Factory default frequencies
Revision as of 20:00, 12 September 2026 by R4002 (Talk | contribs)
This has been split into its own page due to the length of the Business Radio page. VHF/UHF radio services master list here.
Background Information
Higher-end VHF and UHF handheld radios are simply sold by the band they operate on, and the end user (or vendor) programs the radio accordingly. This is changing by the early 2020s and the flooding of the market with inexpensive Chinese radios that often come with factory default frequencies out of the box. Some of these radios have received FCC approval for Part 95 (FRS, GMRS or MURS) usage, while others have Part 90 land mobile authorization (with the programming software of course). See also: commonly used, popular and out of the box factory default FRS and GMRS frequencies channels codes tones and of course the official itinerant business radio service frequencies, low power UHF business radio frequencies and de facto itinerant low band VHF, VHF and UHF frequencies lists.
Users often buy radios and use them on whichever frequencies they came programmed with from the factory, regardless of which band and/or frequencies the radios happen to be programmed with from the
Motorola On Site Business Band Radios Factory Default Channels Frequencies
  • Channel 1 - 464.5500 MHz 67.0 Hz PL [Freq 2, Code 1]
  • Channel 2 - 467.9250 MHz 67.0 Hz PL [Freq 8, Code 1]
  • Channel 3 - 467.8500 MHz 67.0 Hz PL [Freq 5, Code 1]
  • Channel 4 - 467.8750 MHz 67.0 Hz PL [Freq 6, Code 1]
  • Channel 5 - 461.0625 MHz 67.0 Hz PL [Freq 10, Code 1]
  • Channel 6 - 461.1125 MHz 67.0 Hz PL [Freq 12, Code 1]
  • Channel 1 - 154.5700 MHz 67.0 Hz PL [Freq 2, Code 1]
  • Channel 2 - 154.6000 MHz 67.0 Hz PL [Freq 1, Code 1]
  • Channel 3 - 151.8200 MHz 67.0 Hz PL [Freq 3, Code 1]
  • Channel 4 - 151.8800 MHz 67.0 Hz PL [Freq 4, Code 1]
  • Channel 5 - 151.9400 MHz 67.0 Hz PL [Freq 5, Code 1]
  • Channel 6 - 154.5700 MHz CSQ [Freq 2, Code 0]
  • Channel 7 - 154.6000 MHz CSQ [Freq 1, Code 0]
  • Channel 8 - 151.8200 MHz CSQ [Freq 3, Code 0]
  • Channel 12 - 464.4875 MHz 79.7 Hz PL [Frequency 30, Code 5]
  • Channel 13 - 464.5375 MHz 85.4 Hz PL [Frequency 32, Code 7]
  • Channel 14 - 466.0375 MHz 91.5 Hz PL [Frequency 34, Code 9]
  • Channel 15 - 466.0875 MHz 97.4 Hz PL [Frequency 36, Code 11]
Midland On Site Business Band Radios Factory Default Channels Frequencies
Midland BR180 BIZTALK 4 Channel UHF Business Radio
Default Channels Frequencies Midland BR-180
  • Channel 1 - 464.5500 MHz 67.0 Hz PL - Frequency 55
  • Channel 2 - 467.9250 MHz 67.0 Hz PL - Frequency 85
  • Channel 3 - 467.8500 MHz 67.0 Hz PL - Frequency 79
  • Channel 4 - 467.8750 MHz 67.0 Hz PL - Frequency 81
Note: The BR180 uses a non-standard frequency pool of 99 UHF business band frequencies to choose from. Note that the most commonly used frequencies are not listed first on the available business exclusive frequencies to choose from.
