.765625 MHz
  • 449.771875 MHz
  • 449.778125 MHz
  • 449.784375 MHz
  • 449.790625 MHz
  • 449.796875 MHz
  • 449.803125 MHz
  • 449.809375 MHz
  • 449.815625 MHz
  • 449.821875 MHz
  • 426.0250 MHz
  • 426.0375 MHz
  • 426.0500 MHz
  • 426.0625 MHz
  • 426.0750 MHz
  • 426.0875 MHz
  • 426.1000 MHz
  • 426.1125 MHz
  • 426.1250 MHz
  • 426.1375 MHz
  • 429.1750 MHz
  • 429.1875 MHz
  • 429.2000 MHz
  • 429.2125 MHz
  • 429.2250 MHz
  • 429.2375 MHz
  • 429.2500 MHz
  • 429.2625 MHz
  • 429.2750 MHz
  • 429.2875 MHz
  • 429.3000 MHz
  • 429.3125 MHz
  • 429.3250 MHz
  • 429.3375 MHz
  • 429.3500 MHz
  • 429.3625 MHz
  • 429.3750 MHz
  • 429.3875 MHz
  • 429.4000 MHz
  • 429.4125 MHz
  • 429.4250 MHz
  • 429.4375 MHz
  • 429.4500 MHz
  • 429.4625 MHz
  • 429.4750 MHz
  • 429.4875 MHz
  • 429.5000 MHz
  • 429.5125 MHz
  • 429.5250 MHz
  • 429.5375 MHz
  • 429.5500 MHz
  • 429.5625 MHz
  • 429.5750 MHz
  • 429.5875 MHz
  • 429.6000 MHz
  • 429.6125 MHz
  • 429.6250 MHz
  • 429.6375 MHz
  • 429.6500 MHz
  • 429.6625 MHz
  • 429.6750 MHz
  • 429.6875 MHz
  • 429.7000 MHz
  • 429.7125 MHz
  • 429.7250 MHz
  • 429.7375 MHz
  • 429.8125 MHz
  • 429.9250 MHz
  • 449.7125 MHz
  • 449.7250 MHz
  • 449.7375 MHz
  • 449.7500 MHz
  • 449.7625 MHz
  • 449.7750 MHz
  • 449.7875 MHz
  • 449.8000 MHz
  • 449.8125 MHz
  • 449.8250 MHz
  • 449.8375 MHz
  • 449.8500 MHz
  • 449.8625 MHz
  • 449.8750 MHz
  • 449.8875 MHz
  • 449.8000 MHz
  • 449.8125 MHz
  • 449.8250 MHz
  • 449.8375 MHz
  • 449.8500 MHz
  • 449.8625 MHz
  • 449.8750 MHz
  • 449.8875 MHz
  • 469.7375 MHz
  • 469.7500 MHz
  • 469.7625 MHz
  • 469.7750 MHz
  • 469.7875 MHz
  • 469.8000 MHz
  • 469.8125 MHz
  • 469.8250 MHz
  • 469.8375 MHz
  • 469.8500 MHz
  • 469.8625 MHz
  • 469.8750 MHz
  • 469.8875 MHz
  • 26.975 MHz - 26975 kHz - shared with CB radio channel 2
  • 27.025 MHz - 27025 kHz - shared with CB radio channel 6
  • 27.075 MHz - 27075 kHz - shared with CB radio channel 10
  • 27.125 MHz - 27125 kHz - shared with CB radio channel 14
  • 27.175 MHz - 27175 kHz - shared with CB radio channel 18
  • 27.225 MHz - 27225 kHz - shared with CB radio channel 22
  • 27.255 MHz - 27255 kHz - shared with CB radio channel 23, pagers, etc.
