Letter beacon
- Cluster beacons
Contents[hide] |
Location of letter beacons
The letter beacon radio transmissions were discovered in the late 1960s. Their presence became known to the wider amateur radio community in 1978, when beacon “W” started transmitting on 3584 kHz, in the 80 meters band. SPEEDX published indirect evidence that this particular transmitter was located in Cuba. (3)
In 1982 in was reported by SPEEDX, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, it was suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
ID letter | Location |
C | Moscow, RUS |
D | Odessa, UKR |
O | Moscow, RUS |
P | Kaliningrad, RUS |
S | Arkhangelsk, RUS |
Z | Mukachevo, UKR |
A | Astrakhan, RUS (tentative) |
C | Moscow, RUS |
D | Sevastopol, UKR |
F | Vladivostok, RUS |
K | Petropavlovsk-Kamchatsky, RUS |
M | Magadan, RUS |
S | Severomorsk, RUS |
L | Tirana, ALB (inactive) |
R | Izhevsk (Ustinov), RUS |
V | Khiva, UZB |
Types of letter beacons
Cluster beacons
D | -0.3 | 3593.7, 4557.7, 5153.7, 7038.7, 8493.7, 10871.7, 13527.7, 16331.7, 20047.7 |
P | -0.2 | 3593.8, 4557.8, 5153.8, 7038.8, 8494.8, 10871.8, 13527.8, 16331.8, 20047.8 |
S | -0.1 | 3593.9, 4557.9, 5153.9, 7038.9, 8494.9, 10871.9, 13527.9, 16331.9, 20047.9 |
C | 0.0 | 3594.0, 4558.0, 5154.0, 7039.0, 8495.0, 10872.0, 13528.0, 16332.0, 20048.0 |
A | +0.1 | 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 13528.1 16332.1 (10) |
F | +0.2 | 7039.2, 16332.2 |
K | +0.3 | 5154.3, 7039.3, 8495.3, 16332.3 |
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier.
ID letter | Frequencies (kHz) |
R | 4325.9, 5465.9 |
V | 3658.0, 5141, 5342, 6430.7, 6809, 7027.5, 8103.5, 10202 |
P (12) | 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079 |
C | 8000 |
FSK beacons
ENIGMA designation
ENIGMA ID | Description |
MX | Cluster beacons |
Similar systems
A few aero navigation Non Directional Beacons also transmit single letter identification codes. They can be easily distinguished from Letter beacons as they transmit in the allocated low frequency and medium frequency bands, most of them are listed in appropriate aviation handbooks and their transmission mode is A2A (full carrier with audio modulation).
Notes & References
- E.N.I.G.M.A. stands for "European Numbers Information Gathering and Monitoring Association". It was a unique association of radio listeners based in the United Kingdom and operated during the 1990’s.
- ENIGMA-2000 is an internet based community with the same general interests as the old ENIGMA association and with wider coverage of general Intelligence matters. This group produces a regular newsletter and maintains the old ENIGMA station naming scheme. ENIGMA-2000 shows less interest in letter beacons than its predecessor.
- Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
- Spooks mailing list.
- William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications,CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