  • Freq 01 - 451.1875
  • Freq 02 - 451.2375
  • Freq 03 - 451.2875
  • Freq 04 - 451.3375
  • Freq 05 - 451.4375
  • Freq 06 - 451.5375
  • Freq 07 - 451.6375
  • Freq 08 - 452.3125
  • Freq 09 - 452.4125
  • Freq 10 - 452.5125
  • Freq 11 - 452.5375
  • Freq 12 - 452.7625
  • Freq 13 - 452.8625
  • Freq 14 - 456.1875
  • Freq 15 - 456.2375
  • Freq 16 - 456.2875
  • Freq 17 - 456.3375
  • Freq 18 - 456.4375
  • Freq 19 - 456.5375
  • Freq 20 - 456.6375
  • Freq 21 - 457.3125
  • Freq 22 - 457.4125
  • Freq 23 - 457.5125
  • Freq 24 - 457.7625
  • Freq 25 - 457.8625
  • Freq 26 - 461.0375
  • Freq 27 - 461.0625
  • Freq 28 - 461.0875
  • Freq 29 - 461.1125
  • Freq 30 - 461.1375
  • Freq 31 - 461.1625
  • Freq 32 - 461.1875
  • Freq 33 - 461.2125
  • Freq 34 - 461.2375
  • Freq 35 - 461.2625
  • Freq 36 - 461.2875
  • Freq 37 - 461.3125
  • Freq 38 - 461.3375
  • Freq 39 - 461.3625
  • Freq 40 - 462.1875
  • Freq 41 - 462.4625
  • Freq 42 - 462.4875
  • Freq 43 - 462.5125
  • Freq 50 - 462.9125
  • Freq 51 - 464.4875
  • Freq 52 - 464.5000
  • Freq 53 - 464.5125
  • Freq 54 - 464.5375
  • Freq 55 - 464.5500
  • Freq 56 - 464.5625
  • Freq 57 - 466.0375
  • Freq 58 - 466.0625
  • Freq 59 - 466.0875
  • Freq 60 - 466.1125
  • Freq 61 - 466.1375
  • Freq 62 - 466.1625
  • Freq 63 - 466.1875
  • Freq 64 - 466.2125
  • Freq 65 - 466.2375
  • Freq 66 - 466.2625
  • Freq 67 - 466.2875
  • Freq 68 - 466.3125
  • Freq 69 - 466.3375
  • Freq 70 - 466.3625
  • Freq 71 - 467.1875
  • Freq 72 - 467.4625
  • Freq 73 - 467.4875
  • Freq 74 - 467.5125
  • Freq 75 - 467.7625
  • Freq 76 - 467.7875
  • Freq 77 - 467.8125
  • Freq 78 - 467.8375
  • Freq 79 - 467.8500
  • Freq 80 - 467.8625
  • Freq 81 - 467.8750
  • Freq 82 - 467.8875
  • Freq 83 - 467.9000
  • Freq 84 - 467.9125
  • Freq 85 - 467.9250
  • Freq 86 - 468.2125
  • Freq 87 - 468.2625
  • Freq 88 - 468.3125
  • Freq 89 - 468.3625
  • Freq 90 - 468.4125
  • Freq 91 - 468.4625
  • Freq 92 - 468.5125
  • Freq 93 - 468.5625
  • Freq 94 - 468.6125
  • Freq 95 - 468.6625
  • Freq 96 - 469.4875
  • Freq 97 - 469.5125
  • Freq 98 - 469.5375
  • Freq 99 - 469.5625
Privacy codes (CTCSS, DCS, etc,) list. “Code 0” is carrier squelch / CSQ. Tones 1-38 are the standard CTCSS (PL) tones, 39 to 121 are the standard DCS code.
  • Code 00 - CSQ No Tone
  • Code 01 - 67.0 Hz
  • Code 38 - 250.3 Hz
  • Code 39 - 023 DCS
  • Code 121 - 754 DCS
  • Code 122 - 036 DCS
  • Code 123 - 053 DCS
  • Code 124 - 122 DCS
  • Code 125 - 145 DCS
  • Code 126 - 212 DCS
  • Code 127 - 225 DCS
  • Code 128 - 246 DCS
  • Code 129 - 252 DCS
  • Code 140 - 462 DCS
  • Code 141 - 523 DCS
  • Code 142 - 526 DCS
  • Channel 16 - 467.8750 MHz CSQ
Midland MB400 16 Channel UHF Business Radio
Identical to the BR200
Icom MURS and On Site Business Band Radios Factory Default Channels Frequencies
  • Channels 6 - 16 UNPROGRAMMED (by default, may be programmed by end user or dealer)
Icom PMR446 / dPMR446 Factory Default Channels Frequencies
  • Channel 1 - 446.00625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.01875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.03125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.04375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.05625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.06875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.08125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.09375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.00625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.01875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.03125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.04375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.05625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.06875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.08125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.09375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.10625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.11875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.13125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.14375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.15625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.16875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.18125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.19375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.10625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.11875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.13125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.14375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.15625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.16875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.18125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.19375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.003125 MHz Digital - Common ID 85
  • Channel 2 - 446.009375 MHz Digital - Common ID 87
  • Channel 3 - 446.015625 MHz Digital - Common ID 93
  • Channel 4 - 446.021875 MHz Digital - Common ID 95
  • Channel 5 - 446.028125 MHz Digital - Common ID 117
  • Channel 6 - 446.034375 MHz Digital - Common ID 119
  • Channel 7 - 446.040625 MHz Digital - Common ID 125
  • Channel 8 - 446.046875 MHz Digital - Common ID 129
  • Channel 9 - 446.053125 MHz Digital - Common ID 213
  • Channel 10 - 446.059375 MHz Digital - Common ID 215
  • Channel 11 - 446.065625 MHz Digital - Common ID 221
  • Channel 12 - 446.071875 MHz Digital - Common ID 223
  • Channel 13 - 446.078125 MHz Digital - Common ID 245
  • Channel 14 - 446.084375 MHz Digital - Common ID 247
  • Channel 15 - 446.090625 MHz Digital - Common ID 253
  • Channel 16 - 446.096875 MHz Digital - Common ID 254
  • Channel 1 - 446.103125 MHz Digital - Common ID 85
  • Channel 2 - 446.109375 MHz Digital - Common ID 87
  • Channel 3 - 446.115625 MHz Digital - Common ID 93
  • Channel 4 - 446.121875 MHz Digital - Common ID 95
  • Channel 5 - 446.128125 MHz Digital - Common ID 117
  • Channel 6 - 446.134375 MHz Digital - Common ID 119
  • Channel 7 - 446.140625 MHz Digital - Common ID 125
  • Channel 8 - 446.146875 MHz Digital - Common ID 129
  • Channel 9 - 446.153125 MHz Digital - Common ID 213
  • Channel 10 - 446.159375 MHz Digital - Common ID 215
  • Channel 11 - 446.165625 MHz Digital - Common ID 221
  • Channel 12 - 446.171875 MHz Digital - Common ID 223
  • Channel 13 - 446.178125 MHz Digital - Common ID 245
  • Channel 14 - 446.184375 MHz Digital - Common ID 247
  • Channel 15 - 446.190625 MHz Digital - Common ID 253
  • Channel 16 - 446.196875 MHz Digital - Common ID 254
Kenwood On Site Business Band Radios Factory Default Channels Frequencies
Kenwood ProTalk PKT-300 UHF Business Radio Replacement for the TK-3200 series. 2 watt business walkie talkie. 99 available frequencies to choose from.