  • 40.610 MHz
  • 40.630 MHz
  • 40.650 MHz
  • 40.670 MHz
  • 40.690 MHz
  • 40.710 MHz
  • 40.730 MHz
  • 40.750 MHz
  • 40.770 MHz
  • 40.790 MHz
  • 40.810 MHz
  • 40.830 MHz
  • 40.850 MHz
  • 72.130 MHz
  • 72.150 MHz
  • 72.170 MHz
  • 72.190 MHz
  • 72.210 MHz
  • 72.790 MHz
  • 72.810 MHz
  • 72.830 MHz
  • 72.850 MHz
  • 72.870 MHz
  • 223.100 MHz
  • 223.700 MHz
  • 223.975 MHz
  • 224.600 MHz
  • 225.025 MHz
  • 225.325 MHz
  • 230.100 MHz
  • 230.700 MHz
  • 230.975 MHz
  • 231.600 MHz
  • 232.025 MHz
  • 232.325 MHz
  • 418.950 MHz
  • 418.975 MHz
  • 419.000 MHz
  • 419.025 MHz
  • 419.050 MHz
  • 419.075 MHz
  • 419.100 MHz
  • 419.125 MHz
  • 419.150 MHz
  • 419.175 MHz
  • 419.200 MHz
  • 419.225 MHz
  • 419.250 MHz
  • 419.275 MHz
Malaysia
  • 40 MHz band - 50mW EIRP
  • 47 MHz band - 50mW EIRP
  • 49 MHz band - 50mW EIRP
Korea
  • 16K0A1D
  • 16K0A2D
  • 16K0F1D
  • 16K0F2D
  • 16K0G1D
  • 16K0G2D
  • 219.150 MHz
  • 219.175 MHz
  • 219.200 MHz
  • 219.225 MHz
  • 447.6000 MHz
  • 447.6125 MHz
  • 447.6250 MHz
  • 447.6375 MHz
  • 447.6500 MHz
  • 447.6625 MHz
  • 447.6750 MHz
  • 447.6875 MHz
  • 447.7000 MHz
  • 447.7125 MHz
  • 447.7250 MHz
  • 447.7375 MHz
  • 447.7500 MHz
  • 447.7625 MHz
  • 447.7750 MHz
  • 447.7875 MHz
  • 447.8000 MHz
  • 447.8125 MHz
  • 447.8250 MHz
  • 447.8375 MHz
  • 447.8500 MHz
  • 447.8625 MHz
  • 447.8750 MHz
  • 447.8875 MHz
  • 447.9000 MHz
  • 447.9125 MHz
  • 447.9250 MHz
  • 447.9375 MHz
  • 447.9500 MHz
  • 447.9625 MHz
  • 447.9750 MHz
  • 447.9875 MHz
India
"New" channel plan:
Old (???) channel plan:
This section needs additional clarification and information - TRAI - Telecom Regulatory Agency of India regulations???
  • 27.004 MHz - Aeromodelling
  • 27.116 MHz - Aeromodelling
  • 27.148 MHz - Aeromodelling
  • 27.156 MHz - Aeromodelling
  • 27.228 MHz - Aeromodelling
  • SCADA
  • 849.0125 MHz / 933.0125 MHz
  • 849.0025 MHz / 933.0250 MHz
  • 849.0375 MHz / 933.0375 MHz
  • 849.0500 MHz / 933.0500 MHz
  • 849.0625 MHz / 933.0625 MHz
  • 849.0750 MHz / 933.0750 MHz
  • 849.0875 MHz / 933.0875 MHz
  • 849.1125 MHz / 933.1125 MHz
  • 849.1250 MHz / 933.1250 MHz
  • 5.8 GHz Band
Several bands available.
