FRS
Family Radio Service
UHF replacement (or rather supplement) to the CB service. Created in the late 1990s by the FCC after intense lobbying by RadioShack.
Late 2010s/early 2020s Chinese manufactured and sold FRS units with FCC Part 95 FRS radio authorization indicate emission types including 10K0F3E for all 22 channels (462 MHz - 467 MHz), 12K0F3E emission, 9K64F3E emission, 11K3F3E emission, 11K0F3E emission, 8K00F3E emission and other bandwidths, including super-narrow 5K81F3E, 6K00F3E, 5K75F3E and others. Some of these radios are clearly marketed as children's walkie-talkies and offer only 50mw-100mw transmit power (compared to higher-end radios, even Chinese radios, which offer 500mw to 1 watt to 2 watt power output on the 462 MHz frequencies).
| Ch | Freq MHz | - Notes - |
| 1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
| 2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
| 3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
| 4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
| 5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
| 6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
| 7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
| 8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
| 9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
| 10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
| 11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
| 12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
| 13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
| 14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
| 15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
| 16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
| 17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
| 18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
| 19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
| 20 | 462.6750 | Shared with GMRS - GMRS Calling Channel 2 watts maximum TX power |
| 21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
| 22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
- FRS channel 1 (462.5625 MHz) CSQ (no tone)is the recommended "calling" frequency, along it is often the busiest calling - National SOS Radio Network
- FRS channel 3 (462.6125 MHz) CSQ (no tone)is the recommend prepper/militia channel with MURS channel 3 and CB channel 3 as part of the AmRRON CH3 Project
- FRS channel 7 (462.7125 MHz) subcode 15 (7-15) Airshow/milcom hobbyist recommended channel (backup) PL 110.0 Hz
- FRS channel 14 (467.7125 MHz) subcode 38 (14-38) Airshow/milcom hobbyist recommended channel (primary) PL 250.3 Hz
- FRS channel 20 (462.6750 MHz) is the recommended GMRS calling/travel channel, with CTCSS or PL tone 141.3 Hz
- Crossband repeaters, patching FRS/GMRS with CB or MURS, is becoming more and more popular. Use of PL tones 156.7 Hz and 167.9 Hz is recommended. use of 67.0 Hz (the default tone for many radios) is not recommended. The GMRS "default" tone is 141.3 Hz.