  • Channel 1 - 464.5500 MHz 67.0 Hz Tone
  • Channel 2 - 467.9250 MHz 67.0 Hz Tone
  • Channel 3 - 467.8500 MHz 67.0 Hz Tone
  • Channel 4 - 467.8750 MHz 67.0 Hz Tone
  • Channel 5 - 461.0375 MHz 67.0 Hz Tone
  • Channel 6 - 461.0625 MHz 67.0 Hz Tone
  • Freq 01 - 464.5000 MHz
  • Freq 02 - 464.5500 MHz
  • Freq 03 - 467.7625 MHz
  • Freq 04 - 467.8125 MHz
  • Freq 05 - 467.8500 MHz
  • Freq 06 - 467.8750 MHz
  • Freq 07 - 467.9000 MHz
  • Freq 08 - 467.9250 MHz
  • Freq 09 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 91 - 456.3375 MHz
  • Freq 92 - 456.4375 MHz
  • Freq 93 - 456.5375 MHz
  • Freq 94 - 456.6375 MHz
  • Freq 95 - 457.3125 MHz
  • Freq 96 - 457.4125 MHz
  • Freq 97 - 457.5125 MHz
  • Freq 98 - 457.7625 MHz
  • Freq 99 - 457.8625 MHz
  • Channel 1 - 464.5500 MHz 67.0 Hz PL [Freq 2, QT Tone 1]
  • Channel 2 - 467.9250 MHz 67.0 Hz PL [Freq 8, QT Tone 1]
  • Channel 3 - 461.0375 MHz 67.0 Hz PL [Freq 9, QT Tone 1]
  • Channel 4 - 461.0625 MHz 67.0 Hz PL [Freq 10, QT Tone 1]
  • Channel 5 - 461.0875 MHz 67.0 Hz PL [Freq 11, QT Tone 1]
  • Channel 6 - 461.1125 MHz 67.0 Hz PL [Freq 12, QT Tone 1]
  • Channel 7 - 461.1375 MHz 67.0 Hz PL [Freq 13, QT Tone 1]
  • Channel 8 - 461.1625 MHz 67.0 Hz PL [Freq 14, QT Tone 1]
  • Channel 9 - 464.5000 MHz 67.0 Hz PL [Freq 1, QT Tone 1]
  • Channel 10 - 467.7625 MHz 67.0 Hz PL [Freq 3, QT Tone 1]
  • Channel 11 - 467.8125 MHz 67.0 Hz PL [Freq 4, QT Tone 1]
  • Channel 12 - 467.8500 MHz 67.0 Hz PL [Freq 5, QT Tone 1]
  • Channel 13 - 467.8750 MHz 67.0 Hz PL [Freq 6, QT Tone 1]
  • Channel 14 - 467.9000 MHz 67.0 Hz PL [Freq 7, QT Tone 1]
  • Channel 15 - 461.1875 MHz 67.0 Hz PL [Freq 15, QT Tone 1]
Misc On Site Business Band Radios Factory Default Channels Frequencies
Wouxun KG-S86B Business Radio
CONNECOM GD100 and GD900
CONNECOM GD800
Default channel programming
  • Channel 9 - 464.5500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 10 - 464.5000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 11 - 467.7625 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 12 - 467.8125 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 13 - 467.8500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 14 - 467.8750 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 15 - 467.9000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 16 - 467.9250 MHz NFM - 67.0 Hz CTCSS TX/RX
Ritron JOBCOM JMX D Series VHF radios
  • JMX-111D Jobcom 1 watt 1 channel
  • JMX-141D Jobcom 1.5 watt 10 channel
  • JMX-146D Jobcom 2 watt 10 channel
  • JMX-144D Jobcom 4 watt 10 channel
  • Code 00 - CHANNEL DELETE
  • Code 01 - 154.6000 MHz - MURS 4 Green Dot (25 kHz bandwidth)
  • Code 02 - 154.5700 MHz - MURS 5 Blue Dot (25 kHz bandwidth)
  • Code 03 - 151.6250 MHz - Red Dot
  • Code 04 - 151.9550 MHz - Purple Dot
  • Code 05 - 151.9250 MHz
  • Code 06 - 154.5400 MHz
  • Code 07 - 154.5150 MHz
  • Code 08 - 154.5475 MHz
  • Code 09 - 151.6850 MHz
  • Code 10 - 151.7150 MHz
  • Code 11 - 151.7750 MHz
  • Code 12 - 151.8050 MHz
  • Code 13 - 151.8350 MHz
  • Code 14 - 151.8950 MHz
  • Code 15 - 154.4900 MHz
  • Code 16 - 151.6550 MHz
  • Code 17 - 151.7450 MHz
  • Code 18 - 151.8650 MHz
  • Code 19 - 151.8200 MHz - MURS 1
  • Code 20 - 151.8800 MHz - MURS 2
  • Code 21 - 151.9400 MHz - MURS 3
  • Code 22 - 154.6000 MHz - MURS 4 Green Dot (12.5 kHz bandwidth)
  • Code 23 - 154.5700 MHz - MURS 5 Blue Dot (12.5 kHz bandwidth)
  • Code 24 - 151.7000 MHz
  • Code 25 - 151.7600 MHz
  • Code 26 - 152.9000 MHz
Ritron JOBCOM JMX D Series UHF radios
Note: "the code" is the two-digit frequency reference used when the radio is programmed. It is the same as "frequency" or "frequency code".