  • 27 MHz band - 27MHz AM
  • 29 MHz band - 29MHz FM
  • 35 MHz band - 35MHz FM
  • 36 MHz band - 36MHz FM
  • 40 MHz band - 40MHz FM
  • 72 MHz band - 72MHz FM
  • 2.4 GHz band
  • Channel 22 - 476.9500 MHz
  • Channel 23 - 476.9750 MHz
  • Channel 61 - 476.9375 MHz
  • Channel 62 - 476.9625 MHz
  • Channel 63 - 476.9875 MHz
  • 35.000 MHz - RC Channel 500
  • 35.010 MHz - RC Channel 501
  • 35.020 MHz - RC Channel 502
  • 35.030 MHz - RC Channel 503
  • 35.040 MHz - RC Channel 504
  • 35.050 MHz - RC Channel 505
  • 35.060 MHz - RC Channel 506
  • 35.070 MHz - RC Channel 507
  • 35.080 MHz - RC Channel 508
  • 35.090 MHz - RC Channel 509
  • 35.100 MHz - RC Channel 510
  • 35.110 MHz - RC Channel 511
  • 35.120 MHz - RC Channel 512
  • 35.130 MHz - RC Channel 513
  • 35.140 MHz - RC Channel 514
  • 35.150 MHz - RC Channel 515
  • 35.160 MHz - RC Channel 516
  • 35.170 MHz - RC Channel 517
  • 35.180 MHz - RC Channel 518
  • 35.190 MHz - RC Channel 519
  • 35.200 MHz - RC Channel 520
  • 35.210 MHz - RC Channel 521
  • 35.220 MHz - RC Channel 522
  • 35.230 MHz - RC Channel 523
  • 35.240 MHz - RC Channel 524
  • 35.250 MHz - RC Channel 525
  • 35.260 MHz - RC Channel 526
  • 35.270 MHz - RC Channel 527
  • 35.280 MHz - RC Channel 528
  • 35.290 MHz - RC Channel 529
  • 35.300 MHz - RC Channel 530
  • 36.250 MHz - RC Channel 625
  • 36.260 MHz - RC Channel 626
  • 36.270 MHz - RC Channel 627
  • 36.280 MHz - RC Channel 628
  • 36.290 MHz - RC Channel 629
  • 36.300 MHz - RC Channel 630
  • 36.310 MHz - RC Channel 631
  • 36.320 MHz - RC Channel 632
  • 36.330 MHz - RC Channel 633
  • 36.340 MHz - RC Channel 634
  • 36.350 MHz - RC Channel 635
  • 36.360 MHz - RC Channel 636
  • 36.370 MHz - RC Channel 637
  • 36.380 MHz - RC Channel 638
  • 36.390 MHz - RC Channel 639
  • 36.400 MHz - RC Channel 640
  • 36.410 MHz - RC Channel 641
  • 36.420 MHz - RC Channel 642
  • 36.430 MHz - RC Channel 643
  • 36.440 MHz - RC Channel 644
  • 36.450 MHz - RC Channel 645
  • 36.460 MHz - RC Channel 646
  • 36.470 MHz - RC Channel 647
  • 36.480 MHz - RC Channel 648
  • 36.490 MHz - RC Channel 649
  • 36.500 MHz - RC Channel 650
  • 36.510 MHz - RC Channel 651
  • 36.520 MHz - RC Channel 652
  • 36.530 MHz - RC Channel 653
  • 36.540 MHz - RC Channel 654
  • 36.550 MHz - RC Channel 655
  • 36.560 MHz - RC Channel 656
  • 36.570 MHz - RC Channel 657
  • 36.580 MHz - RC Channel 658
  • 36.590 MHz - RC Channel 659
  • 72.010 MHz - RC Channel 701
  • 72.030 MHz - RC Channel 703
  • 72.050 MHz - RC Channel 705
  • 72.070 MHz - RC Channel 707
  • 72.090 MHz - RC Channel 709
  • 72.110 MHz - RC Channel 711
  • 72.130 MHz - RC Channel 713
  • 72.150 MHz - RC Channel 715
  • 72.170 MHz - RC Channel 717
  • 72.190 MHz - RC Channel 719
  • 72.210 MHz - RC Channel 721
  • 72.230 MHz - RC Channel 723
  • 72.250 MHz - RC Channel 725
  • 72.270 MHz - RC Channel 727
  • 72.290 MHz - RC Channel 729
  • 72.310 MHz - RC Channel 731
  • 72.330 MHz - RC Channel 733
  • 72.350 MHz - RC Channel 735
  • 72.370 MHz - RC Channel 737
  • 72.390 MHz - RC Channel 739
  • 72.410 MHz - RC Channel 741
  • 72.430 MHz - RC Channel 743
  • 72.450 MHz - RC Channel 745
  • 72.470 MHz - RC Channel 747
  • 72.490 MHz - RC Channel 749
  • 72.510 MHz - RC Channel 751
  • 72.530 MHz - RC Channel 753
  • 72.550 MHz - RC Channel 755
  • 72.570 MHz - RC Channel 757
  • 72.590 MHz - RC Channel 759
  • 72.610 MHz - RC Channel 761
  • 72.630 MHz - RC Channel 763
  • 72.650 MHz - RC Channel 765
  • 72.670 MHz - RC Channel 767
  • 72.690 MHz - RC Channel 769
  • 72.710 MHz - RC Channel 771
  • 72.730 MHz - RC Channel 773
  • 72.750 MHz - RC Channel 775
  • 72.770 MHz - RC Channel 777
  • 72.790 MHz - RC Channel 779
27 MHz band, 29 MHz band, 36 MHz band, 40 MHz band, 2.4 GHz band. There appears to be at least some use of American spec 72 MHz and 75 MHz equipment as well as 900 MHz band equipment in Australia.
