11 meter
Revision as of 19:25, 30 January 2019 by R4002 (Talk | contribs)
25.330 MHz to 25.550 MHz 25330 kHz to 25550 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks
26.480 MHz to 26.950 MHz 26480 kHz to 26950 kHz Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks
27.430 MHz to 27.540 MHz 27410 kHz to 27540 kHz Business/Industrial Radio Service (20 kHz steps, FM mode)
27.540 MHz to 28.000 MHz 27540 kHz to 28000 kHz Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz
What are the freeband CB frequencies? Freeband CB channels CB frequencies on a ham radio
  • 25.615 MHz - 26.055 MHz - Band A - often used by taxi cabs and trucking companies (AM mode in the Americas, AM or FM elsewhere)
  • 26.065 MHz - 26.505 MHz - Band B - often used by taxi cabs, trucking companies and hunting clubs
  • 26.515 MHz - 26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
  • 26.565 MHz - 26.955 MHz - German CB channels 41-80, FM mode only, heavily used in Europe
  • 26.905 MHz AM - alternate to 26.915 MHz, others, Mexican taxicab dispatcher lady also logged on this frequency
  • 26.965 MHz - 27.405 MHz - Band D - legal CB band - "mid band", "FCC band" or "CEPT" band
  • 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
  • 27.405 MHz - 27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
  • 27.60125 MHz - 27.99125 MHz - UK FM 27/81 CB (UK only) also CADS/WPAS Channels LW01-LW40 UK, Ireland (AM/FM modes, Church broadcasts) straight 10 kHz channel steps
  • 27.605 MHz - 27.995 MHz - CADS/WPAS Channels UW01-UW40 UK, Ireland and elsewhere straight 10 kHz channel steps
  • 27.635 MHz AM - CB channel 19 "up one band" - truckers are often heard here (see also 26.735 MHz)
  • 27.855 MHz - 28.305 MHz - Band F - up to 27.995 MHz (channel 11A) popular with taxicabs and truckers, although truckers are often heard above 28.000 MHz it is strongly advised that freebanders stay below 28 MHz
Business commercial taxi cab dispatch truckers hunters using 11 meter frequencies
Received in various locations, these are commercial or business users of the 11 meter frequencies such as taxi cab companies, trucking companies, logging companies, car services, etc. Taxi cab dispatchers, truckers, boats and other mobile business users are heavy users of CB and the 11 meter band worldwide, but especially in Latin America, Russia and Eastern Europe, where economic conditions make installing a "real" land mobile system unrealistic. Note that most export radios sold today offer frequency coverage from 25.615 MHz to 30.105 MHz, 25.165 MHz to 28.755 MHz, 25.615 MHz to 28.305 MHz, 26.000 to 32.000 MHz or 26.515 MHz to 27.855 MHz. Radio sold in Europe often include the capability to switch from the zeros to the fives, in other words, -5 kHz switch, to gain an in-between channel (i.e. go from 27.455 MHz to 27.450 MHz). The original intention behind this is to allow users to access the original Polish/Russian/Eastern European channel plan.
  • 25.515 MHz FM - Taxi cab dispatch Russian RU taxi lady Olga
  • 25.585 MHz FM - Taxi cab dispatch Russia
  • 25.610 MHz FM - Taxi cab dispatch Russia dispatcher lady
  • 25.615 MHz FM - Russian taxi cab dispatch lady reading numbers in Russian heard here
  • 25.615 MHz AM - Mexican taxi cab dispatch
  • 25.620 MHz FM - Russian taxi cab dispatcher Russia taxi
  • 26.625 MHz AM - Mexican taxi cab dispatch
  • 25.675 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.685 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here "Juanita" or "the taco lady" to CBers
  • 25.715 MHz FM - Russian taxi cab dispatch lady
  • 25.775 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.785 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.895 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 25.915 MHz AM - Mexican or Latin American taxi dispatch lady Spanish language
  • 25.925 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 26.005 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 26.105 MHz AM - truckers, taxis, etc.