  • JMX-441D Jobcom 1 watt 10 channel
  • JMX-446D Jobcom 2 watt 10 channel
  • JMX-444D Jobcom 3 watt 10 channel
  • Code 01 - 467.7625 MHz
  • Code 02 - 467.8125 MHz
  • Code 03 - 464.5500 MHz
  • Code 04 - 464.5000 MHz
  • Code 05 - 467.8500 MHz
  • Code 06 - 467.8750 MHz
  • Code 07 - 467.9000 MHz
  • Code 08 - 467.9250 MHz
  • Code 09 - 469.2625 MHz
  • Code 10 - 462.5750 MHz - FRS Channel 16 / White Dot
  • Code 11 - 462.6250 MHz - FRS Channel 18 / Black Dot
  • Code 12 - 462.6750 MHz - FRS Channel 20 / Orange Dot
  • Code 13 - 464.3250 MHz
  • Code 14 - 464.8250 MHz
  • Code 15 - 469.5000 MHz
  • Code 16 - 469.5500 MHz
  • Code 17 - 464.2625 MHz
  • Code 18 - 464.9125 MHz
  • Code 19 - 462.6000 MHz - FRS Channel 17
  • Code 20 - 462.7000 MHz - FRS Channel 21
  • Code 21 - 462.7250 MHz - FRS Channel 22
  • Code 22 - 464.5000 MHz
  • Code 23 - 464.5500 MHz
  • Code 24 - 467.7625 MHz
  • Code 25 - 467.8125 MHz
  • Code 26 - 467.8500 MHz
  • Code 27 - 467.8750 MHz
  • Code 28 - 467.9000 MHz
  • Code 29 - 467.9250 MHz
  • Code 30 - 461.0375 MHz
  • Code 31 - 461.0625 MHz
  • Code 32 - 461.0875 MHz
  • Code 33 - 461.1125 MHz
  • Code 34 - 461.1375 MHz
  • Code 35 - 461.1625 MHz
  • Code 36 - 461.1875 MHz
  • Code 37 - 461.2125 MHz
  • Code 38 - 461.2375 MHz
  • Code 39 - 461.2625 MHz
  • Code 40 - 461.2875 MHz
  • Code 41 - 461.3125 MHz
  • Code 42 - 461.3375 MHz
  • Code 43 - 461.3625 MHz
  • Code 44 - 462.7625 MHz
  • Code 45 - 462.7875 MHz
  • Code 46 - 462.8125 MHz
  • Code 47 - 462.8375 MHz
  • Code 48 - 462.8625 MHz
  • Code 49 - 462.8875 MHz
  • Code 50 - 462.9125 MHz
  • Code 51 - 464.4875 MHz
  • Code 52 - 464.5125 MHz
  • Code 53 - 464.5375 MHz
  • Code 54 - 464.5625 MHz
  • Code 55 - 466.0375 MHz
  • Code 56 - 466.0625 MHz
  • Code 57 - 466.0875 MHz
  • Code 58 - 466.1125 MHz
  • Code 59 - 466.1375 MHz
  • Code 60 - 466.1625 MHz
  • Code 61 - 466.1875 MHz
  • Code 62 - 466.2125 MHz
  • Code 63 - 466.2375 MHz
  • Code 64 - 466.2625 MHz
  • Code 65 - 466.2875 MHz
  • Code 66 - 466.3125 MHz
  • Code 67 - 466.3375 MHz
  • Code 68 - 466.3625 MHz
  • Code 69 - 467.7875 MHz
  • Code 70 - 467.8375 MHz
  • Code 71 - 467.8625 MHz
  • Code 72 - 467.8875 MHz
  • Code 73 - 467.9125 MHz
  • Code 74 - 469.4875 MHz
  • Code 75 - 469.5125 MHz
  • Code 76 - 469.5375 MHz
  • Code 77 - 469.5625 MHz
  • Channel 34 - 462.7500 MHz - GMRS 16 - not actually a GMRS frequency
Cobra Pro On Site License Free FRS Radios Factory Default Channels Frequencies
Cobra Children’s Low Power FRS Walkie Talkie Radios Factory Default Channels Frequencies
KidDesigns Walkie Talkies
  • Power Output: 0.133mW
  • Emission: 11K0F3E
  • FCC ID IAJ-210
  • Power Output: 7mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7A
  • Power Output: 3.2mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7B
  • Power Output: 4.2mW
  • Emission: 4K26F3E
  • FCC ID IAJ-216
Midland FRS GMRS Radios Factory Default Channels Frequencies
Midland MXT500 Mobile GMRS Radio
Channels 001 to 022 are user-programmable in terms of CTCSS tone or DCS code settings. For the GMRS repeater channels, 15RP to 22RP, split tone operation is available (use of different CTCSS tones on repeater input and output, use of CTCSS on the input or output with DCS on the input or output or CSQ/no tone on the output/input). The pre-programmed channels (channels 023 - 050) may also be re-programmed by the user via the newer firmware.
