11 meter
| 25.330 MHz to 25.550 MHz | 25330 kHz to 25550 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks |
| 26.480 MHz to 26.950 MHz | 26480 kHz to 26950 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks |
| 27.540 MHz to 28.000 MHz | 27540 kHz to 28000 kHz | Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz |
What are the freeband CB frequencies? Freeband CB channels CB frequencies on a ham radio
- 26.905 MHz AM - alternate to 26.915 MHz, others, Mexican taxicab dispatcher lady also logged on this frequency
- 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
Freeband 11 meter users logged
Received in various locations
- 25.515 MHz FM - Taxi cab dispatch Russian RU taxi lady Olga
- 25.585 MHz FM - Taxi cab dispatch Russia
- 25.610 MHz FM - Taxi cab dispatch Russia dispatcher lady
- 25.615 MHz FM - Russian taxi cab dispatch lady reading numbers in Russian heard here
- 25.615 MHz AM - Mexican taxi cab dispatch
- 25.620 MHz FM - Russian taxi cab dispatcher Russia taxi
- 25.675 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.685 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here "Juanita" or "the taco lady" to CBers
- 25.715 MHz FM - Russian taxi cab dispatch lady
- 25.775 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.785 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.895 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.925 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 26.005 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 26.105 MHz AM - truckers, taxis, etc.
- 26.105 MHz FM - Taxi cab Russia RU lady
- 26.620 MHz FM - Russian taxi cab dispatcher
- 26.670 MHz FM - Russian taxi cab dispatcher
- 26.675 MHz AM - US freeband CBers, hunting clubs
- 26.685 MHz AM - ABF drivers "company frequency" or "company channel"
- 26.695 MHz AM - Mexican taxicabs
- 26.705 MHz AM - Puerto Rico/Latin America high power CB
- 26.715 MHz AM - Puerto Rico/Latin America high power CB
- 26.905 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 27.235 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish
- 27.235 MHz FM - ROS data mode (Europe) (see also: 27.245 MHz, 27.635 MHz)
- 27.245 MHz FM - ROS data mode (Europe)
- 27.420 MHz FM - Russian taxi cab dispatch lady "Olga"
- 27.430 MHz FM - Russian taxi cab dispatch lady
- 27.460 MHz FM - Russian taxi cab dispatch lady
- 27.515 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here with roger beep
- 27.805 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 27.825 MHz FM - Russian taxi cab dispatch Moscow RU
- 27.875 MHz FM - Russian taxi cab dispatch Moscow RU
- 28.005 MHz AM - Mexican taxi cab dispatch lady reading numbers (addresses, etc)
- 28.025 MHz AM - Mexican taxi cab dispatch
- 28.085 MHz AM - CB channel 19 "up two bands" - truckers are often heard here
