FRS
Family Radio Service
UHF replacement (or rather supplement) to the CB service. Created in the late 1990s by the FCC after intense lobbying by RadioShack.
Ch | Freq MHz | - Notes - |
1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
20 | 462.6750 | Shared with GMRS - GMRS Calling Channel (141.3 Hz CTCSS) 2 watts maximum TX power |
21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
Late 2010s/early 2020s Chinese manufactured and sold FRS units with FCC Part 95 FRS radio authorization indicate emission types including 10K0F3E for all 22 channels (462 MHz - 467 MHz), 12K0F3E emission, 9K64F3E emission, 11K3F3E emission, 11K0F3E emission, 8K00F3E emission and other bandwidths, including super-narrow FM emission 5K81F3E, 6K00F3E, 5K75F3E and others. Some of these radios are clearly marketed as children's walkie-talkies and offer only 50mw-100mw transmit power (compared to higher-end radios, even Chinese radios, which offer 500mw to 1 watt to 2 watt power output on the 462 MHz frequencies). Cheap children's walkie talkies designed for short range purposes transmit 250mw on 462.55 MHz - 467.7125 MHz, with emission type 9K64F3E on 462.55 MHz - 462.725 MHz and emission 9K69F3E on 467.5625 MHz - 467.7125 MHz. Almost all of these lower-grade transceivers offer all 22 channels, and simply transmit below the 500mw power limit for FRS on all 22 FRS channels.
- FRS channel 7 462.7125 MHz subcode 15 (7-15) Airshow/milcom hobbyist recommended channel (backup) PL 110.0 Hz
- FRS channel 14 467.7125 MHz subcode 38 (14-38) Airshow/milcom hobbyist recommended channel (primary) PL 250.3 Hz
- FRS channel 18 462.6250 MHz subcode 19 (18-19) is default channel 6 on the Baofeng BF-888S series UHF walkie talkies PL 127.3 Hz
- FRS channel 20 462.6750 MHz subcode 22 (20-22) is the recommended GMRS calling/travel channel, with CTCSS or PL tone 141.3 Hz
- FRS channel 22 462.7250 MHz subcode 21 (22-21) is default channel 7 on the Baofeng BF-888S series UHF walkie talkies PL 136.5 Hz
