11 meter
Revision as of 13:36, 29 January 2019 by R4002 (Talk | contribs)
25.330 MHz to 25.550 MHz 25330 kHz to 25550 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks
26.480 MHz to 26.950 MHz 26480 kHz to 26950 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks
27.430 MHz to 27.540 MHz 27410 kHz to 27540 kHz Business/Industrial Radio Service (20 kHz steps, FM mode)
27.540 MHz to 28.000 MHz 27540 kHz to 28000 kHz Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz
What are the freeband CB frequencies? Freeband CB channels CB frequencies on a ham radio
  • 25.615 MHz - 26.055 MHz - Band A - often used by taxi cabs and trucking companies (AM mode in the Americas, AM or FM elsewhere)
  • 26.065 MHz - 26.505 MHz - Band B - often used by taxi cabs, trucking companies and hunting clubs
  • 26.515 MHz - 26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
  • 26.565 MHz - 26.955 MHz - German CB channels 41-80, FM mode only, heavily used in Europe
  • 26.905 MHz AM - alternate to 26.915 MHz, others, Mexican taxicab dispatcher lady also logged on this frequency
  • 26.965 MHz - 27.405 MHz - Band D - legal CB band - "mid band", "FCC band" or "CEPT" band
  • 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
  • 27.405 MHz - 27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
  • 27.60125 MHz - 27.99125 MHz - UK FM 27/81 CB (UK only) also CADS/WPAS Channels LW01-LW40 UK, Ireland (AM/FM modes, Church broadcasts) straight 10 kHz channel steps
  • 27.605 MHz - 27.995 MHz - CADS/WPAS Channels UW01-UW40 UK, Ireland and elsewhere straight 10 kHz channel steps
  • 27.635 MHz AM - CB channel 19 "up one band" - truckers are often heard here (see also 26.735 MHz)
  • 27.855 MHz - 28.305 MHz - Band F - up to 27.995 MHz (channel 11A) popular with taxicabs and truckers, although truckers are often heard above 28.000 MHz it is strongly advised that freebanders stay below 28 MHz
Freeband 11 meter users logged
  • 25.515 MHz FM - Taxi cab dispatch Russian RU taxi lady Olga
  • 25.585 MHz FM - Taxi cab dispatch Russia
  • 25.610 MHz FM - Taxi cab dispatch Russia dispatcher lady
  • 25.615 MHz FM - Russian taxi cab dispatch lady reading numbers in Russian heard here
  • 25.615 MHz AM - Mexican taxi cab dispatch
  • 25.620 MHz FM - Russian taxi cab dispatcher Russia taxi
  • 25.675 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.685 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here "Juanita" or "the taco lady" to CBers
  • 25.715 MHz FM - Russian taxi cab dispatch lady
  • 25.775 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.785 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.895 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.925 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 26.005 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 26.105 MHz AM - truckers, taxis, etc.
  • 26.105 MHz FM - Taxi cab Russia RU lady
  • 26.620 MHz FM - Russian taxi cab dispatcher
  • 26.670 MHz FM - Russian taxi cab dispatcher
  • 26.675 MHz AM - US freeband CBers, hunting clubs
  • 26.685 MHz AM - ABF drivers "company frequency" or "company channel"
  • 26.695 MHz AM - Mexican taxicabs
  • 26.705 MHz AM - Puerto Rico/Latin America high power CB
  • 26.715 MHz AM - Puerto Rico/Latin America high power CB
  • 26.905 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 27.235 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish
  • 27.235 MHz FM - ROS data mode (Europe) (see also: 27.245 MHz, 27.635 MHz)
  • 27.245 MHz FM - ROS data mode (Europe)
  • 27.420 MHz FM - Russian taxi cab dispatch lady "Olga"
  • 27.430 MHz FM - Russian taxi cab dispatch lady
  • 27.460 MHz FM - Russian taxi cab dispatch lady
  • 27.515 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here with roger beep
  • 27.805 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 27.825 MHz FM - Russian taxi cab dispatch Moscow RU
  • 27.875 MHz FM - Russian taxi cab dispatch Moscow RU
  • 28.005 MHz AM - Mexican taxi cab dispatch lady reading numbers (addresses, etc)
  • 28.025 MHz AM - Mexican taxi cab dispatch
  • 28.085 MHz AM - CB channel 19 "up two bands" - truckers are often heard here