  • 26.105 MHz FM - Taxi cab Russia RU lady
  • 26.375 MHz AM - truckers, hunting clubs (English and Spanish)
  • 26.405 MHz AM - another commonly active frequency (truckers, hunting clubs)
  • 26.495 MHz FM - Russian taxi cab dispatch, unknown location
  • 26.505 MHz AM - US truckers, hunting clubs
  • 26.515 MHz AM - US truckers, hunting clubs
  • 26.620 MHz FM - Russian taxi cab dispatcher
  • 26.670 MHz FM - Russian taxi cab dispatcher
  • 26.675 MHz AM - US freeband CBers, hunting clubs
  • 26.685 MHz AM - ABF drivers "company frequency" or "company channel"
  • 26.695 MHz AM - Mexican taxicabs
  • 26.705 MHz FM - Russian taxi dispatch, near Moscow
  • 26.705 MHz AM - Puerto Rico/Latin America high power CB
  • 26.715 MHz AM - Puerto Rico/Latin America high power CB
  • 26.735 MHz AM - US truckers, various locations
  • 26.775 MHz AM - US taxi cab dispatcher, unknown location
  • 26.775 MHz FM - Russian taxi cab dispatch Russia taxi lady
  • 26.805 MHz AM - US truckers, hunting radio or hunting clubs
  • 26.820 MHz FM - Russian or CIS Eastern Europe taxi dispatch
  • 26.855 MHz FM - Taxi cab dispatch - Moscow Russia - Russian taxi lady
  • 26.895 MHz AM _ US truckers
  • 26.905 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 26.915 MHz AM - High power US American freeband CBers and truckers
  • 26.945 MHz AM - US truckers freebanders "Snaker channel" or "Sneaker channel" ??
  • 26.955 MHz AM - US truckers
  • 26.995 MHz AM - Mexican taxi cab dispatch (YL reading numbers in Spanish, talking to OM drivers)
  • 27.045 MHz AM - Mexican taxi cab dispatch (YL reading numbers in Spanish)
  • 27.045 MHz FM - Taxicab dispatch St. Petersburg, Russia
  • 27.185 MHz AM - CB channel 19, probably the most heavily used frequency by trucking companies, etc.
  • 27.195 MHz AM - Mexican taxi cab dispatch
  • 27.235 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish
  • 27.235 MHz FM - ROS data mode (Europe) (see also: 27.245 MHz, 27.635 MHz)
  • 27.245 MHz FM - ROS data mode (Europe)
  • 27.420 MHz FM - Russian taxi cab dispatch lady "Olga"
  • 27.425 MHz AM - Mexican taxi cab dispatcher
  • 27.430 MHz FM - Russian taxi cab dispatch lady
  • 27.445 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
  • 27.460 MHz FM - Russian taxi cab dispatch lady
  • 27.495 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
  • 27.505 MHz AM - US truckers, unknown location
  • 27.510 MHz FM - Taxi cab dispatch, Moscow RU
  • 27.515 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here with roger beep
  • 27.525 MHz AM - US truckers
  • 27.535 MHz AM - US truckers/Mexican truckers
  • 27.545 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
  • 27.585 MHz AM - ABF drivers "company frequency" or "company channel"
  • 27.595 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
  • 27.615 MHz AM - US truckers, unknown location
  • 27.625 MHz AM - US logging trucks, East Coast
  • 27.635 MHz FM - Weather and Traffic conditions report (St. Petersburg, Russia) (possibly off air)
  • 27.645 MHz AM - US truckers
  • 27.645 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
  • 27.655 MHz AM - US truckers
  • 27.665 MHz AM - US truckers
  • 27.685 MHz AM - US truckers
  • 27.705 MHz AM - US truckers, Mexican taxi cab dispatchers
  • 27.735 MHz FM - Popular frequency for German CBers (freebanders)
  • 27.745 MHz AM - US truckers
  • 27.765 MHz FM - Popular frequency for German CBers (freebanders)
  • 27.775 MHz FM - Russian taxi cab dispatch Moscow taxi lady Russia
  • 27.775 MHz AM - US truckers, Mexican truckers and taxis
  • 27.785 MHz AM - US truckers, hunting club frequency
  • 27.805 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
  • 27.825 MHz FM - Russian taxi cab dispatch Moscow RU
  • 27.875 MHz FM - Russian taxi cab dispatch Moscow RU
  • 27.905 MHz AM - Taxi cab dispatch in Spanish
  • 27.905 MHz AM - US truckers
  • 27.915 MHz AM - Truckers, East Coast of USA, possibly New Jersey or New York area
  • 27.950 MHz FM - Russian taxi cab dispatch Moscow taxi lady Russia
  • 27.965 MHz AM - US truckers
  • 27.975 MHz AM - US truckers
  • 27.985 MHz AM - US truckers
  • 27.995 MHz AM - Mexican taxi cab dispatch
  • 28.005 MHz AM - Mexican taxi cab dispatch lady reading numbers (addresses, etc)
  • 28.025 MHz AM - Mexican taxi cab dispatch
  • 28.035 MHz FM - Russian taxi cab dispatch unknown location Russia
  • 28.085 MHz AM - CB channel 19 "up two bands" - truckers are often heard here
  • 28.085 MHz FM - Russia taxicab dispatcher Olga Russian lady taxi 10 meters
  • 28.145 MHz FM - Russian taxi cab dispatch unknown location Russia