Transmit is disabled on channels 8-14 (FRS channels 8, 9, 10, 11, 12, 13 and 14) by the firmware in order for the radio to remain in compliance with FCC regulations.
  • Channel 001 - 462.5625 MHz | CH1 | 5 watt power
  • Channel 002 - 462.5875 MHz | CH2 | 5 watt power
  • Channel 003 - 462.6125 MHz | CH3 | 5 watt power
  • Channel 004 - 462.6375 MHz | CH4 | 5 watt power
  • Channel 005 - 462.6625 MHz | CH5 | 5 watt power
  • Channel 006 - 462.6875 MHz | CH6 | 5 watt power
  • Channel 007 - 462.7125 MHz | CH7 | 5 watt power
  • Channel 008 - 467.5625 MHz | CH8 | TX disable (no transmit)
  • Channel 009 - 467.5875 MHz | CH9 | TX disable (no transmit)
  • Channel 010 - 467.6125 MHz | CH10 | TX disable (no transmit)
  • Channel 011 - 467.6375 MHz | CH11 | TX disable (no transmit)
  • Channel 012 - 467.6625 MHz | CH12 | TX disable (no transmit)
  • Channel 013 - 467.6875 MHz | CH13 | TX disable (no transmit)
  • Channel 014 - 467.7125 MHz | CH14 | TX disable (no transmit)
  • Channel 015 - 462.5500 MHz | CH15 | 50 watt power
  • Channel 016 - 462.5750 MHz | CH16 | 50 watt power
  • Channel 017 - 462.6000 MHz | CH17 | 50 watt power
  • Channel 018 - 462.6250 MHz | CH18 | 50 watt power
  • Channel 019 - 462.6500 MHz | CH19 | 50 watt power
  • Channel 020 - 462.6750 MHz | CH20 | 50 watt power
  • Channel 021 - 462.7000 MHz | CH21 | 50 watt power
  • Channel 022 - 462.7250 MHz | CH22 | 50 watt power
  • Channel 023 - 462.5625 MHz 250.3 Hz | | 5 watt power
  • Channel 024 - 462.6125 MHz 225.7 Hz | | 5 watt power
  • Channel 025 - 462.6625 MHz 203.5 Hz | | 5 watt power
  • Channel 026 - 462.7125 MHz 179.9 Hz | | 5 watt power
  • Channel 027 - 462.5500 MHz 162.2 Hz | | 50 watt power
  • Channel 028 - 462.6000 MHz 146.2 Hz | | 50 watt power
  • Channel 029 - 462.6500 MHz 131.8 Hz | | 50 watt power
  • Channel 030 - 462.7000 MHz 118.8 Hz | | 50 watt power
  • Channel 031 - 462.5875 MHz 023 DCS | | 5 watt power
  • Channel 032 - 462.6375 MHz 031 DCS | | 5 watt power
  • Channel 033 - 462.6875 MHz 047 DCS | | 5 watt power
  • Channel 034 - 467.5625 MHz 065 DCS | | TX disable (no transmit)
  • Channel 035 - 467.6125 MHz 073 DCS | | TX disable (no transmit)
  • Channel 036 - 467.6625 MHz 115 DCS | | TX disable (no transmit)
  • Channel 037 - 467.7125 MHz 131 DCS | | TX disable (no transmit)
  • Channel 038 - 462.5750 MHz 143 DCS | | 50 watt power
  • Channel 039 - 462.6250 MHz 156 DCS | | 50 watt power
  • Channel 040 - 462.6750 MHz 172 DCS | | 50 watt power
  • Channel 041 - 462.7250 MHz 223 DCS | | 50 watt power
  • Channel 042 - 462.5625 MHz 107.2 Hz | | 5 watt power
  • Channel 043 - 462.6125 MHz 97.4 Hz | | 5 watt power
  • Channel 044 - 462.6625 MHz 88.5 Hz | | 5 watt power
  • Channel 045 - 462.7125 MHz 79.7 Hz | | 5 watt power
  • Channel 046 - 462.5500 MHz 71.9 Hz | | 50 watt power
  • Channel 047 - 462.6000 MHz 241.8 Hz | | 50 watt power
  • Channel 048 - 462.6500 MHz 218.1 Hz | | 50 watt power
  • Channel 049 - 462.7000 MHz 192.8 Hz | | 50 watt power
  • Channel 050 - 462.5875 MHz 025 DCS | CH2 | DCS 2 | 5 watt power
  • Channel 15RP - RX: 462.5500 MHz | TX: 467.5500 MHz | 50 watt power
  • Channel 16RP - RX: 462.5750 MHz | TX: 467.5750 MHz | 50 watt power