The 476 MHz / 477 MHz UHF CB allocation also includes 5 channel frequencies designated specifically for data, telemetry and telecommand (RC) specifically:
  • UHF CB Channel 22 - 476.950 MHz
  • UHF CB Channel 23 - 476.975 MHz
  • UHF CB Channel 61 - 476.9375 MHz
  • UHF CB Channel 62 - 476.9625 MHz
  • UHF CB Channel 63 - 476.9875 MHz
  • 36.010 MHz - RC Channel 601
  • 36.020 MHz - RC Channel 602
  • 36.030 MHz - RC Channel 603
  • 36.040 MHz - RC Channel 604
  • 36.050 MHz - RC Channel 605
  • 36.060 MHz - RC Channel 606
  • 36.070 MHz - RC Channel 607
  • 36.080 MHz - RC Channel 608
  • 36.090 MHz - RC Channel 609
  • 36.100 MHz - RC Channel 610
  • 36.110 MHz - RC Channel 611
  • 36.120 MHz - RC Channel 612
  • 36.130 MHz - RC Channel 613
  • 36.140 MHz - RC Channel 614
  • 36.150 MHz - RC Channel 615
  • 36.160 MHz - RC Channel 616
  • 36.170 MHz - RC Channel 617
  • 36.180 MHz - RC Channel 618
  • 36.190 MHz - RC Channel 619
  • 36.200 MHz - RC Channel 620
  • 36.210 MHz - RC Channel 621
  • 36.220 MHz - RC Channel 622
  • 36.230 MHz - RC Channel 623
  • 36.240 MHz - RC Channel 624
There appears to be some use of out of band 40MHz equipment, generally in the 40.7 MHz to 40.9 MHz range.
  • 40.665 MHz - RC Channel 50
  • 40.675 MHz - RC Channel 51
  • 40.685 MHz - RC Channel 52
  • 40.695 MHz - RC Channel 53
Swaziland / Eswatini
  • 35.000 MHz
  • 35.010 MHz
  • 35.020 MHz
  • 35.030 MHz
  • 35.040 MHz
  • 35.050 MHz
  • 35.060 MHz
  • 35.070 MHz
  • 35.080 MHz
  • 35.090 MHz
  • 35.100 MHz
  • 35.110 MHz
  • 35.120 MHz
  • 35.130 MHz
  • 35.140 MHz
  • 35.150 MHz
  • 35.160 MHz
  • 35.170 MHz
  • 35.180 MHz
  • 35.190 MHz
  • 35.200 MHz
  • 35.210 MHz
  • 35.220 MHz
  • 40.665 MHz - 100mW power limit, 40.660 MHz - 40.670 MHz
  • 40.675 MHz - 100mW power limit, 40.670 MHz - 40.680 MHz
  • 40.685 MHz - 100mW power limit, 40.680 MHz - 40.690 MHz
  • 54 MHz band, model control.
  • 54.4500 MHz
  • 54.4625 MHz
  • 54.4750 MHz
  • 54.4875 MHz
  • 54.5000 MHz
  • 54.5125 MHz
  • 54.5250 MHz
  • 54.5375 MHz
  • 54.5500 MHz
European regulations
  • 2.4 GHz band
South Africa
Color code + channel number “spot” for frequency and band identification.
