11 meter
| 25.330 MHz to 25.550 MHz | 25330 kHz to 25550 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and COTHEN networks |
| 26.480 MHz to 26.950 MHz | 26480 kHz to 26950 kHz | Government and Military Fixed/Mobile, including the Civil Air Patrol and SHARES networks |
| 27.540 MHz to 28.000 MHz | 27540 kHz to 28000 kHz | Government and Fixed/Mobile, including NATO common combat scene of action frequency 27.900 MHz 27900 kHz |
What are the freeband CB frequencies? Freeband CB channels CB frequencies on a ham radio
- 26.905 MHz AM - alternate to 26.915 MHz, others, Mexican taxicab dispatcher lady also logged on this frequency
- 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
Freeband 11 meter land mobile users logged
Received in various locations, these are commercial or business users of the 11 meter frequencies
- 25.515 MHz FM - Taxi cab dispatch Russian RU taxi lady Olga
- 25.585 MHz FM - Taxi cab dispatch Russia
- 25.610 MHz FM - Taxi cab dispatch Russia dispatcher lady
- 25.615 MHz FM - Russian taxi cab dispatch lady reading numbers in Russian heard here
- 25.615 MHz AM - Mexican taxi cab dispatch
- 25.620 MHz FM - Russian taxi cab dispatcher Russia taxi
- 25.675 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.685 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here "Juanita" or "the taco lady" to CBers
- 25.715 MHz FM - Russian taxi cab dispatch lady
- 25.775 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.785 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.895 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 25.925 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 26.005 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 26.105 MHz AM - truckers, taxis, etc.
- 26.105 MHz FM - Taxi cab Russia RU lady
- 26.375 MHz AM - truckers, hunting clubs (English and Spanish)
- 26.515 MHz AM - US truckers, hunting clubs
- 26.620 MHz FM - Russian taxi cab dispatcher
- 26.670 MHz FM - Russian taxi cab dispatcher
- 26.675 MHz AM - US freeband CBers, hunting clubs
- 26.685 MHz AM - ABF drivers "company frequency" or "company channel"
- 26.695 MHz AM - Mexican taxicabs
- 26.705 MHz FM - Russian taxi dispatch, near Moscow
- 26.705 MHz AM - Puerto Rico/Latin America high power CB
- 26.715 MHz AM - Puerto Rico/Latin America high power CB
- 26.735 MHz AM - US truckers, various locations
- 26.805 MHz AM - US truckers, hunting radio or hunting clubs
- 26.855 MHz FM - Taxi cab dispatch - Moscow Russia - Russian taxi lady
- 26.905 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 26.915 MHz AM - High power US American freeband CBers and truckers
- 26.955 MHz AM - US truckers
- 27.235 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish
- 27.235 MHz FM - ROS data mode (Europe) (see also: 27.245 MHz, 27.635 MHz)
- 27.245 MHz FM - ROS data mode (Europe)
- 27.420 MHz FM - Russian taxi cab dispatch lady "Olga"
- 27.430 MHz FM - Russian taxi cab dispatch lady
- 27.445 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
- 27.460 MHz FM - Russian taxi cab dispatch lady
- 27.495 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
- 27.505 MHz AM - US truckers, unknown location
- 27.510 MHz FM - Taxi cab dispatch, Moscow RU
- 27.515 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here with roger beep
- 27.525 MHz AM - US truckers
- 27.535 MHz AM - US truckers/Mexican truckers
- 27.545 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
- 27.595 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
- 27.615 MHz AM - US truckers, unknown location
- 27.635 MHz FM - Weather and Traffic conditions report (St. Petersburg, Russia) (possibly off air)
- 27.645 MHz AM - US truckers
- 27.645 MHz AM - Mexican taxi cab dispatch lady - numbers in Spanish
- 27.655 MHz AM - US truckers
- 27.685 MHz AM - US truckers
- 27.735 MHz FM - Popular frequency for German CBers (freebanders)
- 27.735 MHz FM - Russian taxi cab dispatch Moscow taxi lady Russia
- 27.805 MHz AM - Mexican taxi cab dispatch lady reading numbers in Spanish heard here
- 27.825 MHz FM - Russian taxi cab dispatch Moscow RU
- 27.875 MHz FM - Russian taxi cab dispatch Moscow RU
- 27.915 MHz AM - Truckers, East Coast of USA, possibly New Jersey or New York area
- 27.950 MHz FM - Russian taxi cab dispatch Moscow taxi lady Russia
- 28.005 MHz AM - Mexican taxi cab dispatch lady reading numbers (addresses, etc)
- 28.025 MHz AM - Mexican taxi cab dispatch
- 28.085 MHz AM - CB channel 19 "up two bands" - truckers are often heard here