  • Channel 17RP - RX: 462.6000 MHz | TX: 467.6000 MHz | 50 watt power
  • Channel 18RP - RX: 462.6250 MHz | TX: 467.6250 MHz | 50 watt power
  • Channel 19RP - RX: 462.6500 MHz | TX: 467.6500 MHz | 50 watt power
  • Channel 20RP - RX: 462.6750 MHz | TX: 467.6750 MHz | 50 watt power
  • Channel 21RP - RX: 462.7000 MHz | TX: 467.7000 MHz | 50 watt power
  • Channel 22RP - RX: 462.7250 MHz | TX: 467.7250 MHz | 50 watt power
  • Channel 51 - 462.6375 MHz 032 DCS
  • Channel 52 - 462.6875 MHz 051 DCS
  • Channel 53 - 467.5625 MHz 071 DCS
  • Channel 54 - 467.6125 MHz 074 DCS
  • Channel 55 - 467.6625 MHz 116 DCS
  • Channel 56 - 467.7125 MHz 132 DCS
  • Channel 57 - 462.5750 MHz 152 DCS
  • Channel 58 - 462.6250 MHz 162 DCS
  • Channel 59 - 462.6750 MHz 174 DCS
  • Channel 60 - 462.7250 MHz 226 DCS
  • Channel 61 - User configurable (user selects from channel 1-22 and then either selects no squelch, CTCSS code 1-38 or DCS code 1-83).
Cobra RX380 Series FRS Radios
Cobra RX380
Additional Factory Default Channels Frequencies
SAMCOM 20 Channel UHF Radios
FCC ID 2AIOQ-FPCN30AA
  • CH01 - 462.5500 MHz D226 [FRS Channel 15 - D226N | 226 DCS]
  • CH02 - 462.5750 MHz D243 [FRS Channel 16 - D243N | 243 DCS]
  • CH03 - 462.6000 MHz D244 [FRS Channel 17 - D244N | 244 DCS]
  • CH04 - 462.6250 MHz D245 [FRS Channel 18 - D245N | 245 DCS]
  • CH05 - 462.6500 MHz D246 [FRS Channel 19 - D246N | 246 DCS]
  • CH06 - 462.6750 MHz D251 [FRS Channel 20 - D251N | 251 DCS]
  • CH07 - 462.7000 MHz D252 [FRS Channel 21 - D252N | 252 DCS]
  • CH08 - 462.7250 MHz D255 [FRS Channel 22 - D255N | 255 DCS]
  • CH09 - 462.5625 MHz D261 [FRS Channel 1 - D261N | 261 DCS]
  • CH10 - 462.5875 MHz D332 [FRS Channel 2 - D332N | 332 DCS]
  • CH11 - 462.6125 MHz D265 [FRS Channel 3 - D265N | 265 DCS]
  • CH12 - 462.6375 MHz D266 [FRS Channel 4 - D266N | 266 DCS]
  • CH13 - 462.6625 MHz D271 [FRS Channel 5 - D271N | 271 DCS]
  • CH14 - 462.6875 MHz D274 [FRS Channel 6 - D274N | 274 DCS]
  • CH15 - 462.6500 MHz D306 [FRS Channel 19 - D306N | 306 DCS]
  • CH16 - 462.5500 MHz D311 [FRS Channel 15 - D311N | 311 DCS]
  • CH17 - 462.7000 MHz D315 [FRS Channel 21 - D315N | 315 DCS]
  • CH18 - 462.6625 MHz D325 [FRS Channel 5 - D325N | 325 DCS]
  • CH19 - 462.5625 MHz D331 [FRS Channel 1 - D331N | 331 DCS]
  • CH0 - 462.7125 MHz D225 [FRS Channel 7 - D225N | 225 DCS]
Radioditty GA-2S
Radioditty GA2S GA-2S Factory Default Out Of The Box Programming (Confirmed radios are being sold in late February 2026 with this programming)
Baofeng Factory Default Channels Frequencies
HN5RV01 firmware version
Baofeng UV-5R8W
  • Channel 1 - 400.1250 MHz
  • Channel 2 - 410.1250 MHz
  • Channel 3 - 420.1250 MHz
  • Channel 4 - 430.1250 MHz
  • Channel 5 - 440.1250 MHz
  • Channel 6 - 450.1250 MHz
  • Channel 7 - 460.1250 MHz
  • Channel 8 - 470.1250 MHz
  • Channel 9 - 480.1250 MHz
  • Channel 10 - 490.1250 MHz
  • Channel 11 - 500.1250 MHz
  • Channel 12 - 510.1250 MHz
  • Channel 13 - 519.9750 MHz
  • Channel 14 - 136.1250 MHz
  • Channel 15 - 145.1250 MHz
  • Channel 16 - 155.1250 MHz
  • Channel 17 - 165.1250 MHz
  • Channel 18 - 173.9750 MHz
Baofeng UV-98 UV98Pro
Default Channels Frequencies This list incomplete, you can help by adding to it.
