11 meter
| 25.330 MHz to 25.550 MHz | 25330 kHz to 25550 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks |
| 26.480 MHz to 26.950 MHz | 26480 kHz to 26950 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks |
| 27.540 MHz to 28.000 MHz | 27540 kHz to 28000 kHz | Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz |
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz).  Common freeband frequencies include:
 - 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