  • 26.995 MHz - Brown 04
  • 27.045 MHz - Brown 09
  • 27.095 MHz - Brown 14
  • 27.145 MHz - Brown 19
  • 27.195 MHz - Brown 24
  • 35.000 MHz - Orange 60
  • 35.010 MHz - Orange 61
  • 35.020 MHz - Orange 62
  • 35.030 MHz - Orange 63
  • 35.040 MHz - Orange 64
  • 35.050 MHz - Orange 65
  • 35.060 MHz - Orange 66
  • 35.070 MHz - Orange 67
  • 35.080 MHz - Orange 68
  • 35.090 MHz - Orange 69
  • 35.100 MHz - Orange 70
  • 35.110 MHz - Orange 71
  • 35.120 MHz - Orange 72
  • 35.130 MHz - Orange 73
  • 35.140 MHz - Orange 74
  • 35.150 MHz - Orange 75
  • 35.160 MHz - Orange 76
  • 35.170 MHz - Orange 77
  • 35.180 MHz - Orange 78
  • 35.190 MHz - Orange 79
  • 35.200 MHz - Orange 80
  • 35.210 MHz - Orange 81
  • 35.220 MHz - Orange 82
  • 35.230 MHz - Orange 83
  • 35.240 MHz - Orange 84
  • 35.250 MHz - Orange 85
  • 35.260 MHz - Orange 86
  • 35.270 MHz - Orange 87
  • 35.280 MHz - Orange 88
  • 35.290 MHz - Orange 89
  • 35.300 MHz - Orange 90
  • 53.300 MHz - Red 31
  • 53.350 MHz - Red 32
  • 53.400 MHz - Red 33
  • 53.450 MHz - Red 34
  • 53.500 MHz - Red 35
  • 53.550 MHz - Red 36
  • 53.600 MHz - Red 37
  • 53.650 MHz - Red 38
  • 53.700 MHz - Red 39
  • 53.750 MHz - Red 40
  • 53.800 MHz - Red 41
  • 53.850 MHz - Red 42
  • 53.900 MHz - Red 43
  • 54.450 MHz - Yellow 46
  • 54.500 MHz - Yellow 47
  • 54.550 MHz - Yellow 48
Argentina
50 MHz / 53 MHz band
6 meter ham radio band. Licensed ham radio operators only.
  • 50.800 MHz
  • 50.820 MHz
  • 50.840 MHz
  • 50.860 MHz
  • 50.880 MHz
  • 50.900 MHz
  • 50.920 MHz
  • 50.940 MHz
  • 50.960 MHz
  • 50.980 MHz
  • 53.100 MHz
  • 53.200 MHz
  • 53.300 MHz
  • 53.400 MHz
  • 53.500 MHz
  • 53.600 MHz
  • 53.700 MHz
  • 53.800 MHz
72 MHz band
72 MHz band is assigned exclusively for aeromodelling use - that is, only model aircraft control 72MHz band. Identical to the U.S. FCC allocation, same as the American 72 MHz R/C allocation.
  • 72.010 MHz - Channel 11
  • 72.030 MHz - Channel 12
  • 72.050 MHz - Channel 13
  • 72.070 MHz - Channel 14
  • 72.090 MHz - Channel 15
  • 72.110 MHz - Channel 16
  • 72.130 MHz - Channel 17
  • 72.150 MHz - Channel 18
  • 72.170 MHz - Channel 19
  • 72.190 MHz - Channel 20
  • 72.210 MHz - Channel 21
  • 72.230 MHz - Channel 22
  • 72.250 MHz - Channel 23
  • 72.270 MHz - Channel 24
  • 72.290 MHz - Channel 25
  • 72.310 MHz - Channel 26
  • 72.330 MHz - Channel 27
  • 72.350 MHz - Channel 28
  • 72.370 MHz - Channel 29
  • 72.390 MHz - Channel 30
  • 72.410 MHz - Channel 31
  • 72.430 MHz - Channel 32
  • 72.450 MHz - Channel 33
  • 72.470 MHz - Channel 34
  • 72.490 MHz - Channel 35
  • 72.510 MHz - Channel 36
  • 72.530 MHz - Channel 37
  • 72.550 MHz - Channel 38
  • 72.570 MHz - Channel 39
  • 72.590 MHz - Channel 40
  • 72.610 MHz - Channel 41
  • 72.630 MHz - Channel 42
  • 72.650 MHz - Channel 43
  • 72.670 MHz - Channel 44
  • 72.690 MHz - Channel 45
  • 72.710 MHz - Channel 46
  • 72.730 MHz - Channel 47
  • 72.750 MHz - Channel 48
  • 72.770 MHz - Channel 49
  • 72.790 MHz - Channel 50
  • 72.810 MHz - Channel 51
  • 72.830 MHz - Channel 52
  • 72.850 MHz - Channel 53
  • 72.870 MHz - Channel 54
  • 72.890 MHz - Channel 55
  • 72.910 MHz - Channel 56
  • 72.930 MHz - Channel 57
  • 72.950 MHz - Channel 58
  • 72.970 MHz - Channel 59
  • 72.990 MHz - Channel 60