  • Channel 8 - 462.5500 MHz
  • Channel 10 - 462.6000 MHz
  • Channel 11 - 462.6250 MHz
  • Channel 12 - 462.6500 MHz
  • Channel 13 - 462.6750 MHz
  • Channel 14 - 462.7000 MHz
  • Channel 15 - 462.7250 MHz
TYT Radios Factory Default Channels Frequencies
  • VFO F1 - 400.5250 MHz FM [CSQ]
  • VFO F2 - 226.0000 MHz FM [CSQ]
  • VFO F3 - 469.5250 MHz FM [CSQ]
  • Channel 1 - 136.4250 MHz FM CSQ
  • Channel 2 - 150.4250 MHz FM 159.8 Hz PL
  • Channel 3 - 173.9450 MHz FM CSQ
  • Channel 4 - 220.4250 MHz FM CSQ
  • Channel 5 - 240.4250 MHz FM D023N 023 DPL
  • Channel 6 - 259.9450 MHz FM CSQ
  • Channel 7 - 400.4250 MHz FM CSQ
  • Channel 8 - 435.4250 MHz FM CSQ
  • Channel 9 - 469.4250 MHz FM CSQ
  • Channel 10 - 136.4250 MHz NFM 67.0 Hz PL
  • Channel 11 - 150.4250 MHz NFM 254.1 Hz PL
  • Channel 12 - 173.9450 MHz NFM D023N 023 DPL
  • Channel 13 - 220.4250 MHz NFM 67.0 Hz
  • Channel 14 - 240.4250 MHz NFM 254.1 Hz PL
  • Channel 15 - 259.9450 MHz NFM D023N 023 DPL
  • Channel 16 - 400.4250 MHz NFM 67.0 Hz PL
  • Channel 17 - 435.4250 MHz NFM 254.1 Hz PL
  • Channel 18 - 469.4250 MHz NFM D023N 023 DPL
TXPro TX-680AV VHF
VHF version 136-174 MHz
FCC ID: 2AS4FEPCOTX680AV
Retevis Radios Factory Default Channels Frequencies
Retevis RT10
Zone 1
Zone 2
Zone 3
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
  • Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
  • Channel 15 - 462.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 1
  • Channel 16 - 467.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 8
  • Channel 1 - 462.5625 MHz 043 DPL D043N - FRS Channel 1
  • Channel 2 - 462.5875 MHz 065 DPL D065N - FRS Channel 2
  • Channel 3 - 462.6125 MHz 116 DPL D116N - FRS Channel 3
  • Channel 4 - 462.6375 MHz 205 DPL D205N - FRS Channel 4
  • Channel 5 - 462.6625 MHz 261 DPL D261N - FRS Channel 5
  • Channel 6 - 462.6875 MHz 265 DPL D265N - FRS Channel 6
  • Channel 7 - 462.7125 MHz 271 DPL D271N - FRS Channel 7
  • Channel 8 - 467.5625 MHz 306 DPL D306N - FRS Channel 8
  • Channel 9 - 467.5875 MHz 311 DPL D311N - FRS Channel 9
  • Channel 10 - 467.6125 MHz 331 DPL D331N - FRS Channel 10
  • Channel 11 - 467.6375 MHz 365 DPL D365N - FRS Channel 11
  • Channel 12 - 467.6625 MHz 431 DPL D431N - FRS Channel 12
  • Channel 13 - 467.6875 MHz 466 DPL D466N - FRS Channel 13
  • Channel 14 - 467.7125 MHz 503 DPL D503N - FRS Channel 14
  • Channel 1 - 446.00625 MHz 114 DPL D114N - PMR446 Channel 1
  • Channel 2 - 446.01875 MHz 131 DPL D131N - PMR446 Channel 2
  • Channel 3 - 446.03125 MHz 132 DPL D132N - PMR446 Channel 3
  • Channel 4 - 446.04375 MHz 165 DPL D165N - PMR446 Channel 4
  • Channel 5 - 446.05625 MHz 226 DPL D226N - PMR446 Channel 5
  • Channel 6 - 446.06875 MHz 306 DPL D306N - PMR446 Channel 6
  • Channel 7 - 446.08125 MHz 371 DPL D371N - PMR446 Channel 7
  • Channel 8 - 446.09375 MHz 503 DPL D503N - PMR446 Channel 8
Radtel
Radtel RT-A1 22 channel analog + digital dual mode FRS radios
Note: the digital voice mode appears to be a non-standard mode, not DMR, NXDN, D-Star, P25, etc.
"Group call" and "private calls" are available, with what appear to be either talkgroups or radio IDs in the range between 0 and 8388607. Group calls are available for talkgroups (or IDs?) 8388608 - 16777214. In digital mode, a "group call" may be made to up to 8 unique IDs per group lists, with up to 8 unique group lists. "All call" is also available to call all radios on frequency.
According to the manual, analog (NFM) and digital voice mode may be selected for any of the 22 FRS channels. In analog mode, 50 CTCSS tones plus 105 DCS codes (the manual claims 210 DCS codes, using inverted DCS). This radio is advertised as a regular FRS radio. Power output is 2 watts on channels 1-7 and 15-22. Power output is 0.5w on channels 8-14. Manual indicates the radio is capable of operating on the UHF band, 400-470 MHz.
  • Channel 1 - 462.5625 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 2 - 462.5875 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 3 - 462.6125 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 4 - 462.6375 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 5 - 462.6625 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 6 - 462.6875 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 7 - 462.7125 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 8 - 467.5625 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 9 - 467.5875 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 10 - 467.6125 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 11 - 467.6375 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 12 - 467.6625 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 13 - 467.6875 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 14 - 467.7125 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 15 - 462.5500 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 16 - 462.5750 MHz - Analog NFM mode - CSQ - CTCSS disabled, DCS disabled
  • Channel 17 - 462.6000 MHz - Digital voice mode - all call (?)
  • Channel 18 - 462.6250 MHz - Digital voice mode - all call (?)
  • Channel 19 - 462.6500 MHz - Digital voice mode - all call (?)
  • Channel 20 - 462.6750 MHz - Digital voice mode - all call (?)
  • Channel 21 - 462.7000 MHz - Digital voice mode - all call (?)
  • Channel 22 - 462.7250 MHz - Digital voice mode - all call (?)
Radtel RT518 RT-518 License Free FRS Radio
Note: This radio is sold in Europe and other countries as a PMR446 approved radio.
Frequency / Channel ID Lists
  • Freq 1 - 464.5000 MHz
  • Freq 2 - 464.5500 MHz
  • Freq 3 - 467.7625 MHz
  • Freq 4 - 467.8125 MHz
  • Freq 5 - 467.8500 MHz
  • Freq 6 - 467.8750 MHz
  • Freq 7 - 467.9000 MHz
  • Freq 8 - 467.9250 MHz
  • Freq 9 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 11 - 461.0875 MHz
  • Freq 12 - 461.1125 MHz
  • Freq 13 - 461.1375 MHz
  • Freq 14 - 461.1625 MHz
  • Freq 15 - 461.1875 MHz
  • Freq 16 - 461.2125 MHz
  • Freq 17 - 461.2375 MHz
  • Freq 18 - 461.2625 MHz
  • Freq 19 - 461.2875 MHz
  • Freq 20 - 461.3125 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 25 - 462.8125 MHz
  • Freq 26 - 462.8375 MHz
  • Freq 27 - 462.8625 MHz
  • Freq 28 - 462.8875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 36 - 466.0875 MHz
  • Freq 37 - 466.1125 MHz
  • Freq 38 - 466.1375 MHz
  • Freq 39 - 466.1625 MHz
  • Freq 40 - 466.1875 MHz
  • Freq 41 - 466.2125 MHz
  • Freq 42 - 466.2375 MHz
  • Freq 43 - 466.2625 MHz
  • Freq 44 - 466.2875 MHz
  • Freq 45 - 466.3125 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 1 - 151.6250 MHz
  • Freq 2 - 151.9550 MHz
  • Freq 3 - 154.5700 MHz
  • Freq 4 - 154.6000 MHz
  • Freq 5 - 151.7000 MHz
  • Freq 6 - 151.7600 MHz
  • Freq 7 - 151.8200 MHz
  • Freq 8 - 151.8800 MHz
  • Freq 9 - 151.9400 MHz
  • Freq 10 - 151.5125 MHz
  • Freq 11 - 151.6550 MHz
  • Freq 12 - 151.6850 MHz
  • Freq 13 - 151.7150 MHz
  • Freq 14 - 151.7450 MHz
  • Freq 15 - 151.7750 MHz
  • Freq 16 - 151.8650 MHz
  • Freq 17 - 151.8950 MHz
  • Freq 18 - 151.9250 MHz
  • Freq 20 - 154.4900 MHz
  • Freq 21 - 154.5150 MHz
  • Freq 22 - 154.5275 MHz
  • Freq 23 - 154.5400 MHz
  • Freq 24 - 154.6000 MHz
  • Freq 26 - 158.4000 MHz
  • Freq 27 - 158.4075 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 81 - 456.3375 MHz
  • Freq 82 - 456.4375 MHz
  • Freq 83 - 456.5375 MHz
  • Freq 84 - 456.6375 MHz
  • Freq 85 - 457.3125 MHz
  • Freq 86 - 457.4125 MHz
  • Freq 87 - 457.5125 MHz
  • Freq 88 - 457.7625 MHz
  • Freq 89 - 457.8625 MHz
  • Freq 3 - 152.8850 MHz
  • Freq 4 - 152.9150 MHz
  • Freq 7 - 152.9450 MHz
  • Freq 8 - 151.8350 MHz
  • Freq 9 - 151.8050 MHz
  • Freq 24 - 153.0050 MHz
